Lowering Issues
Old Dec 26, 2010 | 11:36 AM
teenVette's Avatar
teenVette
Veteran: National Guard
Default Lowering Issues
I got my corvette lowered with a set of lowering bolts. On my passenger side in the rear there is grease that is getting all over my rims while I am driving. That is also the only corner that is having issued bottoming out and the tire is eating up my inner fender. Before I take it back to the shop that did it. What could the issue be? Anyone else run into this problem? My driver side in the rear is just as low, it does not bottom out/scrape in the inner fender, and has no grease at all on the rims. I hope I explained this correctly. Any help would be greatly appreciated.
Old Dec 26, 2010 | 01:28 PM
in2fun's Avatar
in2fun
Sounds like to me you may have had a shock go out. Is there grease on the shock also. I just replaced the shocks on a friends car that was bottoming out on one side. When we took the old shock off it had grease on it. If you push down on the passengers rear side of the car... Dose it feel like it has less tension then the other side?
Because you haven't said anything about your brakes, I'm going to assume that the brakes are still working fine.. because another reason you may have oil on the rim is because the brake caliper cylinders may be leaking or you have a loose or broken brake line.
I would take a close look at the shock and see if you can tell if the oil is coming from there.
Old Dec 26, 2010 | 01:35 PM
Deceptikon's Avatar
Deceptikon
Im thinking of lowering mine as well. Please let us know what the issue was
Old Dec 26, 2010 | 01:39 PM
timd38's Avatar
timd38
Could also be a wheel bearing.
Old Dec 26, 2010 | 02:17 PM
98ramair's Avatar
98ramair
I live right up the road from ya in Macon. If you need some help trying to figure it out, I have a garage with all the tools we need. I have lowered all 3 of my C6's and can help you find out the problem. Let me know if you need a hand.......don't have a lift but gotta air compressor and all the tools we will need. PM me if ya need a hand! If your shock is leaking, that's an easy part to remove/replace.
Andy
Old Dec 26, 2010 | 02:26 PM
teenVette's Avatar
teenVette
Andy
I was thinking about replacing the shocks anyway because it is real low, the car is in my parents garage and will be locked up until April when I get home. If I was in Bonaire at this moment Andy I would be at your house with the quickness, but my car is in Fayetteville, NC at the moment. Does anyone have any suggestions on some shocks for a lowered corvette?
Old Dec 26, 2010 | 02:27 PM
teenVette's Avatar
teenVette
Thanks for your input, my brakes are working normally right now, its just that one side that is acting up with the grease on the rims after I drive it. I'll look into both the shocks and wheel bearings when I get home in April
Old Dec 26, 2010 | 04:54 PM
Bill Dearborn's Avatar
Bill Dearborn
Is it grease or oil? Shocks have oil in them. CV joints have grease. When the boot on a CV joint goes bad you get grease all over the place.
Bill
Old Dec 26, 2010 | 05:02 PM
timd38's Avatar
timd38
Bill
That's my bet.
Old Dec 26, 2010 | 05:07 PM
teenVette's Avatar
teenVette
Bill
It's not oil. If I'm not mistaken when I was cleaning off the rims yesterday it was thick and darker green. Don't quote me exactly on the color though.
Old Dec 26, 2010 | 05:09 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
just a q.; not trying to jack the thread: does lowering cause more stress on the CV joint/bearing?
Old Dec 26, 2010 | 05:17 PM
teenVette's Avatar
teenVette
You're not jacking the thread, that's a good question
Old Dec 26, 2010 | 05:27 PM
timd38's Avatar
timd38
Mine would have gone bad a long time ago if it does.
Old Dec 26, 2010 | 06:12 PM
BEZ06's Avatar
BEZ06
I see in your profile that you have a Z51, which has zerk fittings to lube the ball joints on the toe adjustment links.
Perhaps the shop saw those lube fittings and decided to shoot some new grease in there for you.
It could definitely ooze out and get on your wheels.
Bob
Old Dec 26, 2010 | 06:23 PM
laconiajack's Avatar
laconiajack
Since on the C6 your engine/transmission and diffential are all mounted on the same frame, lowering shouldn't effect drive line constant velocity joint life, but those connecting the differential to the rear drive wheels through the interconecting half shafts will likely experience shorter life as will the rear wheel bearings and seals. Front and rear suspension travel will also be reduced as well as ground clearance over speed bumps, or such things as elevated railroad roadways adjacent automotive roadways, underground parking garage approch and departure angles, etc., etc. The Corvette as it comes from the factory is a low as the engineers thought practicle. These automotive engineers take into account civil engineering standards, test track results, etc. Anytime you think you know more than these engineers and alter the car's ride height you are setting yourself up for problems.
Old Dec 26, 2010 | 06:29 PM
Boomer111's Avatar
Boomer111
May not be the fun answer but it is the real one.
Old Dec 26, 2010 | 08:00 PM
teenVette's Avatar
teenVette
Yeah it is the truth, but I'm hard headed
To Lowering Issues
Old Dec 26, 2010 | 09:58 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Bill
BINGO! My money's on the CV boot.
Old Dec 26, 2010 | 11:36 PM
98ramair's Avatar
98ramair
I'm with you guys on that one. Maybe the guys that changed out the bolts accidentally tore his cv boot. God willing, I'll be around when you get back to Bonaire so hit me up if you haven't figured it out by then. G/L to ya!!
Old Dec 27, 2010 | 08:28 AM
teenVette's Avatar
teenVette
Thanks everyone. I'll be flying back to Afghan tomorrow so the vette is locked up in my parent's garage until my next break in April. But I'll be sure to keep everyone updated on what it is once I get back. Thanks again
