1-4 shift
Old Apr 5, 2011 | 11:12 AM
steve burns's Avatar
steve burns
Default 1-4 shift
I know the instrument panel shows when to shift from 1-4 at low speed.
But does anyone do this on a regular basis? Will it hurt the transmission at all. Fuel economy goes up if I switch from 1-4, and find I dont really need second and third gear.
So what does everyone generally do?
thanks!
Old Apr 5, 2011 | 11:14 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I have CAGS tuned out.
Elmer
Old Apr 5, 2011 | 11:18 AM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
Honestly, I have probably seen that light maybe five times in six months of ownership. Just shift a little sooner. Or, give it a little gas.
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
On my fourth ride with the skip shift and I totally ignore it. If you drive reasonably it will never come into play. I realize that light is on the instrument panel but I never see it. Been driving stick since early 1960s and other than a tach (used for spirited driving) I shift by instinct!
Old Apr 5, 2011 | 11:19 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I usually start off in 2nd, then onto 3rd, then 5th then 6th.
Old Apr 5, 2011 | 11:23 AM
JoesC5's Avatar
JoesC5
I installed the $20 CAGS eliminator and just drive like I've driven every stick shift car I've driven since 1956. I decide when I want to shift, and what gear I want to shift to, not what the car thinks I should. If I had wanted the car to do my thinking for me, I would have purchsed the auto transmission option. But if I had purchased the auto transmission option, I would not be driving a Z06.
Old Apr 5, 2011 | 11:25 AM
chris@sfcc's Avatar
0chris@sfcc
Former Vendor
thanks!
To answer the actual question posed- no the 1->4 shift won't hurt the transmission in any way. You could just as easily start in 2nd and shift to 4th without an issue as well.
Old Apr 5, 2011 | 11:28 AM
SKP's Avatar
SKP
Cruising
I installed a CAGS eliminator and shift when I want to.
Old Apr 5, 2011 | 11:40 AM
6spdC6's Avatar
6spdC6
Had a CAGS eliminator in my first of 4 cars with a 6spd. Found that if you drive right you do not need that device. My last 3 Vettes no eliminator needed and I shift when I want to.
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Just shift a little later
Old Apr 5, 2011 | 11:48 AM
LionGS's Avatar
LionGS
Had the car for almost a year, think I saw the 1->4 light 3 to 5 times the fist week, have not seen it since.
A little gas is all it takes.
Old Apr 5, 2011 | 12:00 PM
rchbn's Avatar
rchbn
If I'm in traffic I just use 2,4, and 6 if going above 40 other wise I leave it in 4th at slower speeds.
Old Apr 5, 2011 | 12:12 PM
Ed32's Avatar
Ed32
For certain reason I've heard about ppl complaining and getting a kit to get rid of it. I have an ls3 and it doesnt bother me, skip gears at ur own discretion, what it's not good is the jerky motion when u shift to 2nd with low rpm's.
Ed
Old Apr 5, 2011 | 12:23 PM
C7Joy's Avatar
C7Joy
I just accelerate hard enough that the CAGS almost never comes into play. I don't even think about it anymore. (Won't hurt the tranny to do a 1-4.)
Old Apr 5, 2011 | 12:34 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Everyone has their own style of driving but IMO self-inflicted skip-shifting isn't a good practice to follow. With 'normal' driving the skip-shift feature should hardly ever engage. That said I think its wise to have the skip-shift feature eliminated. It's an annoyance at best and a hazard at worst. These are some of my 'rules' for manual transmission use:
You upshift and down-shift sequentially through the gears...you never skip-shift.
5th and 6th gears are not used for in-town driving...they're overdrive gears used solely for extended, highway cruising.
You never place the transmission in neutral and coast to a stop.
When stopping for a red light don't put the transmission in neutral....keep the transmission in first gear.
Old Apr 5, 2011 | 01:32 PM
Don LT-1's Avatar
Don LT-1
I always find it hard to believe that any corvette owner would be concerned with gas mileage. That's not why you buy the car.
Old Apr 5, 2011 | 01:41 PM
LionGS's Avatar
LionGS
I am interested in this. Do you say this for safety reasons or mechanical reasons?
To 1-4 shift
Old Apr 5, 2011 | 02:08 PM
Boz86's Avatar
Boz86
Old Apr 5, 2011 | 02:21 PM
jackcasa's Avatar
jackcasa
Originally Posted by eboggs_jkvl
1-2-3-4-5-6
Elmer
The CAGS delete was the first mod I made to my '98 C5 and '05 C6.
Old Apr 5, 2011 | 02:28 PM
diyguy's Avatar
diyguy
Needs an explanation behind this method???
I do both all the time and have for years...
