Super Charge
Old Dec 29, 2010 | 01:17 PM
shelleygraham's Avatar
shelleygraham
Default Super Charge
I have a 2010 GS Convertible with 436 HP . I am thinking of modifying it with a super charger system. First , what would be the best system, how much HP would I get and what the approximate cost including labor be. Plus I realize I would have to replace the hood right ? Thanks. I like the look of the window on the hood I was looking to replace my hood anyway. How about 638 like a ZR1 ?
Old Dec 29, 2010 | 01:19 PM
not08crmanymore's Avatar
not08crmanymore
All kinds out there.EDELBROCK is the newest I think,theres VORTECH and another one I forget the name of .They are all good,just depends on what type you want.ROOTS,centrifugal..etc.Probably 10 grand or so is a safe bet.AT LEAST 120 OR SO BUMP.
Old Dec 29, 2010 | 01:24 PM
MikeSVT04's Avatar
MikeSVT04
HP is dependent on how much boost you want to run...on a typical build your looking at around 550-600rwhp. you will prolly need a BAP(fuel) and tune to goo with it. and your set. I would say around 7k installed and tuned. If you do it yourself you could prolly do it for 5k. This isn't for edelbrock but a kit like A&A.
Old Dec 29, 2010 | 01:38 PM
DaveC6ZHZ's Avatar
DaveC6ZHZ
If you don't want the expense of replacing the hood or the stock fuel pump, Edelbrock E Force Supercharger #1590 makes about 554 hp at flywheel; kit costs about $6,500 to $6,750 depending on where you buy it, plus installation cost which varies by installer (install usually cheaper if you buy the SC kit from them).
Old Dec 29, 2010 | 02:19 PM
Tom@Zip's Avatar
Tom@Zip
Platinum Supporting Vendor
C6 Corvette Superchargers
We offer a couple of different Superchargers for the LS3 engine, both the Edelbrock and the Vortech do not require a new hood.
If you have any questions feel free to give me a call.
Tom 1-800-962-9632 ext 240.
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Old Dec 29, 2010 | 02:40 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Depends on your ultimate goals, if you want around 500 rwhp or so the Edlebrock is a very nice unit. Now if you want a blower to really be there for growth get the A&A unit I had one on my C5 and loved it. When I get another Vette for boost it will either have the A&A kit or TT
Old Dec 29, 2010 | 02:56 PM
shelleygraham
Do you know someone in your area. I was born and raised in Bergen County N.J.
Old Dec 29, 2010 | 02:59 PM
MARSC6's Avatar
MARSC6
http://eastcoastsupercharging.com/SuperChargers.html
Old Dec 29, 2010 | 03:12 PM
BevoZ06's Avatar
BevoZ06
St. Jude Donor '11-'12
Be sure you know what effect, if any, a supercharger will have on your factory drivetrain warranty.
Old Dec 29, 2010 | 03:19 PM
b4i4getit's Avatar
b4i4getit
Don't do it. Unless you can afford to purchase a new engine.
Old Dec 29, 2010 | 03:50 PM
Marc V.'s Avatar
Marc V.
I know these guys, and they are 1st class.
Old Dec 29, 2010 | 03:56 PM
MARSC6's Avatar
MARSC6
3 years with the ECS kit and the original engine is just fine.
Old Dec 29, 2010 | 04:54 PM
yellowgrandsport's Avatar
yellowgrandsport
A friend of mine just recently had an Edelbrock kit installed and tuned at Behe Performance in Eldersburg Md. They do a lot of supercharger, and tuning work. They are authorized Edelbrock, Magnuson, Vortec, and Procharger installers and tunners. They also do a lot of car from New Jersey for SCCA. There are pics. and dyno results on there facebook page. He did not have to change his hood or fuel pump.
Old Dec 29, 2010 | 06:42 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
To the OP:
If you are going to do it, do it right. I'd PM Peter Pan for details. Lot more to supercharging a Vette than slapping it on. I recall a very revealing conversation I had with Peter when I thought about putting a S/C on my old C5 a couple of years back. Thanks Brother
Old Dec 29, 2010 | 06:50 PM
saplumr's Avatar
saplumr
Really? I've had my blower on for almost 6 years. 10 psi....same car, same motor.
Old Dec 29, 2010 | 06:54 PM
LBear's Avatar
LBear
If you want to do a FI correctly, you have to get a forged bottom end, different cam, drop the compression ratio, change the pistons to forged aluminum, get a forged crank, better piston rings and up the oiling system.
If all it took was throwing on a supercharger onto a LS3, then GM wasted a million dollars in engineering the LS9.
Do it right, you will have a reliable setup. Cut corners, you will be left with a bomb and you will be stranded on the road. Or better yet, just buy a ZR1 and save yourself the headaches.
Old Dec 29, 2010 | 06:57 PM
LBear's Avatar
LBear
Stock bottom end or forged?
Take a trip to the FI forum, there are 5 horror stories for every good one. If one wants to do FI on a LS3, more power to them. I just don't think it is a nice thing to tell people that a LS3 in stock form is engineered for FI, it's not.
Cast pistons - High compression - cast crank - Cam designed for NA - Piston rings not designed for FI - rod strength is questionable with FI
To Super Charge
Old Dec 29, 2010 | 07:29 PM
MARSC6's Avatar
MARSC6
I check the FI section quite a bit and see very few failures. The engines aren't designed for FI but they do hold up well.
Old Dec 29, 2010 | 07:32 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Originally Posted by Chemdawg99
To the OP:
Thanks for the kudos, and I love boost and what is involved if you want to talk pm me and I will send you my cell and we can chat. Oh I just had a little HP in my C5
Old Dec 29, 2010 | 07:38 PM
saplumr's Avatar
saplumr
Completely stock. You don't need all the things you mention unless you plan to go above 7-800 rwhp. The people you speak of probably didn't have the correct installer working on the car. I thought about the forged block but when Chris at ECS told me they have been intentionally trying to break a LS2 under boost but haven't done it yet, it was all I needed to hear. I suspect they are more experienced in such matters. You can believe what you wish but I wouldn't think dispersing incorrect info would be wise.
