Wheel problem
Old Oct 4, 2011 | 02:23 AM
  #41
redzone's Avatar
redzone
Originally Posted by speedraider
I have seen them installed and they look really scary, sidewall at about 45 degree.
I agree,I ordered a set back when I had a regular C6 & didn't like the way the sidewall was slanted at all. Not saying they won't work,I just didn't like the look.
send them back and get the 8.5
The problem is they most certainly don't have them in the 8.5". Many people who sell the repros only keep the 19x10,19x12 & 18x9.5. That way they reduce their inventory by 25%. At least that's what the vendor I used told me. He was able to get me the 8.5's. But it took about a month.
Old Oct 4, 2011 | 02:25 AM
  #42
BigDs_C6's Avatar
BigDs_C6
Originally Posted by Racer
yes, it does, it has been verified.
Agreed!!! I've been running 245/40/18's on 9.5" Z06 replicas for a year and a half now... No issues what so ever.
Now, as to why the vendor sent this size wheel... That's an entirely different issue.
D
Old Oct 4, 2011 | 09:32 AM
  #43
haljensen's Avatar
haljensen
Originally Posted by eurostyle
In other words, if I buy a 255/40 it will fit the rim much better. Will the TPMS still work properly? and in order to balance the rears will a 295/35 fit the oem size of 19x10?
A 275/35/18 is perfect for the 9.5" wheel. Very close to the original diameter and works with the 285/35/19 rear well.
Old Oct 4, 2011 | 10:30 AM
  #44
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
Racer, vendor did nothing wrong, my question to him was "will they fit" the OEM tire and he said yes, no problem, but "forgot" to mention that it won't look right. Of course not, the wheel is protruding 1/2" inside and outside of the tire being a 18x9.5 instead of 18.8.5
I need some suggestions on a new tire size. Thanks
Absolutely no fault to the vendor. Due diligence is on your behalf.
Run a 255 or 265 tire if you're not comfortable. I run 265s on my 18x9.5 fronts.
Old Oct 4, 2011 | 04:29 PM
  #45
eurostyle's Avatar
eurostyle
That's the answer I was looking for. Thanks haljensen.
Old Oct 5, 2011 | 09:34 AM
  #46
haljensen's Avatar
haljensen
Have to remember that the tire companies AND the wheel companies want to sell their products, they don't care if you get a correct fit, they just want you to buy from them. If the companies stated that their tire or wheel only fit one specific size they would lose sales.
GM has enough buying power that when they order an 8.5 inch wheel for a 245/40/18 tire and a 9.5 inch wheel for the 275/35/18 tire you can be reasonably sure the wheel and tire fit correctly.
Old Oct 5, 2011 | 03:27 PM
  #47
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
Rarely do I speak this frankly, but you need to stop posting, period. You have no idea what you're talking about.
There is not ONE tire size for every ONE rim size. Tire sizes increase by 10MM increments. The smallest incremental increase you will find in wheel width is in .5" widths. That is more than 10MM (it's roughly 16MM). Your blatantly incorrect logic suggests that every single other tire manufactured is "in between" the correct .5" wheel width increments.
Do you comprehend what I'm saying? Please stop proliferating false information.
Old Oct 5, 2011 | 07:04 PM
  #48
haljensen's Avatar
haljensen
I've obviously done more research than you have. Tire width at the sidewall is dependant on the wheel width. If you'd look a little deeper you'd find that a 245mm width sidewall is only a 245mm width with ONE SPECIFIC SIZE wheel width. The example quoted above shows a 245mm sidewall width on a 8.5 inch wheel. If you increase the wheel width you increase the sidewall width. Maybe you need to actually read and comprehend the 1010 tires site explanations?
Old Oct 6, 2011 | 01:34 PM
  #49
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
What in the sam hell are you talking about? Nothing you just said makes any sense whatsoever.
Has anyone ever taught you how to read a tire's sidewall, or what the measurements mean?
Old Oct 6, 2011 | 06:11 PM
  #50
haljensen's Avatar
haljensen
Again; Read the fine print on post # 32.
Under "Notes"
"Specifications are as accurate as possible based on the information provided to us by the tire manufacturers. The dimensions reflect average values for tires MEASURED ON THE SPECIFIED MEASURING RIM WIDTH."
For those of you with English as a second language that means if you have a different rim width you will have a different sidewall measured value. Common sense tells you that if you change the rim width that the sidewall measurment will change. Look at extremes, if a sidewall measures 245mm on an 8.5" rim it will measure less if it's on a 1.0" rim and will measure more if it's on a 16" rim.
You have to realize that the sidewall measurement isn't the tread width measurement, it's the measurement of the sidewall width at it's widest point. Narrower rim equals narrower sidewall, wider rim equals wider sidewall.
Old Oct 7, 2011 | 01:43 AM
  #51
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
No.
Just.....no.
*sigh*
Old Oct 7, 2011 | 04:40 PM
  #52
eurostyle's Avatar
eurostyle
No.
Just.....no.
*sigh*
haljensen is right. Please jump into the Toluca lake to refresh your brain.
