2008 Vette dash split open
Old Jul 7, 2010 | 09:15 PM
plumqik's Avatar
plumqik
Default 2008 Vette dash split open
Got into my Vette today after work (it has been very hot here in FL!) and noticed a split in the dash right dead center of drivers side close to the edge of the oval. Its like the heat caused it to split and due to pressure that it had at this bend a small portion has peeled back. Unable to press it back into place (split is approximately 2 inches long) and was wondering if anyone else has had this happen. Nothing has ever been mounted or sat on the dash but the car is in direct sunlight all day. Is this something the dealer will replace or am I gonna have a battle on my hands over this defect? All replies welcomed! Thanks, Cheryl
Old Jul 7, 2010 | 09:19 PM
Just Buy It's Avatar
Just Buy It
Bring it back to the dealer and they do not need to know how long it sits in the sun. They will have to put a replacement in. Do NOT let them try to "fix" that. Let us know what happens.
Old Jul 7, 2010 | 09:24 PM
RedRider1's Avatar
RedRider1
I agree. They must fix it. I don't see why they wouldn't.
Old Jul 7, 2010 | 09:27 PM
VET4LES's Avatar
VET4LES
That's a good reason to use a window shade while the C6 is parked.
Old Jul 7, 2010 | 09:38 PM
cclive's Avatar
cclive
I've never seen a thread on it before so it probably is just a defect. Should be a warranty fix.
Old Jul 7, 2010 | 10:04 PM
CQRT's Avatar
CQRT
How old is the car? there's no info in your profile . . .
Just curious - -we get some sun out here too . . .
Old Jul 7, 2010 | 10:15 PM
numbrman's Avatar
numbrman
Ahh the life of a garage queen. We don't have problems like this
Yes, they will have to fix this under warranty. I would push hard to have the offending piece replaced. If they don't replace the piece with a new one, then make sure that you get it in writing that their "fix" comes with a lifetime warranty.
vetphan's Avatar
vetphan
Dude, I hate that happen but, really sitting in direct sun all day? How could you? I won't even take the vette out for drive in direct sun. I always wait till after 06:00 p. - I agree with the others, that sounds like a defect and should be covered.
Old Jul 7, 2010 | 10:18 PM
STEVE MC's Avatar
STEVE MC
I agree with the others that it should be covered.
I also agree that you should use a sun shade if your parked in direct sunlight all day.
Old Jul 7, 2010 | 10:44 PM
PatriotZ's Avatar
PatriotZ
Veteran: Marine Corps
From: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
Should be a warranty item....Hell I have to leave my Z out sometimes and the heat here hasn't messed the dash up....yet....knock on wood
Old Jul 7, 2010 | 10:50 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
Warranty.
All autos manufactured are tested to withstand ambient's way above the normal highs for any given area of the country as well as the lows. You have a claim. Period. No matter whether you didn't use a sun-shield, or didn't park in the shade cause it was sooooo hot......, yaaa daaa yadada......
Old Jul 7, 2010 | 10:53 PM
gbgary's Avatar
gbgary
my very non-garage queen '07 daily-driver sits in the sun every work day (without a sun shade) and doesn't have a hint of anything like this. in fact this is the first such thread i can ever remember reading.
Old Jul 8, 2010 | 12:08 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Probably wouldn't hurt to spray on some UV protection, like Aerospace 303, on the new dash, once they've installed it.
Old Jul 8, 2010 | 12:15 AM
NYC6's Avatar
NYC6
Originally Posted by wolfdogs
Warranty.
Makes perfect sense there.
Old Jul 8, 2010 | 12:18 AM
danl72's Avatar
danl72
They should cover it under warranty.
Old Jul 8, 2010 | 03:00 AM
AtHomeSoda's Avatar
AtHomeSoda
Default well..
I am sure they will fix... but get a shade and spray on some UV Protection... when the warrany runs out, it will be on you...
Old Jul 8, 2010 | 06:18 AM
plumqik's Avatar
plumqik
Thank you very much for all the replies~will call dealership today and see when I can get the Vette in to them and will keep you posted on the results. Also a sunshade is gonna be used from here on out!
To 2008 Vette dash split open
Old Jul 8, 2010 | 10:32 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Warranty.
Get this into the dealer and get a new dash installed while under warranty
Old Jul 8, 2010 | 10:38 AM
superdutymike27's Avatar
superdutymike27
[QUOTE=numbrman;1574626873]Ahh the life of a garage queen. We don't have problems like this
Good luck!!
Old Jul 8, 2010 | 11:35 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Someone said it...always use a windshield sun screen when you park your car in the direct sunlight. Also, I suggest you use 303 Aerospace Protectant which has UV filtering properties. There's no telling what the dealership might say as you haven't demonstrated there was a manufacturer's defect. That said it seems unusual a dashboard would split open on such a new car. Let us know what happens....good luck!
