Jack Recommendation
Old Dec 26, 2011 | 08:25 PM
KibunInc's Avatar
KibunInc
I just lift up the car with my right arm so my left hand is available to do the work.
Old Dec 26, 2011 | 08:41 PM
SSTEVEGS's Avatar
SSTEVEGS
Originally Posted by Tide Will Roll!
I noticed your doors/trunk are opened...is opening the hood/doors/trunk when raising on a lift and or raising with a floor jack recommended? Or is that just extra precaution to avoid potential problems?(sorry for hijack)
I have a regular floor jack that I already had before I got my C6.
Corvettemods sells a puck that replaces the cradle on any floor jack.The top of the puck fits into the slot in the frame
Bert
Roll Tide!
I've read that the C6 frame is stiff enough so you don't have to open the doors, etc...but I like to take every precaution. It's not much trouble for the extra insurance.
Old Dec 26, 2011 | 09:40 PM
JoesC5's Avatar
JoesC5
The frame's side rails, where the rocker panel cutouts are, is not the recommended jacking site according to the owner's manual. GM says to lift the car by placing the jack under the aluminum crossmember at the ends where the lower A-arms are attached. Use a block of wood to distribute the load over several of the ribs. Do not lift the car in the center of the aluminum crossmember. You can lift the entire front, or rear, by using a crossbeam adapter that allows you to place the jack in the center of the adapter with the ends of the adapter under the ribbed ends of the aluminum crossmember. I made my crossbeam adapter from a piece of 2x6 long enough to span the distance, with 1/4" plywood pads("5.5x5.5") screwed on top of the 2X6 at the ends.
http://www.chevrolet.com/assets/pdf/...12corvette.pdf see pages 10-5 & 10-6
Old Dec 27, 2011 | 10:04 AM
pcguy2u's Avatar
pcguy2u
Originally Posted by Tim05C6Z51
A ton of vendors sell them. Look on the forum or even ebay, or just make a run to Academy sporting goods and buy a few standard hockey pucks. Then put a 3/4 eye bolt through each one.
or just use a small piece of 2X4 like the dealers use........
Old Dec 27, 2011 | 10:14 AM
RACE U's Avatar
RACE U
From: Louisville Ky NCM Lifetime Member 429 (Member Since 1993)
St. Jude Donor '12-'13, '16
What do you use for your car if you have a ground effects kit added?
Old Dec 27, 2011 | 11:50 AM
speedraider's Avatar
speedraider
Got this at Harbor freight and in the back of most automotive magazines is a 20% off coupon for Harbor Freight
http://www.harborfreight.com/2-ton-l...ump-68051.html
Old Dec 28, 2011 | 08:57 AM
studiovette's Avatar
studiovette
anybody use anything from sears? I have a gift card so I figured I would use it to buy a jack. I would only be using the jack to remove my tires for cleaning. No oil changes or going under the car so don't think I need stands.
Old Dec 28, 2011 | 11:28 AM
torquetube's Avatar
torquetube
You need jack stands (or some equivalent) in any event and especially so if you're buying a cheap Chinese jack from Sears. Don't get in the habit of not using them.
The jack may never let go suddenly, but it's not uncommon for them to leak down pretty quickly.
A pair of jack stands can be had for less than a fill-up.
Old Dec 28, 2011 | 12:47 PM
studiovette
Good call! I'll spend the g/c on the stands from Sears and buy a quality American made jack from elsewhere.
Old Dec 28, 2011 | 04:01 PM
Bonefishmak's Avatar
Bonefishmak
I'll be buying one from Harbor Freight however I can't decide if I should just buy the 2 ton steel low profile one or the 2 ton low profile racing one. Not sure I need the lightweight and the 2 tone low profile steel one seemed to get better reviews....
I'd only be jacking the car to change tires or maybe something else light duty. I've got 6 jack stands. When I put my cars up I don't play..I make sure it ain't going any where!!!
Besides I hope to have a lift in about a year....
Old Dec 28, 2011 | 08:58 PM
studiovette
Old Dec 28, 2011 | 09:44 PM
C7Joy's Avatar
C7Joy
Originally Posted by SSTEVEGS
I bought mine at Harbour Freight for 69.99 on sale a few years ago. It works great for my needs. I use it on all my cars, including my Tahoe. 2 ton capacity, 2.75" minimum to 19.5" maximum jacking heights. Item number 67022.
I was installing new OEM splash guards and removing the old aftermarket guards...
Yes, I have the same one for the same price and really like it. It's not rapid pump but who needs that in the man-cave garage!!
Old Dec 28, 2011 | 10:15 PM
  #33
Tide Will Roll!'s Avatar
Tide Will Roll!
Thanks for the info
So the frame side rails whers the pucks go are for raising the car with a lift only not a floor jack with a puck?
And the lift points referenced in the owners manual and in your post above, that GM recommends are for use with a floor jack (using block of wood or crossbeam adapter) or you could also use a lift under there if you could position it correctly that far under the car?
Not trying to start a argument, just trying to learnAnd yes I read the owners manual the first day I got home with the car from front to back and have referenced it numerous times since thenAnd have also watched the DVD.
Perhaps GM does not recommend using a jack (with a puck of course) at the frame rails (shipping slots?) because of the likelihood of the jack slipping off of the puck?
Thanks for any more tips or info
Bert
Roll Tide!
Old Dec 28, 2011 | 10:54 PM
  #34
My07C6's Avatar
My07C6
And they will take the 20% off even the sale prices.
Old Dec 28, 2011 | 11:11 PM
  #35
duramaxsky's Avatar
duramaxsky
Lightweight is good when you get a lift. You will be lifting it up there to raise the tires off the ramps.
Old Dec 29, 2011 | 03:47 AM
  #36
CO Lightfoot's Avatar
CO Lightfoot
Whatever you get, make sure it's low-profile!
If you have a local Harbor Freight, look at their selection. I got their 1.5-ton economy model last summer, on sale for $59.99.
Now for the holiday season, it's $79.99.
http://www.harborfreight.com/rapid-p...html-7814.html
Works great with hockey pucks for jacking the sides of a C6. But it's not long enough to reach the center jacking point from the front... not sure it's heavy-duty enough to easily support that. Anyway, I only use it for oil changes and Z51 lubing, so not a problem for me.
Old Dec 29, 2011 | 04:49 AM
  #37
studiovette
Anybody have discount codes for harbor freight.
To Jack Recommendation
Old Dec 30, 2011 | 12:40 PM
  #38
studiovette
Just ordered the 2 ton light weight alum. one for $159.99 plus the 20% off and shipping was only $6.99 until tomorrow.
Old Dec 30, 2011 | 12:53 PM
  #39
franman69's Avatar
franman69
I'm new here and a little confused. I too read the manual, and all the posts about having jacking pucks. I have purchased the jacking pucks and it's my understanding that I should use the side frame points to jack the car up?? So If I want to take off a wheel to clean or access behind the fender lining panels, I should use the under chassis points shown in the manual??
Are the jacking pucks ONLY for use by a shop lift??
Thanks - signed, slightly confused...
Thanks for the info
Bert
Roll Tide!
Old Dec 30, 2011 | 02:49 PM
  #40
speedraider
just ordered the 2 ton light weight alum. One for $159.99 plus the 20% off and shipping was only $6.99 until tomorrow.
your gonna love it, its light as hell. I have the same one.
