Auto trans temp.
Old Apr 23, 2011 | 06:53 PM
MuscleVette's Avatar
MuscleVette
That's a good way to go. If the B&M will do a good job and brings the temps down (right now I find them at about 200-210 pretty often), then I'll try to do it quickly. Anyone know of a good Corvette mechanic in Austin/Cedar Park? I'm not really very good mechanically
Old Apr 23, 2011 | 07:28 PM
Ketchum's Avatar
Ketchum
What size cooler is recommended ?
Old Apr 23, 2011 | 07:30 PM
MuscleVette
Which B&M cooler did you go with? I see a few different ones.
Old Apr 23, 2011 | 07:35 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
does anyone know the designed/engineered* operating temperature for the transmission?
*defined: optimal range
Old Apr 23, 2011 | 07:36 PM
MuscleVette
I've seen posts that it goes up to 270.
Old Apr 24, 2011 | 12:05 AM
ReosLS2's Avatar
ReosLS2
I have an '05 that now runs about 30* hotter after the GM dealership did a flush & fill using Dexron v vs. Dexron lll ( lll no longer being used).The tech called GM engineering and they said as long as it does'nt go 20-30 degrees above the engine temp it's okay (they did'nt specify coolant temp or oil temp).My temp was about 172 before the change and 214 after.That's at complete warm-up around town.but it is'nt even summer so I know mines gonna go above 214!
Old Apr 24, 2011 | 09:37 AM
theofel's Avatar
theofel
St. Jude Donor '10-'13
I don't know the model #. I will call HorsePower Sales and ask the model # and size specs on Monday. HPS does all my work and I rely on them for all my installations and tunes. I know they also bought some fittings that didn't come with the kit. I will also try to get those part #'s for you on Monday. MIKE
Old Apr 24, 2011 | 09:41 AM
theofel's Avatar
theofel
If the Tranny temps are 270 degrees in normal conditions..thats a formula for disaster! In road racing it's understandable...but for driving around town totally BAD.
Old Apr 24, 2011 | 09:53 AM
Mad*Max's Avatar
Mad*Max
I've noticed that the temps get much higher when doing stop and go driving.
Old Apr 24, 2011 | 09:58 AM
theofel's Avatar
theofel
Your torque converter is working harder in stop and go mode. More slippage=more heat.Very normal.
Old Apr 24, 2011 | 12:25 PM
fnsblum's Avatar
fnsblum
You can over cool the trans oil. It is a hydraulic system and needs a minimum temp for proper operation. I don't have a clue exactly what that is on my A6 but I suspect it is approximately 120-140. At least that is what a lot of industrial systems I have worked on call for. Why do you suppose the primary cooler is in the radiator? GM wants the trans oil temp to come up with the engine coolant/oil temp. My Duramax won't lock the converter up until the coolant gets to approximately 165. Under load towing my 5th wheel trans temp would mirror the coolant temp which was always at 210. Too big a trans cooler is bad news in cold weather. If you are racing you may need a secondary cooler. MHO is it would be over kill for the rest of us. Later! Frank
Old Apr 24, 2011 | 12:47 PM
Ketchum's Avatar
Ketchum
What trans temp do you see on your D/Max normal driving and then towing?
Old Apr 24, 2011 | 01:05 PM
  #33
Rogers 07's Avatar
Rogers 07
Food for thought, Lets just suppose the engineers who designed the C6 cooling system knew what they were doing so.... OHHH I dont know, the cars power train could be warrented for 5 years and 100000 miles !!!! Unless your really flogging it at the track, driving in 110+ degree temps or towing with your Vette (Your not are you?) Then the cooling design of the radiator and A6 trans cooler is going to function as it should with out any additionial help. Gauge readings will go up an down with different driving conditions, these are normal and expected operating conditions for the car. JMHO !!
Old Apr 24, 2011 | 01:14 PM
  #34
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I'd like to also know.
Saying that the caution range begins at 230', and redline is 270', doesn't tell us much about the ideal temperature.
I'm guessing that desired operating temp would be about 180.
The problem with an additional cooler is that during normal highway driving, you may find yourself running something like 150'
I'm surprised the tranny stays as cool as it does. With water temps near 200' or more, the fact that the trans is often below 200' leaves me scratching my head.
Old Apr 24, 2011 | 01:45 PM
  #35
Ketchum's Avatar
Ketchum
Most of the time even in summer heat my Dodge truck trans. runs under 160 unless working real hard. As I stated before I've never seen 200 even towing 4500 lbs. and from what I've read elsewhere 200 degrees is right at the getting in a questionable heat range. Curious to what that D/Max Allison runs out. Your right ROGERS 07 that obviously its in the design. I was just really alarmned to see 210 in mild traffic. I almost pulled over to shut it off and let it cool down. I thought DARN got a stopped up trans cooler or something.
Old Apr 24, 2011 | 01:59 PM
  #36
MuscleVette
Not that my tranny temps go that high, but that GM lists that as a max.
Old Apr 24, 2011 | 02:07 PM
  #37
MuscleVette
I would agree. Except here it does get to 110 (Austin, Texas) and the tranny gets hot pretty quick.
To Auto trans temp.
Old Apr 24, 2011 | 05:15 PM
  #38
HOXXOH's Avatar
HOXXOH
When the converter locks up, there is not much else generating heat. Plus the lines to/from the radiator and the trans case are also in a cooler airstream.
The quickest way to drop temps is to drive at an uninterupted 50 MPH. High airflow with converter locked in 6th and a low RPM will get it done in a hurry. Turning on the heater to 90* with full fans is an additional help.
Old Apr 24, 2011 | 05:56 PM
  #39
Rogers 07's Avatar
Rogers 07
I hear you on that one !!!!
Old Apr 25, 2011 | 08:11 AM
  #40
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I'm seeing about 180-190 in moderate traffic here in 80 degree weather.
