Sweet Spot
Old Oct 31, 2011 | 11:10 PM
ptaylor_9849's Avatar
ptaylor_9849
Default Sweet Spot
Has anyone here supercharged their GS? I had a C6 and then a Z06. Both had their pros and cons. The ride was more comfortable and less twitchy in the C6 but the acceleration was insane in my Z06. So I started thinking..... maybe the best of both worlds would be a supercharged Grand Sport. That would give you creature comforts like selective ride, glass roof, great gas mileage etc but with more intense acceleration. Your thoughts please?
Old Oct 31, 2011 | 11:34 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
There are some that have, yes.
I say go for it!
Old Nov 1, 2011 | 11:52 AM
Wayne O's Avatar
Wayne O
CF Senior Member
While I've never been a fan of forced induction on a stock, cast-piston engine if used responsibly supercharger's work well enough. Typically, most guys are just looking for a short, straight line blast on a public road anyway. A friend has a cammed GS with long tube headers, coil-over's, etc. and it runs very well on a road course. I still prefer naturally aspirated power.
Old Nov 1, 2011 | 12:07 PM
ptaylor_9849
Wayne O, please elaborate more about this. Are you saying that an LS3 might not have enough internal strength to handle a supercharger?
Is the LS9 in the ZR1 a much stronger engine internally? Pardon my ignorance but I no nothing about superchargers and where they should and shouldn't be used.
Old Nov 1, 2011 | 12:50 PM
EDinPA's Avatar
EDinPA
Yes.
Old Nov 1, 2011 | 02:21 PM
OnPoint's Avatar
OnPoint
The Consigliere
Like Ed above,
I've got a 606hp Callaway Grand Sport. Great car. Strong running, comfortable driver, and a 100k mile warranty from Callaway that overlays GM's 100k mile drivetrain warranty.
Or you can go a less expensive route and either install the supercharger yourself or have a shop do it with off the shelf stuff. Tuning and set-up is key to a safe, reliable and durable package. I frankly didn't want to have to worry about any of that, and fortunately had the coin to just pop for the Callaway, which has a demonstrated record of outstanding reliability/durability.
So. . . OP, go get that SC GS and have some fun.
Old Nov 1, 2011 | 11:46 PM
Callaway Chris's Avatar
0Callaway Chris
Former Vendor
We can help - if I can assist, please let me know - our SC Corvettes are peerless with power, drivability, reliability, emissions compliance, and Powertrain Warranty
Recently, our 2010 SC606 Grand Sport turned 109,000 miles in 2 years - flawlessly, I might add
more @ www.callawaycars.com
Old Nov 1, 2011 | 11:58 PM
Silver05GTO's Avatar
Silver05GTO
Option 3.....
Buy a used Z06 and alter the suspension to your liking....buy the softer springs + shocks from the GS and bolt them right in.
The positives of this is that you'll get the acceleration you want, better reliability then a FI car (plenty of horror stories of SC's that went bad).
If you buy a Z06 with warranty, you'll be much more likely to keep a drivetrain warranty intact by doing suspension tweaks then a SC kit which by default voids your entire drivetrain warranty.
Just a couple things to consider. If you want a solid GS package, you should opt for the Callaway, but you certainly pay a hefty price for admission.
Old Nov 2, 2011 | 12:47 AM
0Callaway Chris
Former Vendor
Originally Posted by Silver05GTO
Option 3.....
You DO keep your powertrain warranty from Chevrolet w/ Callaway
Old Nov 2, 2011 | 08:22 AM
FloydSummerOf68's Avatar
FloydSummerOf68
The positives of this is that you'll get better reliability then a FI car
....until you drop a valve in the Z06, you mean
Old Nov 2, 2011 | 09:49 AM
NYC6's Avatar
NYC6
you might not get the power you want from a stock LS7. A LS3 with an entry level Centri kit makes a good amount of HP/TQ over the Z06 and will pull away pretty hard from one.
Reading the Z06 section you see quite a few stock LS7 imploding for different reasons. Its not a bulletproof plant.
Personally, I dont think a carefully done, moderately boosted LS2/3 is any more likely to grenade than a LS7. There are thousands of us who are F/I for years w/o issues at all. Like any hi-po install, the more you turn up the wick the greater the odds of something going wrong. If left at reasonable boost pressures its damn near as safe as the day you drove it off the showroom floor.
Old Nov 2, 2011 | 01:08 PM
JoesC5's Avatar
JoesC5
A friend has a '10 GS coupe with manual transmission. He had a TVS2300 installed with a cam and longtubes. He's getting around 615 at the rear wheels. He has had no problems but he dosen't beat on the car. More of a show car then a race car.
I think the only problem he has had was in a low speed cruise in traffic in 95 degree weather, the engine went to 230* and the A/C shut off. I think most people with blowers recommend a larger aftermarket radiator.
To Sweet Spot
