Shifter
Old Feb 8, 2012 | 01:22 AM
JRfigo's Avatar
JRfigo
Default Shifter
What does it mean when the shifter feels tight changing gears?
I own an '06 vert with barely 20,000 miles on it, mostly highway.
Old Feb 8, 2012 | 06:23 AM
Triumph Jerry's Avatar
Triumph Jerry
I am a '06 vert with barely 20,000 miles on it, mostly highway.
I'm guessing you have a standard tranny.
If you are driving in colder temps the tranny will be a little stiff starting out.
Old Feb 8, 2012 | 07:47 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
wow, your car can write
Old Feb 8, 2012 | 09:22 AM
JRfigo's Avatar
JRfigo
Doesn't yours?
Old Feb 8, 2012 | 09:39 AM
Wayne O's Avatar
Wayne O
CF Senior Member
It's impossible to know what your shifter feels like or what you consider "tight" but the Corvette manual transmission is widely considered to be 'notchy' compared to many other cars. As noted, cold temperatures affect ease of shifting as well. With only 20,000 miles it may be unnecessary but you might consider changing transmission fluid. I use Royal Purple Synchromax transmission fluid with good results. I doubt you'll get dramatically different results whether you use Royal Purple or the factory recommended fluid but it might be worth a try. Good luck!
Old Feb 8, 2012 | 09:48 AM
JRfigo's Avatar
JRfigo
Thank you. How much would it cost on average if I have a dealer do it?
Old Feb 8, 2012 | 09:49 AM
C6FirstVette's Avatar
C6FirstVette
Also, don't forget the shifter-to-tranny linkage for a C6 is long due to tranny being in rear...thus it will take more effort to shift and is particularly noticeable in colder weather when lubricants are thicker/'stiffer' in both the tranny fluid and linkage lube.
I did switch to Amsoil tranny fluid and did feel a bit of improvement over OEM fluid BUT you not going to feel a miraculous jump in less shifting effort...just the nature of the beast. My 1990 ZR-1 with a direct input shifter ZF 6 sp tranny is soooo much easier shifting you just want to row the thru the gears.
Old May 21, 2020 | 11:42 PM
RedHottGS's Avatar
RedHottGS
I have over 90K miles on my 2010 GS, all paddles, no issues.
Old May 22, 2020 | 12:04 AM
EviLS7's Avatar
EviLS7
You could do the venom mod. Helps ease shifting.
Old May 22, 2020 | 12:30 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Eight year old thread. Might have it figured out by now.
To Shifter
