Auto trans temp.
Old Apr 19, 2011 | 09:25 AM
Ketchum's Avatar
Ketchum
Default Auto trans temp.
What kind of temps are you all seeing with the 06 up 6 speed automatic ? Street driving.
Old Apr 19, 2011 | 09:47 AM
AtomicLS3's Avatar
AtomicLS3
In the mid 180's after doing some pulls around town.
Old Apr 19, 2011 | 10:40 AM
ParkRat's Avatar
ParkRat
Usually around 160 - 180. It hits 200 here and there.
Old Apr 19, 2011 | 10:46 AM
beav626's Avatar
beav626
Old Apr 19, 2011 | 12:14 PM
Ketchum's Avatar
Ketchum
Wow. I noticed mine at those temps. I was shocked. Seems awful high. My 1500 Dodge truck with Hemi hardly will hit 180 towing 4500 lbs. not towing its 140 to 160 at most.
Old Apr 19, 2011 | 12:27 PM
cclive's Avatar
cclive
Don't be shocked...normal and fairly cool. A general rule was that anything under 200 on a regular basis was considered good. Many older trans ran considerably higher.
A truck made for towing with a big cooler on it can get lower, which is fine.
Old Apr 19, 2011 | 01:28 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
2006 and 2009 Corvettes:
Typically, 160 on the highway but takes a while to get up there.
180-200 in most traffic.
Creeping along for an hour in heavy traffic on a 85' day, 217' max.
Book says redline is 270', let it cool below to 230' if possible.
So, cooler is better but I don't get excited at anything below 230'.
Old Apr 19, 2011 | 01:35 PM
blown34's Avatar
blown34
Last summer I saw temps of 250, but then I'm convinced my fluid level was more than two quarts low. When I did a tranny service. I put in almost three quarts more than I took out. Now its running in the 180 range, but then its much cooler now.
Old Apr 19, 2011 | 02:38 PM
Dendk's Avatar
Dendk
229 in slow traffic for three miles straight with hardly any movement temps in the high 80's....normally runs in the 160 s
Old Apr 19, 2011 | 02:51 PM
cclive's Avatar
cclive
A big part of the internal heat in an auto trans is generated by the torque converter and its shearing effect on the fluid. Newer auto trans have a lockup clutch in the converter which minimizes this when it is locked. Slow traffic, stop and go are times when the converter is not locked and is producing maximum heat. Once on the highway and the speed stabilizes, the converter locks and the generated heat goes down alot.
Old Apr 22, 2011 | 06:49 PM
MuscleVette's Avatar
MuscleVette
I've wondered since both of ours hit about 210 here, but its been at 85-95.
Old Apr 22, 2011 | 07:11 PM
Ketchum's Avatar
Ketchum
I'm no expert on this subject and never gave it a lot of thought. Even in the few automatic trans vehicles that had any H.P. or I towed heavy with. Until now. My Dodge truck shows trans temp and the Corvette. I have been on truck forums and read info from time to time on trans temps,coolers and where to mount a temp sender for auto trans. temp gauges. My Dodge truck has never gotten over 185 in summer heat towing 4500 lbs. From what all I have ever read I thought over 200 is not a good thing. Yet G.M. obviously has these units cooking! Wonder what a engineers take is on this and why is so hot OK with these auto 6 speeds.
Old Apr 22, 2011 | 07:58 PM
D2 Vette's Avatar
D2 Vette
My 2005 Z51 A4 consistently hits 230-250 in Phoenix during the summer at freeway speeds. But then it's 110-115 degrees. Car has 95,000 miles with no issues.
Old Apr 22, 2011 | 09:08 PM
theofel's Avatar
theofel
St. Jude Donor '10-'13
I just got my A6 rebuilt by Century Transmission and the tranny temps were running between 175 and 217 for about two days until HorsePower Sales added a B&M tranny cooler and it now runs between 146 and 175 on 85-90 degree days. If your worried about tranny temps...just add the tranny cooler..a great insurance investment. If your adding a higher stall converter get the tranny cooler! Hot tranny temps are the main factor for A4 and A6 failures.
Old Apr 22, 2011 | 09:14 PM
MuscleVette
Would it be better to do the B&M tranny cooler, or get an all in one unit: http://www.westcoastcorvette.com/p-3...c-non-z51.aspx
Old Apr 22, 2011 | 09:26 PM
TLTONEY's Avatar
TLTONEY
Old Apr 23, 2011 | 12:14 AM
Ketchum's Avatar
Ketchum
I'd run a separate unit. Much less money and install is easy etc.
To Auto trans temp.
Old Apr 23, 2011 | 06:28 PM
theofel's Avatar
theofel
The B&M tranny cooler works great....The new radiater with a built in cooler in addition to the B&M cooler would be a great set up if you use that radiator with the internal cooler to cool your oil instead of the tranny and use the B&M cooler for cooling tranny The combination of both would be ideal.
Old Apr 23, 2011 | 06:42 PM
MuscleVette
The radiator shown though was supposed to be a tranny cooler and engine cooler, so if I did that why would I add on another tranny cooler? Obviously just doing the tranny cooler is much cheaper and is kind of the way I'm thinking of going right now. $60 vs $1000.... unless there its really worth it. I paid $xxxxxx for my cars...the least I can do is give them what they need.
Old Apr 23, 2011 | 06:51 PM
theofel's Avatar
theofel
The B&M cooler could run in conjuction with the radiator/cooler or independently. We chose to install it as a stand alone. The cost was not the main factor but I did save some money on this method. This does not diminish the cooling capabilities of the stock radiator just enhances its capabilities. Use the extra $ for a good tune.
