Does your engine tick?
Old May 10, 2012 | 07:43 PM
  #41
QUAKEJAKE's Avatar
QUAKEJAKE
In short,my 06 LS2 @ 16K did and my 07 LS7 @ 32K does not. The word on here is normal injector pulse characteristic to LS motors.
Old May 10, 2012 | 07:56 PM
  #42
Mach2's Avatar
Mach2
1st off, I'm lazy. Haven't read past the 1st page but I'd like to suggest the following. A very good tune up shop where I had Kooks headers and catted X-pipe installed pointed out that now with the thin walled stainless headers I will hear a ticking sound. It's coming from hearing the exhaust valve hitting the exhaust valve seat when it closes. You don't hear it with the thick stock exhaust manifolds, but when headers replace the thick, cast stock exhaust manifolds you hear it.
Just my .02 cents.
Old May 10, 2012 | 08:06 PM
  #43
66biskwik's Avatar
66biskwik
Ah nothing better than the sound of an L72 with a solid flat tappet cam. Back in the day some of my races ended before they even started. You were serious if you ran solids and headers. Ticking is normal but if it gets louder get it looked at.
Old May 10, 2012 | 08:32 PM
  #44
LPT2011's Avatar
LPT2011
OK ... my story. I got my '07 last July. It was stored from December to March. Picked it up and within 2 weeks I had a "ticking sound". I started rather faint, but then if I was driving at slow speeds next to a building I could really hear it
That was enough for me ... I wasn't having this beautiful car and have it sound like a 1995 Impala that needed oil every 2 days.
So I'm on my way to my Chevy dealer (GREAT Dealer !) when suddenly the SAH code shows up on my DIC. I was actually happy because the code would be on as I drove into the service bay. 10 minutes later - they told me it was the Harmonic Balancer .... AND IT WAS STILL COVERED UNDER WARRANTY
Bottom line here is that the ticking is totally gone ...
This may not be the case with your "ticking" ... but wouldn't hurt to have someone look at it. And you really can't tell by just looking at the belt ... it needs to be on a lift.
Old May 10, 2012 | 08:56 PM
  #45
JCtx's Avatar
JCtx
Originally Posted by MR_JLR
Is it yours one sided also? Curious myself as to if it may be normal as this is my first American V8 engine.
One side is usually a little louder than the other, so no worries there (tolerances). And remember you're likely to hear the driver's side more, for obvious reasons.
I had to sell my LS1 and LS2 for being embarrassingly loud when hot. And both had piston slap too. My 2012 is silent by comparison, so I can tell you by experience it's the nature of the beast. And your '08 40K+ mile Vette sounds as quiet as my dry-sump, 'hand-built' '12 GS with 700 miles, so I wouldn't worry one bit . This engine is almost as quiet (or as noisy? ) as the Germans I'm used to. They make different noises, however. I actually expected the Germans to be quieter . The quietest engines are Ferraris, with very subdued but clear tappet sound only. With the others, I don't know exactly what's making the noise. And yes, the weirdest sound is the one between 1,500 and 2K rpm, when very easy on the throttle. Have no freaking idea what it is. But again, all other Corvettes I've heard sound like our car, so I'm absolutely convinced it's normal for these engines to make those sounds . Just like this guy put it:
Originally Posted by TNTC4VETTE
It is a common noise with LS motors. VERY common..
Old May 10, 2012 | 08:59 PM
  #46
ChevyRider's Avatar
ChevyRider
My 08 ticks. I brought it up to salesman when I bought it. We went over to brand new one, and it ticked too. Figured it was normal
Old May 10, 2012 | 09:04 PM
  #47
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default May be it's a ....................
Rolex ?
Old May 10, 2012 | 09:06 PM
  #48
boost2na's Avatar
boost2na
Originally Posted by JLMounce
Every LS engined car I've ever driven, including the three vettes I've owned (C6 LS2, C6Z, C6 LS3) all make this noise, as well as the "sewing machine" noise at around 1800 rpm.
I'm pretty sure it's normal valvetrain noise.
Both vids sound like normal aging LS motor noise. My current LS7 sounds like that, old LS3 sounded like that; brother and brother-in-law's LS3s both sound like that.
I think it's actually an illness that all corvette owners suffer from. HTD, hyperreactive tick disorder. We're all OCD about that damn noise!
Old May 10, 2012 | 10:37 PM
  #49
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The LS engines are known for oddball noises, usually harmless but not always.
You can pull an oil sample and send to Blackstone labs, see if they find anything unusual.
When does your 5/100 powertrain warranty run out? I'd be inclined to keep runing it hard (after proper warmup) while still under warranty, and see if anything changes. If it blows up, get a new engine. If it doesn't change, probably ok.
Old May 10, 2012 | 10:48 PM
  #50
MR_JLR's Avatar
MR_JLR
Originally Posted by gearhead jim
the ls engines are known for oddball noises, usually harmless but not always.
You can pull an oil sample and send to blackstone labs, see if they find anything unusual.
12/17/12
Old May 10, 2012 | 10:59 PM
  #51
Gearhead Jim
St. Jude Donor '13
12/17/12
Have fun for the next 6 months!
(Leaving a bit of extra time just to be sure it gets under the wire).
Old May 11, 2012 | 03:06 AM
  #52
Rusler John's Avatar
Rusler John
I've got an 07', LS2, and it has sounded like a quiet typewriter since I bought it. I brought it back to the dealer for the first oil change and mentioned the noise. They said it was normal. We even went out and started another one on the lot, just to prove his point. And, that one sounded the same. So, after 34,000 miles, it still sounds like that and runs as strong as ever. It doesn't make any where near the sound of my old bored out 327 ( 30 over / solids ) or my 409- 425HP monsters of the 60's. But, I'm sure this engine will last longer.
Old May 11, 2012 | 03:16 AM
  #53
Don-Vette's Avatar
Don-Vette
No ticks here.
Old May 11, 2012 | 07:00 AM
  #54
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
My suggestion is for the o/p to contact Dennis Fichtner @ Fichtner Chevrolet, our extended warranty person on the forum. Iirc, Dennis has an extended warranty that will eliminate the date issue.
Old May 11, 2012 | 07:02 AM
  #55
LisasZR1's Avatar
LisasZR1
Lifetime NCM Member #2482
St. Jude Donor '11
My '08 has ticked since brand new. I only notice it when I pull into the garage or am idling next to a wall (drive thru). I don't hear it driving - exhaust too loud, radio blaring, and too much fun driving to listen for a tick at that point. I've never noticed it on the ZR1.
Old May 11, 2012 | 07:18 AM
  #56
Jimmy W1's Avatar
Jimmy W1
My 05 ticks when it is cold for the first couple of miles and then it goes away. I believe it is the air conditioner, because I hear it on that side of the car and it sounds like it is coming from down there. As far as the ticking on your car goes, could it just be the valve train? If you take the valve covers off of an older car, you can really hear the valves ticking. So, maybe you can hear the valves ticking on the newer C6s because of the covers on the engine just don't block out the noise as much as the older ones did. If you were the only person who had this problem, you should be concerned. But since so many people have the same thing it sounds like it is a normal thing to me.
Old May 11, 2012 | 08:19 AM
  #57
357's Avatar
357
Default Driver's side tick
My 05 has a tick on the driver's side. The tick got louder when I put the headers on. It is louder near the ground and very faint under the hood.
To Does your engine tick?
Old May 11, 2012 | 10:18 AM
  #58
push's Avatar
push
Sounds normal to me, here is mine:
Through the fender, hood open
Close up to engine, driver side, hood open
Old May 11, 2012 | 11:16 AM
  #59
deadringer's Avatar
deadringer
I experienced something similar...
In my case it was a leak or crack in the exhuast manifold or header gasket causing the exhaust gas to leak causing the ticking noise..
To locate the leak, you can use a length of hose or tubing (like 1/2" or 1/4") and put one end to your ear and the other around each gasket to locate the leak. You may need a lift up the car either on a lift or ramps to get to the bottom of the gaskets - just don't get burned...
Old May 11, 2012 | 11:46 AM
  #60
HyperX's Avatar
HyperX
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
Noisy valves is what my dealer told me. My Z06 does the same.
