Mobil 1 all marketing hype!
Old 02-12-2012, 01:33 PM
dkvetteguy
dkvetteguy's Avatar
Default Mobil 1 all marketing hype!
Mobil 1 in my experience cant compare to true synthetics like redline,lucas and amsoil! I wish the'd quite brainwashing the general public into thinking its straight from heaven and from the gods! But then again just my opinion! Ive been using royal purple and see a difference in idle smoothness when i switched in all 3 cars!
good read! http://forums.nasioc.com/forums/show....php?t=1265711
dkvetteguy is offline
Old 02-12-2012, 01:45 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,202 Likes on 706 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
so do tell why is Mobil 1 NOT a true synthetic
http://www.bobistheoilguy.com/
pewter99 is offline
Old 02-12-2012, 01:46 PM
Vette_DD
Vette_DD's Avatar
Received 1,277 Likes on 935 Posts
Must be some reason why GM put Mobil 1 in all the new Corvettes.
Vette_DD is offline
Old 02-12-2012, 01:49 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Talk about drinking the Coolaide.
Look, you put whatever you want in your cars. I'll put what I want in mine. I've seen the data on the Mobil 1 and frankly, I'd put it put against any of the "boutique" oils.
talon90 is offline
Old 02-12-2012, 01:51 PM
dkvetteguy
dkvetteguy's Avatar
Mobil 1 is fully derived from dino stock base stock ! All except the 0w-30 blend european formula. It is derived from polyalephins [spelling not correct] Redline and other are also derived from PAL's
Even Nissan only recomends 0w30 mobil 1 because it can handle the heat where other mobil 1 grades can't
Old 02-12-2012, 01:55 PM
C-INRED
C-INRED's Avatar
St. Jude Donor '06
What exactly in your experience tells you this? Do you think this is case no matter how the car is used (i.e. normal road used vs. track)?
C-INRED is offline
dkvetteguy
dkvetteguy's Avatar
Old 02-12-2012, 01:58 PM
bearman95
bearman95's Avatar
bearman95 is offline
Old 02-12-2012, 02:05 PM
ByByBMW
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Thanks for the link. I knew that info was out there somewhere and hadn't found it.
For the Mobil1 lovers, your choice in oils is fine, nothing really wrong with Mobil1, but if you want the BEST oil in your car, you need to research some of the other brands. There are oils that are just as good, if not better, and in a few cases, maybe even cheaper than mobil1. YMMV.
ByByBMW is offline
Old 02-12-2012, 02:06 PM
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
oh ok I get it, because some guy on a Subaru forum says so....
I'll stick with my Mobil one and he can put what he wants in his "Subaru" after all he is such a "specialist"
mcandrew67 is offline
Old 02-12-2012, 02:07 PM
dkvetteguy
dkvetteguy's Avatar
It is common knowledge that in Europe the mobil 1 we use here is not even allowed to advertize it is synthetic! It does not even meet warranty requirements for many cars here and in europe! That alone tells me REDLINE [which does meet those requirements is better choice!] or 0w30 european formula which is true group 1V synthetic.
Cant see why 0w 30 european formula or redline or others wouldn't be a better all around choice for our cars
Old 02-12-2012, 02:10 PM
obxchartercaptain
obxchartercaptain's Avatar
FL Events Coordinator
obxchartercaptain is offline
Old 02-12-2012, 02:13 PM
LoneStarV
LoneStarV's Avatar
Hogwash. GM is offering 100k power train warranties on cars running Mobil 1 Oil without even blinking. Is there better oil? Does it matter? It lubricates a GM engine just fine. If there's any hype i usually see it coming the other direction with someone screaming oil XYZ is better blah blah like my car is going to fall apart if i don't switch.
LoneStarV is offline
Old 02-12-2012, 02:23 PM
R&L's C6
R&L's C6's Avatar
Received 1,254 Likes on 708 Posts
GM is backing their belief with a 100K mile warranty. That's good enough for me. Lets see you get oil brand X to pay for any engine trouble you may have.
R&L's C6 is online now
Old 02-12-2012, 02:24 PM
glenB
glenB's Avatar
St. Jude Donor '08-'09 & '12, '14
Step back from the pipe or stick to Subooboo'
Your link proved nothing
See Mobil's site - FULLY synthetic
http://www.mobiloil.com/usa-english/...l_1_5w-30.aspx
"Mobil 1 5W-30 is an advanced full synthetic motor oil designed to keep your engine running like new by providing exceptional wear protection, cleaning power and overall performance. It meets the demanding ILSAC GF-5 performance standards."
PRODUCT
Product Name: MOBIL 1 5W-30
Product Description: Synthetic Base Stocks and Additives
Product Code: 481119-00, 970056
Intended Use: Engine oil
http://www.smartsynthetics.com/amsoi...-basestock.htm
"Group IV -Chemical Reactions: Group IV base oils are chemically engineered synthetic base stocks. Polyalphaolefins (PAO's) synthetics, when combined with additives, offer excellent performance over a wide range of lubricating properties. They have very stable chemical compositions and highly uniform molecular chains. Group IV base oils are becoming more common in synthetic and synthetic-blend products for automotive and industrial applications. The future belongs to the Group IV basestocks (AMSOIL Synthetic Oils are Group IV Polyalphaolefins). "
So much for Amsoil
Do your research
glenB is offline
Old 02-12-2012, 02:33 PM
jschindler
jschindler's Avatar
I hate these threads. I'm sorry I got duped into opening the thread.
jschindler is offline
Old 02-12-2012, 02:38 PM
su8pack1
su8pack1's Avatar
Mobil 1 is good enough for me.
su8pack1 is offline
To Mobil 1 all marketing hype!
Old 02-12-2012, 02:39 PM
MidYearRoadster
MidYearRoadster's Avatar
I am going to use whatever Chevy says to use. If something happens to the motor that is oil related then its there fault not mine, and you know they will look for an out in a major problem.
and if your car idles different because you switched to a different oil..then you have more than an oil problem, I cant see how oil could effect the idle or idle progaming...
if Chevy tells me to use chicken fat..thats what I will use.
MidYearRoadster is offline
CorvetteJenny66 (09-15-2017)
Old 02-12-2012, 02:42 PM
rayk
rayk's Avatar
I like that.
rayk is offline
Old 02-12-2012, 02:47 PM
hawkgfr
hawkgfr's Avatar
Received 1,223 Likes on 833 Posts
oh, YOUR experience? Exactly when did it fail for you and what was the problem? I've been using it since at least 2000 and have had zero problems from or withnthe oil... In fact I know of know one who has had any problems..
Are you trolling?
hawkgfr is online now
Quick Reply: Mobil 1 all marketing hype!
