Bluetooth?
Old Mar 14, 2010 | 06:30 PM
rlhtroy@aol.com's Avatar
rlhtroy@aol.com
Default Bluetooth?
Hey guys! I just picked up a new Sierra 1500 and it has a beautiful blue tooth system for my cell phone. I thought GEE my 07 C6 should have the same type of system but I can't seem to find out anything about it. I look at the operation manual and their is no mention of this feature. Any help out there? Thanksed
Old Mar 14, 2010 | 06:34 PM
laconiajack's Avatar
laconiajack
Corvette didn't have bluetooth phone capability until the 2009 nodel year.
Old Mar 14, 2010 | 06:38 PM
cclive's Avatar
cclive
Time to trade in....for $20,000,you can have bluetooth.
Old Mar 14, 2010 | 07:58 PM
CSixDude's Avatar
CSixDude
Check this out. If you can live without OnStar and voice controls for the Nav system, you can have BlueTooth via the OnStar button.
http://www.costartech.com/pb/products/bluestar.html
BlueSTAR 2010 Complete Kit ........................................ ..................... $279
Complete kit, for all GM vehicles 2002 and up.This is all you need. Just plug it in and go!
(Shipping Units ordered before 3-7-10 this week. Next batch targeted for 3-25)
Note: Installing the BlueSTAR 2010 requires disconnecting your onstar communications module. Once disconnected, you will not have any onstar capabilities, including emergency assistance, or voice control for navigation if equipped.
Note: The BlueSTAR 2010 is designed for GM class2 and GMLAN data vehicles only. It will not work in vehicles that do not utilize either of these communication busses to mute the radio. This includes early model GM vehicles (pre-2002) that utilized the Entertainment and Control Bus (E&C) to mute the radio. Contact us or refer to your service manual when in doubt.
Old Mar 14, 2010 | 09:11 PM
CSixDude's Avatar
CSixDude
It would be interesting to compare the wire diagrams of the 2008/2009 side by side and see how the bluetooth module was integrated. It's very possible that you could add this to an earlier model car. It may be something as simple as buying an upgraded OnStar module. Just depends on where/how they put the BlueTooth.
I don't have the manuals or I would investigate.
Old Mar 14, 2010 | 10:18 PM
Another Don's Avatar
Another Don
I traded my '07 coupe for an '09 1> to turn the A6 trannie to an M6 and 2> to get the Bluetooth.
I have no idea how the Bluetooth is integrated in with the rest of the electronics, but I do know that there are some idiosyncracies in the '09. First, the Bluetooth can only be operated with the buttons on the steering wheel and so far, none of the aftermarket folks have developed a harness for those Bluetooth buttons to work with aftermarket bluetooth nav systems. That is, if I added a Pioneer Z110BT for nav and bluetooth, those steering wheel buttons would become non-functional. I also know that adding an OEM nav, I have to have a model for an "09. OEM Navs from '05 thru '08 won't work with the Bluetooth.
I can't imagine that adding the Bluetooth is cheap if it is even possible. By the time you found the Bluetooth module, correct radio or nav, changed out the steering wheel and probably changed out the harness to the steering wheel to work with the buttons, you probably would have been better off just trading for a newer car that already had the Bluetooth. Just my $0.02. YMMV
Old Mar 14, 2010 | 10:31 PM
AntneeD's Avatar
AntneeD
anyone know anything about this unit?
sounds great....
Old Mar 15, 2010 | 12:32 AM
candlemuse's Avatar
candlemuse
My 07 didn`t even come with a simple AUX input never mind the Bluetooth.
Old Mar 15, 2010 | 01:57 AM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
I got this motorola bluetooth T505 ,$60., for my o8 vert works off unit or can be used thru fm radio, it works.
www.wirelessoemshop.com
Old Mar 15, 2010 | 09:29 AM
JLB768's Avatar
JLB768
sounds great....
Old Mar 15, 2010 | 10:58 AM
CSixDude's Avatar
CSixDude
From your description, it sounds like the Bluetooth on the 2009 is part of the Nav unit. That would probably make it not a worthwhile venture to try to upgrade.
In looking over the site in the link posted by George Vee, I see they have a new 605 unit out that looks interesting...
I think I also read somewhere that someone is working on a BlueTooth version of the GM PAL. That might also be a good way to go once it becomes available.
Old Mar 15, 2010 | 11:04 AM
cclive's Avatar
cclive
That's OK, they still don't if you have NAV...
Old Mar 15, 2010 | 11:38 AM
PAKev's Avatar
PAKev
The Bluestar 2010 looks nice. Anyone know where the OnStar module is located in the convertible?
Old Mar 15, 2010 | 03:32 PM
andneil74's Avatar
andneil74
Cruising
On the convertible, the Onstar module is located in the right cubby behind the carpet. You can easily pry away the carpet below the cubby lid and access the module. I just read about the Costar Bluestar 2010 and it sounds like a winner to me. Getting ready to order it this afternoon. Anyone have any experience with this yet?
Old Mar 15, 2010 | 05:28 PM
65Corvette's Avatar
65Corvette
For $40 you can pick up a BlueTooth speaker and clip it to your visor. They work great and solved the problem for me on another ride that didn't have BlueTooth.
Old Mar 17, 2010 | 12:22 AM
AntneeD's Avatar
AntneeD
Nice, let us know how it works out...take some pics during the install if you can for use to see etc..
best of luck!! awaiting your install and review!
thanks!
Old Mar 17, 2010 | 10:10 AM
BSE1956's Avatar
BSE1956
I have the bluetooth on the 09 and no Nav unit. The quality of the system is just OK and not consistent. Phone placement (I have a Bberry) can determine how much feedback or static you will get. I've had better systems, but it works. BTW: forget using it with the top off. WAY too much noise.
To Bluetooth?
Old Mar 17, 2010 | 11:23 AM
mickeykelley's Avatar
mickeykelley
People way smarter than me determined long ago that trying to add the bluetooth to my 08 was not realistic. Ray K is working with people at the PAL and estimated this fall or so will have new PAL with bluetooth. So I am just waiting.
Old Mar 17, 2010 | 11:44 AM
NYC-Style's Avatar
NYC-Style
I put an AVIC Z3 in my '07 coupe last year with blue tooth module...steering wheel controls operate the functions of the unit. I can make calls using voice command...but need to touch the "phone" symbol to answer incoming calls.
Old Mar 17, 2010 | 12:37 PM
GCD1962's Avatar
GCD1962
My new 2010 Ford Taurus has a sytem called Sync that has Blue tooth and many other voice control commands available. Cost is zero, no extra charges at all.
