F55 Suspension Software Mod Request Input
F55 is also way better on rougher, pothole-ridden streets/roads.
I now have the F55 on my 2009, but I did add the Z51 sway bars to minimize body roll. My F55 rides a bit harder than the standard F55, but I still can feel the difference in modes. I leave it in Tour mode for most local driving, and go to Sport if the roads are smooth or if I drive aggressively. The modes are not dramatically different, especially in routine driving or on decent roads. There is a very obvious change in the suspension when the car is pushed or the roads are rough.
In past posts, I've seen the F55 Tour mode described as "Buick soft." I can only imagine that those posters have been driving over glass smooth roads because, even on Tour, the F55 is not a very soft ride.
Obviously, GM felt giving the driver some input in system control had advantages. I figure more from a marketing perspective.You seem reluctant to try the one thing (I know of) that most clearly demonstrates the difference between tour and sport mode. Be that as it may, everyone perceives things differently...it's possible you may never "feel" the difference between settings. Perhaps you're looking for something (in the system) that just isn't there. I don't know. I researched trying to modifying the F55 suspension to make it more 'competition oriented' for some time. I wish you all the best in your effort to have GM retro-mod the F55 suspension for you.
"...I can’t go in to great detail about all of the changes, but at the risk of being too general, I would say that the overall body control strategy has been greatly “tweaked” with the goal of streamlining the calibrations so that the vehicle engineer may more effectively change the performance of the vehicle. Also, alternate strategies have been investigated (and maybe even used in production!) to augment and/or improve wheel control and vehicle stability. Our team of software, hardware and vehicle engineers is always working hard to raise the bar on vehicle performance. The same could be said of our customers at the vehicle level."
I test drove a 09 Coupe before I bought my current vette with the F55 and had a hard time feeling the difference in the two modes.I do understand why F55 folks swap out the sway bars to the Z51 bars as the body lean was very pronounced in a hard sweeping corner. Maybe that's all that is needed to "tighten" it up but then I wonder why GM wasn't offering the Z51 bars as an option?
Tom
From what I heard this isn't speculation. According to the engineer I know, before the C6 was released he had his team put Z51 sway bars on his F55 test car at Nurburgring. He said there was a measurable improvement with the Z51 sway bars. Despite GM knowing the Z51 were an improvement over the base sway bars with the F55 suspension, GM marketing execs prevailed...they did not (then) want the F55 seen as any sort of a performance suspension that could compete with the attributes of the Z51 option or even the Z06. Obviously, this mindset is changing as evidenced by the release of the ZR1 with its more competition oriented MR suspension.
The system is frequently being improved. This is from one of the Delphi (now BWI Group) engineer's who developed the F55 suspension commenting on changes made with the 2008 model year:
See below
BTW, the Z51 tires wear out much faster but nobody talks about that cost of replacement. They are also much more prone to losing grip in cooler weather.
All that said, I think it would be nice if there was a bigger difference between the two settings. I'd like to know why GM decided on the settings as they are. It seems that they could have tuned it differently if they wanted to. Maybe there's a good (performance) reason that there isn't a greater difference or maybe it was cost or other considerations. Has anyone here ever seen an explanation?
All of those Corvette tires are expensive that's why I make sure mine last a long time.
I agree, an indicator light of some sort would be helpful.
Oh to get my hands on one of those bad boys
Strange I felt it before taking in car and now no longer after getting car back.
