Lockpick Reverse Camera
Old Dec 15, 2012 | 08:27 PM
  #61
jcarl's Avatar
jcarl
Please describe how you remove the vanity mirror from the sun visor.
Old Dec 15, 2012 | 09:00 PM
  #62
4SUMERZ's Avatar
4SUMERZ
Ok, the thing you will have to realize, is when you remove the vanity mirror, you are breaking the tabs that hold it in the sunvisor. Therefore, there is no turning back, although, if you wanted to reattach it, you can use epoxy to do that, and it will hold. I removed one, and reattached it with epoxy and it held up OK.
To remove, just have to get a flathead screwdriver under a corner, and pry up. It is held on all 4 corners with these plastic tabs.
Old Dec 15, 2012 | 10:53 PM
  #63
4SUMERZ's Avatar
4SUMERZ
Here is another option for mounting a monitor above the rearview mirror.
post #18 in the attached link
http://forums.corvetteforum.com/c6-c...ng-camera.html
Old Dec 15, 2012 | 11:04 PM
  #64
LS WON's Avatar
LS WON
Originally Posted by LV2TOUR
Probably 4 hours from start to finish.
It's not difficult to do, but you need a liitle bit of ingenuity, and the right tools to do the job.
This was the process:
1) I had to remove the sunvisor from the car.
2) I had to remove the vanity mirror from the sunvisor
3) I took the cover off the vanity mirror, measured and modified (cut) an opening in the cover, which the monitor would fit perfectly snug.
4) Drilled a hole on the top part of the cover (above the monitor) on each side, and placed a rod through the drilled holes, across the back of the cover, and epoxed each end on the inside.
5) Once the opening was perfect, the monitor was fit into the opening, and epoxied in a few places around the monitor on the backside of the cover.
6) In order to attach the cover to the sunvisor, mounting tabs were epoxed into the sunvisor on the top area where the vanity mirror used to be.
The rod then snaps into the mounting tabs to secure the top part of the cover/monitor to the sunvisor.
7) The bottom part of the cover was secured to the sunvisor with industrial velcro.
8) The power cable and video cables were run inside the sunvisor, and out to where the sunvisor attaches to the top windshield molding
9) The power and cable feeds from the camera to the monitor are run up inside the driver windshield pillar.
10) All the wiring /lights and switch (taped off) for the vanity mirror were left and tucked into the sunvisor opening. The wiring was still needed for the homelink/garage door opener buttons.
Patience and alot of thought went into measuring, cutting etc, so it would look OEM when finished. It turned out pretty nice.
The thing I like about this mod is that the cover/monitor can be removed from the visor without damaging anything, just in case the monitor has to be replaced down the road.
4) Drilled a hole on the top part of the cover (above the monitor) on each side, and placed a metal rod through the drilled holes, across the back of the cover, and epoxed each end on the inside.
thanks for the info
Beyond me I would have to have a professional install it. I can't do it.
