Let me see if I can dig them out of the garbage.....I am sorry I didn't get those numbers and post them intially.
Brian.
All we should need is the dimensions of them. See Lowes site below with 11 sizes, unfortunately the pics are all the same or it would be easy to tell which one matched those for the air cleaner assembly. I guess I'll measure mine when I get home and then check Lowes locally.
The part number for the individual rubber grommet is 25099300
Bringing this back from the dead in case it helps someone else find this part number as I had to replace mine. Same situation, K&N intake, the ones that came on the car were torn. The part number is correct, and I paid $5.88 each from the dealership.
