Tire Life Expectancy?
Old Nov 8, 2010 | 05:36 AM
direct007's Avatar
direct007
Default Tire Life Expectancy?
I keep reading about the low tire life on the Z51 equipped vettes of 14,000 to 20,000 miles.
What has been your experience with F55 and Standard Suspension equipped cars with the factory equipped Goodyear Run Flats?
How many miles have you been able to drive before replacing your tires?
My vert with F55 and factory equipped Goodyear runflats has just over 30,000 miles and the tires seem fine.
Back in 1989, my convertible went about 44,000 miles before needing tires, but I know the Goodyear Run Flats are a different breed of tire.
Old Nov 8, 2010 | 06:59 AM
GOLD72's Avatar
GOLD72
It's not the Run Flat design that determines life. It's the rubber compound. The standard and F55 suspension cars get "all season" design tires and those tires don't get the softer and more sticky rubber that the Super Car tires get that go on the Z51 and Z06 cars. New tire tread depth might be greater also on the all season tires than the Super Car tires but someone else will have to confirm. The Super Car tires don't get as much tread depth so as to minimize tread block squirm on cornering. JMHO.
Old Nov 8, 2010 | 07:10 AM
CETA 256's Avatar
CETA 256
Just replaced mine at 20k miles with the F55 suspension. I went to Michelin AS, but just installed Friday and haven't driven it except home Friday.
Old Nov 8, 2010 | 07:15 AM
enzodude's Avatar
enzodude
Corvette is a sports car and a muscle car. Some people will get 50k out of the stock tires driving like women. Some will get 15k driving like morons. I guess I am on the moron side of things.
Old Nov 8, 2010 | 08:10 AM
Joe C's Avatar
Joe C
correct - the tires differ from the base or f55 to the z51 equipped cars. the tread depth on the base/f55 cars is 10/32 (f) and 11/32 (r) and z51 cars is 9/32 (f&r). the UTQG treadwear rating is 300 AA A for base/f55 and 220 AA A for the z51 cars. i'm thinking the actual usable tread is 2/32 less than rating due to wear indicators. i have around 14K on my 2008 (z51) coupe, and i still have an average of about 6/32, and yes, I DRIVE LIKE A PU$$Y - well, most of the time . with a little luck, i'll get 25K out of my OE tires, then it's on to a set of michelin ps2 a/s.
Old Nov 8, 2010 | 08:33 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
a slight exagg re the 50K miles on Corvette tires of any kind, but as to the moron thing, can't speak to that concern. I can say some of the other comments re softer compound/different compound are correct. also, alignment, air pressure and a lot of other factors. just remember: an alignment in January (or any month) is not a set-it-and-forget-it thing. it can go out in Feb., or June. depending on the tire and how you drive that can reduce your tire life in a month of driving. so can the wrong tire pressure over a period of just a few weeks.
Old Nov 8, 2010 | 08:42 AM
weathermaker's Avatar
weathermaker
38,000 miles on my base 05 vert; Still not down to the wear bars yet. Will replace in the spring with Mich, a/s.
Old Nov 8, 2010 | 09:13 AM
BRCC's Avatar
BRCC
I was told that alignment from the factory on GS's and Z06's is a little aggressive, however, those not tracking their cars should consider a realignment that would take it back to a less aggressive stance and help mileage factors on the tires if driven normally. Search other post on alignment.
Old Nov 8, 2010 | 09:58 AM
Vette_DD's Avatar
Vette_DD
The front tires on my F55 06 were down to the wear bars at 32K. Rear tires still had plenty of tread.
Old Nov 8, 2010 | 10:43 AM
ducvw2004's Avatar
ducvw2004
I'm at the wear indicators on the front a just a bit more tread left at the rear. This is at 13,000 miles.
Old Nov 8, 2010 | 11:40 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The base and F55 tires are not really All Season, although they work a lot better around freezing than the Z51 Supercar tires.
Goodyear made, maybe still does, a genuine All Season runflat for the C6. It looked exactly like the Base/F55 tire except for some of the printing on the sidewall, but different tread compound for cold temp use. Also, rated to "only" 168 mph. I had a set and they worked very well in cold temps and in snow up to 4".
Of course, driving style is the biggest factor in tire life. I've gotten about 20k miles from each of my three sets of Supercar tires. Lots of guys wear them out in 10k-15k, but a Grandpa in our club got 30k from his Supercar fronts and still has over 2/32" on the rears at about 35k.
Old Nov 8, 2010 | 12:44 PM
LS WON's Avatar
LS WON
On 2005 F-55 at 37,000+ miles I'm still on original tires (Battery too)with lots of life left. I do notice the front tires seem to be wearing faster than the rears.
Old Nov 8, 2010 | 12:49 PM
fleetc's Avatar
fleetc
23K on my 08 F55. Will probably get at least 30K if they don't dry rot on me.
Old Nov 8, 2010 | 01:43 PM
laconiajack's Avatar
laconiajack
20K on my '09 F55 but still had at least 3/32s on front, 6/32s on rear. Went to Michelin A/S ZPs and love them.
Old Nov 8, 2010 | 02:20 PM
Eritosthenes's Avatar
Eritosthenes
With modified camber settings (-0.1 degree), non-tracked Z51 and Z06 owners could probably expect to get 20-22K miles from their GY SC runflats. Base and F55 owners could probably expect to get 28-30K from their GY GS-2 runflats.
Then there are the garage queens who will have to replace their tires due to age and dry rot with fewer than 10K.
Old Nov 8, 2010 | 06:01 PM
lastcowboy's Avatar
lastcowboy
my 09 f55 came with s.c. tires..........
Old Nov 8, 2010 | 06:16 PM
joec's Avatar
joec
I had 12k on mine before I got rid of them.. Biggest POS tires ever.. Got Mich's All season HP Runflats and never looked back.. Great tires!
/joe
To Tire Life Expectancy?
Old Nov 8, 2010 | 07:17 PM
Dans C6's Avatar
Dans C6
14,xxx miles on my 05 Z51 factory supercar tires. Still have plenty of room left.
Old Nov 8, 2010 | 09:07 PM
phileaglesfan's Avatar
phileaglesfan
You don't buy a sports car (or a lot of sports sedans) if you are worried about tire wear. 15k is nothing for a max performance tire. A Lotus will eat up their performance tires at about 5k and that car is only about a ton.
Old Nov 8, 2010 | 09:50 PM
Convair580's Avatar
Convair580
I have an '07, Z51, and got 21k on the oem tires, which included running the car on a NASCAR track, plus a short LeMans type course for a day. I think I did well. I now have Mich. PS 2's with 15k on them, still holding on well. (total miles on car 36.5k).
I like the PS 2 a bit better.
