Cigarette Lighter Problem
Old Dec 27, 2011 | 08:29 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Sorry, I'm not sure if the outlet under the armrest is on the 'cig ltr' or the fuse right next to it labeled 'aux pwr'.
Old Dec 27, 2011 | 08:41 PM
greengo's Avatar
greengo
If you replace the entire lighter...get the Z06 lighter!
It adds 20 HP
Old Dec 28, 2011 | 01:02 AM
jedblanks's Avatar
jedblanks
The lighter has a hot wire and a ground. If it blows when pushed, it's the lighter. If it blows immediately , the hot wire is probably shorted to ground or the socket is bad.
Old Dec 28, 2011 | 05:25 AM
jft69z's Avatar
jft69z
Had a customer once that kept blowing fuses when he would turn the car a certain way, or hit a bump just right. Turns out he used his ashtray as a coin holder & a dime ended up in the lighter socket. Just the right turn or bump would take out the fuse. It might be worth a look....
Old Dec 29, 2011 | 04:37 PM
Paul 68's Avatar
Paul 68
It adds 20 HP
Cool but if I add the ZR1 Lighter it will add 100 HP.
Old Dec 29, 2011 | 04:40 PM
Paul 68's Avatar
Paul 68
Ok Thanks. If so, car still under warranty I have it fixed. Should be cover under the bumper to bumper warranty I hope.
Old Dec 29, 2011 | 04:43 PM
Paul 68's Avatar
Paul 68
Yeah, the lighter socket clean, but can check around, when I open the fuse panel there was a business card in there lol. Never know what you find in a used car, my 92 Vette there was a gun clip with bullets in it and I got that car from a doctor.
Old Dec 29, 2011 | 04:48 PM
Paul 68's Avatar
Paul 68
If the lighter in the socket the fuse blow immediately, when putting the fuse in but if I take the lighter out of the socket and put the fuse in, all is fine until the lighter is set back in the socket but not push in, the fuse will blow.
Old Dec 29, 2011 | 04:53 PM
TMyers's Avatar
TMyers
Seems to be a problem but I don't know the fix. It blows everytime I use the socket for my air pump.
Old Dec 31, 2011 | 02:39 AM
Paul 68's Avatar
Paul 68
Damn, seem like the lighter port should be the least of the car problems, you think they have that down pack by now.
