Sun visor mirror hinge broken
Old Jul 19, 2010 | 08:26 AM
jfrazier's Avatar
jfrazier
Default Sun visor mirror hinge broken
The hinge on the mirror that is mounted on the passenger sun visor (on my C6) is broken. Is it necessary to replace the entire sun visor, or can the vanity mirror assembly be replaced? Is GM the only/best source?
Old Jul 19, 2010 | 08:53 AM
kev1949's Avatar
kev1949
The visor has to be replaced. If your car is out of warranty It's an expensive job. It's hard to believe gm is still using plastic hinged door. I,m on my 3rd one on my'08.
Old Jul 19, 2010 | 09:27 AM
Tonz-A-Fn's Avatar
Tonz-A-Fn
Same thing happened here. But, the car was still under warranty. Luckily for me NO questions were asked and it was taken care of.
Good luck. Little things can ruin a day.
Old Jul 19, 2010 | 09:28 AM
Brim's Avatar
Brim
Active Streak: 90 Days
I had the same problem and mine was replaced under warranty. By the way, last I checked the passenger visor was approx. $125 from gmpartshouse.
Old Jul 19, 2010 | 11:13 AM
cclive's Avatar
cclive
When you get the new one, put a drop of lube on the hinges to keep it from happening again.
Old Jul 21, 2010 | 09:27 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Yes, unfortunately you have to purchase a new one. If you need assistance with new, please let me know as I would be happy at the opportunity to earn your business.
Old Jul 22, 2010 | 12:02 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Somebody once posted that he put some "oil" on his hinges and they deteriorated. That sounds weird, I use a tiny dab of Dielectric Silicone Grease with no problems.
Old Sep 17, 2011 | 12:42 PM
gatorvette1's Avatar
gatorvette1
Cruising
Default C6 Sun visor with vanity mirror
I am looking for the best price on a driver's side sun visor with vanity mirror for my C6.
Old Sep 17, 2011 | 12:53 PM
Jimbeaux's Avatar
Jimbeaux
Me too.
Old Sep 17, 2011 | 07:09 PM
cmonkey713's Avatar
cmonkey713
I need to replace mine too. On Monday I think I will contact Corvette Recycling and see what they have.
Old Sep 17, 2011 | 07:40 PM
AmmoVet's Avatar
AmmoVet
My driver side is broken also.
Old Sep 17, 2011 | 08:02 PM
GREENTAHOE's Avatar
GREENTAHOE
Both of mine are broken. Once I get in there to start doing the radio bezel and center console cushion I'm going to remove them and cover up the holes.
Old Sep 17, 2011 | 08:59 PM
360Rocket's Avatar
360Rocket
St. Jude Donor '12-'13-'14
+1
Old Sep 17, 2011 | 10:46 PM
Gering's Avatar
Gering
Tolero Apto Victum
Originally Posted by 360Rocket
+1
+2
Old Sep 17, 2011 | 11:54 PM
cmonkey713's Avatar
cmonkey713
What is going on here? Several of us have broken hinges at the same time.
Old Sep 17, 2011 | 11:59 PM
AmmoVet's Avatar
AmmoVet
Kinda like that fuse block cover that was not available til everyone started having broken hinges, now there available. Maybe someone will get the idea that these should be available too. Funny how the market works, build it and they will purchase!
Old Nov 23, 2011 | 01:36 PM
masihman's Avatar
masihman
Mine just broke off today. Did you guys have any issues with it draining your battery? I don't need that issue as I have an 05 and finally got rid of that stupid priority start that was making things even worse. I just don't want to deal with a dead battery from this cheap visor.
To Sun visor mirror hinge broken
Old Nov 23, 2011 | 01:43 PM
WHYASK's Avatar
WHYASK
my driver side broke 2 weeks ago was quoted 245 for the visor with home link... ugggg
Old Nov 23, 2011 | 01:50 PM
Gering's Avatar
Gering
Tolero Apto Victum
No problems, I just had the electrical plugs pulled so there is no lights in the visor.
Old Dec 15, 2011 | 07:01 PM
Dusty13760's Avatar
Dusty13760
Mine have also broke.
I did a repair using velcro cut into small pieces on the corners.
Then I cut small strips mount them next to to broken hinge.
This works fine. You just have to pull the cover a little to get the velcro to release at the corners. At least I can still have the lights work and didn't have to spend 250 for 2 complete visors.
Anyone else have another method please let me know.
Dusty
