Lug Nut Socket
Old Apr 28, 2011 | 06:18 PM
dbevins's Avatar
dbevins
Default Lug Nut Socket
What's the best lug nut socket out there to protect the chrome wheel lug nuts?
Old Apr 28, 2011 | 06:24 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I don't think there is a best one. You need formal contact on each edge with a socket in order to tighten or losen the bolts, so keeping them pretty isn't really going to work assuming you want the bolts torqued properly. Someone else might have a better idea but I've never seen anything in a tire shop yet.
Old Apr 28, 2011 | 06:33 PM
RicK T's Avatar
RicK T
You might consider getting some good Gorilla brand lug nuts and a good 6-point socket. Just the common suggestion.
Anyway, here's an older thread and I put in 2 links to older threads one of which talks about non marring socket options:
http://forums.corvetteforum.com/c6-c...-question.html
jimmie jam's Avatar
jimmie jam
i picked up a very cheap set (4) of deep metric sockets with nylon linings. made for this very reason. where? of all places the Harbor Freight store. $12 i think. there is your solution.
Old Apr 28, 2011 | 07:11 PM
Jay13's Avatar
Jay13
From: . [Rotorhead] "You seem to be a douche. What I'm getting at is just STFU" [/Rotorhead]
St. Jude Donor '06 & '09 & '11
I always wrap a piece of blue painter's masking tape around the contact points of the lug nuts. It usually gets beat up, but I don't have any scars on the chrome, either.
Old Apr 28, 2011 | 07:23 PM
smurfkiller's Avatar
smurfkiller
really? are you that worried about your nuts. that is seriously ****.
i wrap painters tape around my lug sockets to protect the wheels but the lugnuts come on.
Old Apr 28, 2011 | 08:27 PM
toomuchcar's Avatar
toomuchcar
Factory "capped" lug nuts are terrible and they don't fit sockets well. Get real chrome plated lug nuts, I found the McGard product to be great.
Old Apr 28, 2011 | 09:05 PM
CH-Z51's Avatar
CH-Z51
From: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
I have an 10 piece set from HF and there is your solution.
Old Apr 29, 2011 | 09:02 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Factory lug nuts seem to hold up pretty well for me, we switch tires every spring/fall (summer/AS) plus the occasional brake flush and such, and check the torque each month. Use a normal 6 pt socket. Our 2006 had 3 1/2 years/44,000 miles, nuts still looked good to me. But we don't put our car in shows, that might be a different story.
Old Apr 29, 2011 | 09:33 PM
MARSC6's Avatar
MARSC6
A regular 6 point socket will be fine just don't use a impact.
Old Apr 29, 2011 | 10:19 PM
fmarshall's Avatar
fmarshall
Here is what I use. I bought it when I had my Porsche and it works on my Grand Sport.
http://www.boothedesign.com/assets/socket_lg.jpg
Old Apr 30, 2011 | 09:28 AM
Bandit1's Avatar
Bandit1
Me too.
Old Apr 30, 2011 | 10:34 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
It's probably not necessary, but I also use the sockets from Harbor Freight. Inside and outside are both cushioned.
Old Apr 30, 2011 | 12:02 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I don't like nylon coated sockets. I still prefer Craftsman socket sets. I wouldn't be worried about marring the lug nuts in the first place. If they're quality lug nuts the chrome plating should withstand normal use. IMO use a decent socket and simply exercise a little care when removing the lug nuts.
Old Apr 30, 2011 | 12:34 PM
Vette5.5's Avatar
Vette5.5
While never used these myself, recall seeing a setup called Met Wrench, where the socket's are of a design that grab's the nut's only on the flat's and wont round them. Pretty sure Home Depot sell's some like this too. I swap out track tire's quite often with OEM capped nut's using long handled wrenches/12 point socket's with gentle action, and still look nearly new. Think avoiding impact shock has something to do with it.
Old Apr 30, 2011 | 12:49 PM
florida john's Avatar
florida john
I've not had my wheels off yet. Am I to believemm that the factory lug nuts are those cheapie chrome capped nuts like my 2002 FireBird came with?
Old Apr 30, 2011 | 01:02 PM
Jeff78's Avatar
Jeff78
The factory lugnuts are just a steel lug nut with a thin stainless steel cap on top of it.
To Lug Nut Socket
