upgrading interior speakers
I dont need to do RTA measurements. I have excellent hearing in both ears. Hearing is believing as far as I'm concerned.
IMO I believe there is a lot fact in what Peter is saying. It is unfortunate our car was not designed for good sound quality and we are off axis and the 10" in the door is very good. I also like the 3.5" in the door. I have sound tested them against focal in a bench. The dynamics range of the bose was a lot better with the right capacitor. I found a little better quality and much better staging by keeping all speakers stock but adding a nice soft dome in the doors on a closer axis to driver and passenger also disconnected the center channel but added another soft dome in the mirror facing the windshield for staging. I also have a 10" in the back attached to a mono block JL amp.
Sound is better than stock but I would say a lot more volume and much better staging with somewhat better overall quality. Bass is tuned so that you would not notice the rear of the car until you get to the much lower notes that the door can't handle. But middle bass and great mid range bass all upfront. I can dial up the bass from the back when I wish to hear it outside the car but it is tuned nicely and adjustable for the type of music being played. I did the same to the wife caddy CTSV and the improvements were much more dramatic. That car has better cabin dynamics and while it might be off axis the tweets are on dash facing the windshield and the sound reflection make for pretty good staging.
To really improve the sound the cost could outweigh the benefits. That said, most people feel it is a major sound improvement when a little more highs are added and more bass out of the back is added. Sound quality is mostly an opinion anyway so get it and if you like it great.
I have spent less than $1k and have heard vette's with $10K worth of focal and stuff. He was a little disappointed after he heard my car. When he begged to know what I did and the cost he was even more upset. The thing I'm trying to say is he was very happy with what he had and thought it was amazing. Then he heard my car and realized high-end brand names are not always the answer. Tuning is key.
Joe
Joe
Nevertheless, it is your dime and your ears and manufacturers and retailers thank you for your lack of understanding and keeping them in business.
You are missing the point. Upgrading speakers is not going to make the factory stereo great, but it will make it better. The GM factory speakers are crap, and for $120 and about an hour of work you can replace 3 speakers and get a noticiable improvement in SOUND QUALITY.
Saying that replacing cheap low-quality speakers with better ones will not improve sound quality does not make any sense. You can spout all the jargon you want but what your selling just doesn't pass the smell test. I have done a speaker upgrade and it does make a difference and to me it is noticably better.
Eh... I just wanted to know if I could swap in some 60$ speakers and get improved sound quality. From the sound of it, hehe, everyone but one thinks that swapping speakers is a big sound improvement. I don't care about coax-flux capacitor-dilation-radial-deflection-wtf i just want to know if it sounds better. If you haven't trusted the retailer and swapped in a couple of speakers petermj, I really don't wanna hear your opinion. Everyone else that trusted the retailer and got 240rwhp for 60 bucks in audio terms, they are the ones I want to hear from. As far as I'm concerned, I got my answer. Thanks guys =)
I had focal speakers all the way around, 850 5 channel amp with a 10" jl audio in a custom box in my c5. That set up sounded amazing, off axis or not. I could crank up the volume to 100% and it would come in crystal clear, at an amazingly loud volume. Going to the bose speakers in this c6 is a huge kick in the *****. I'm just gonna throw in some infinitis and see what happens. Worst comes to worst petermj, I just return them. I'll definitely let everyone know how it goes.
From: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
The best sound system is the exhaust system and you don't need no Amp or coax-flux capacitor-dilation-radial-deflection for that.
Now, thanks for the entertainment and let the ignorance rule as usual, LMAO
Two things that could make it even better would be if you could find a speaker with a tilting/aiming tweeter or some fabrication work on the door panel to focus the whole unit.
If you decide to do this you may want to order a few extra door panel pins, as they are cheap. I think the pins for our door panels are pretty brittle, and have snapped at least 1 each time I've had a panel off. However I'll admit I don't tend to have very good luck with push pins.
I would not do it. Upgrading speakers in the same locations amounts to downgrade as a matter of fact because you will not be able to use the center channel and even if you use it by some miracle, you will not be able to match the signal processing and tonality. What typically happens with these "upgrades" is you end up with smaller speakers in the doors and people swearing the sound is better.
Unless you come up with a better soundstage layout and followup with capable fabrication and installation, you will join others who literally dump the money down the toilet.
And no, a different amplifier will not improve your car sound quality, all amplifiers sound exactly the same as a matter of fact. The only reason why you would be needing higher output amps would be due to the loss of sensitivity in the typical aftermarket drivers due to less compliant suspension and smaller diameter drivers.
Also, throwing a sub or two in the back of your car will not improve the sound QUALITY, it will merely give you more output while creating a real sonic mess due to little details like directional cues resulting from the expected high low pass crossover points set up for your subwoofers.
Take it or leave it but in reality, you end up making your system louder while discarding the sound quality completely-this is the real outcome of those audio upgrades in corvettes I keep seeing, nothing but bragging rights about amount spent, high end brands purchased, sound dampener installed and still not a single clue about the sound quality itself.
As a matter of fact, you can improve the sound quality in your car for about fifty bucks total in a way more effective way than what you think about doing. Corvette audio upgrade is an oxymoron, at least those I keep seeing around here or on so called sound quality forums.
Complete and utter BS. Sound stage is junk on most factory cars. (including the Corvette) You're better off keeping this nonsense to yourself because you sound really ignorant and non-intelligent.
To OP... Do replace speakers, cut out center channel, by-pass factory amp, and put a real amplifier in with a couple of 10" sub-woofers. You'll have a great sound stage. And your ears will notice a HUGE difference. Trust your ears and not Peter.
I'm one of them, and agree ten thousand percent!
Not all obsessive nerds, however, know how to provide criticism in a constructive manner... I promise, some do!
Great discussion!! Yes, I have to agree that an audible improvement can be made by eliminating the center speaker and putting in a couple of better in door speakers (location and aiming not withstanding).. Yes, Audiophile are obsessive nerds.. Yes, they (we) act like Tea Party extremists sometimes...
I've been the pro audio recording business for 30 years. Never heard a car really sound great with great sound stage, stereo field and depth, but that is not what this discussion or the OP is about... The stock (Bose) systems sounds like do do... speakers are extremely bandwidth limited and the system is underpowered... put in a couple of Coax (or other full range) in door upgrades.. you won't be sorry.. Cheap and quick, do it yourself and you'll be happy and proud that you made it "Sound Better".. (not awesome... not like a stereophile's living room system.. just better)...
He should learn to understand the subject before tackling his objective but since he is a typical ignorant consumer, he will follow the clueless majority instead. Seeing comments from you and others, it is pretty obvious that wallet contents replaced brains for quite a few long time ago. Thanks for the douche comment, hating what you do not understand beats learning anything for sure.
... Sound stage is junk on most factory cars. (including the Corvette) ...
To OP... Do replace speakers, cut out center channel, by-pass factory amp, and put a real amplifier in with a couple of 10" sub-woofers. You'll have a great sound stage. And your ears will notice a HUGE difference. ...
Replacing factory speakers with aftermarket ones will not change the sound stage. If you cut out the center speaker and add subs to the rear of the vehicle, you'll be moving the sound stage towards the rear, actually degrading it.
However, this is where I disagree with many other audiofiles that tend to be a bit narrow minded. Sound stage is not EVERYTHING wrt sound quality. Take a sound system in a perfect world with a perfect sound stage and then add a couple of subwoofers behind you. Will it degrade the sound stage? Yes. Will it sound BETTER to the average consumer that likes a good bit of bass? Absolutely. Sound stage is important, but it's not the only factor.
Replacing stock speakers with high quality aftermarket speakers CAN, but does not always, make a positive impact on the system, albeit a small one, from a clarity perspective, which is one of the more important factors to the average consumer.
Here's my $.02 to the OP: I personally wouldn't spend money on aftermarket speakers if that's ALL you plan to do. I don't think that the result will be worth the cash. If you plan to amplify the system (and throw in a couple subs if you want the boom-de-booms), I think you'll be happy. If you are willing to do the install yourself, you should be able to pick up some quality speakers, amp, and a sub or two that won't break the bank, and I think you'll enjoy the result.
I only warn that I've seen MANY people replace only the stock speakers with aftermarket ones, and usually the difference is barely noticeable, and sometimes worse. A good aftermarket speaker needs juice that your stock amplification simply doesn't provide.
Good post! The only thing is low bass frequencies are omnidirectional. It is hard for most people to tell where the sounds of the subs are coming from in a stage. That's why we can use the cube speakers in a home theater and have a subwoofer in a corner.
And I hate having a center channel (in my car no less) that is mono. IMO It sounds terrible when having stereo sounds on the sides being muffled out by center speaker with both right and left sounds coming from it. But hey, they're my ears and if they don't like it I'm fixing it.
Just don't tell Peter.
