Jump Starting a Vette
Old Dec 20, 2010 | 09:43 AM
jborg's Avatar
jborg
Default Jump Starting a Vette
Ok, I parked my 09 and let it sit a few weeks. Yesterday I added some Stabil and tried to start it and ...nothing. battery was dead. Its been in the 20s here the last couple weeks but the battery shouldnt have been dead (about 3 volts) should it?
Anyway I hooked it up to a charger for an hour and it started. I noticed instructions to connect jumper cables to other areas other than the battery. Is there a reason for this? Why not connect directly to the battery?
Old Dec 20, 2010 | 09:52 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I think why they tell you to connect the negative cable to a metal part of the car (not the negative battery terminal) is that it reduces the risk igniting hydrogen gas coming off the battery. Most often (but not always) I hookup the jumper cables directly to the battery terminals. I'm not saying that's the recommended way but I've never had a problem.
PS I think the C6 also has a 'remote jumping terminal' away from the battery in the fuse compartment....it's probably better to use this.
Old Dec 20, 2010 | 10:31 AM
Eritosthenes's Avatar
Eritosthenes
When parked "a few weeks" nearly all C6s will have dead batteries. After you shut your car down, there are still a lot of electronic subsystems that continue to draw a few milliamps here and there. Go out *NOW* and buy a CTEK or Battery Tender for your car so your battery won't be dead next time. Don't use your battery charger for this -- you'll end up cooking your battery.
Old Dec 20, 2010 | 10:50 AM
Marc V.'s Avatar
Marc V.
The proper way to jump start ANY car is to connect the negative cable to a good engine ground, and not the negative battery cable of the dead battery. It reduces the chances of arcing and the battery exploding from hydrogen gas in the battery.
I leave my 07 coupe for months and never had a problem starting it. Make sure that your battery is fully charged (and not just driving it around. That will not properly recharge a deeply discharged battery) and have the battery tested. It should not go dead after a few weeks.
Old Dec 20, 2010 | 11:15 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
C6s are battery pigs, always something taking a little here and there aand it sure adds up. Some people have little or no problems others have plenty.
On my 2ed C6 now and after a couple weeks you have a good chance of a low battery. Get a TENDER and use it anytime the cars sits for more than a few days.
As far as hooking up I ALWAYS go direct to the batteries, I prefer the shortest possible hook up I can get! If your carefull and hook up right +_+ -_-you will be ok. Have worked on cars since early 60s and been around a lot of batteries!
Old Dec 20, 2010 | 04:07 PM
Marc V.'s Avatar
Marc V.
That's not always true. I've worked at a dealership for over 20 years now and have seen my share of exploding batteries. It's not pretty if it happens to blow up in your face. I've seen it several times, luckily never to me.
Why not just err to the side of caution?
Old Dec 20, 2010 | 04:58 PM
JoesC5's Avatar
JoesC5
My Z06 has the rear mounted battery and I always connect my float charger to the (+) lug at the underhood fusebox and a grounding point on the frame below the fusebox. I have never had a battery explode on any car I've owned over the past 50 years, but why start now.
To Jump Starting a Vette
