Does your engine tick?
Old May 11, 2012 | 02:22 PM
  #61
biskitman's Avatar
biskitman
Can be the start of the old Piston Slap problem GM has had with their engines for years. I had one that had piston slap so bad it sounded like a diesel at start up then went away after about 30 seconds. lets hope that the LS3 doesnt have this as I have a 2008 with the new LS3! I hated it so bad after taking it to a Chevy dealer that I actually traded the Tahoe for a Ford Diesel Excursion! Im praying all is well with these engines!
Old May 11, 2012 | 02:59 PM
  #62
MR_JLR's Avatar
MR_JLR
Originally Posted by push
Sounds normal to me, here is mine:
Through the fender, hood open
Close up to engine, driver side, hood open
thanks for all the responses. I actually bookmarked your first vid on youtube for comparison last month lol
Old May 11, 2012 | 03:16 PM
  #63
Thunder8's Avatar
Thunder8
Originally Posted by TNTC4VETTE
It is a common noise with LS motors. VERY common.
Our cars are often related to sewing machines from valvetrain, injector, and other noises from under the hood. It is massively worse when you start adding things like headers and intake manifolds.
I would have to agree here. I've had an LS1, 2 and now an LS3. They've all had the same sort of tick coming from the valve train. I can't say there's nothing wrong with yours, but it's very common to the LS motors. I do find it a bit annoying at times, but in my case, there's never been anything to fix.
Old May 11, 2012 | 03:57 PM
  #64
phileaglesfan's Avatar
phileaglesfan
Originally Posted by GARYFINN
So GM can't make an engine that doesn't tick ??????????????????????
I'm guessing not since I have 3 GM V8s (Yukon Denali, Impala SS and GS Vert) and they all tick. Maybe it is the injectors which are noisy. GM's tolerances are so wide it is amazing at times.
Old May 11, 2012 | 04:04 PM
  #65
push's Avatar
push
haha, glad my youtube video was good for something.
Old May 12, 2012 | 03:03 PM
  #66
djohnsto's Avatar
djohnsto
My 2010 GS has a tick that was attributed to piston slap. It was almost unnoticeable until I had an Edelbrock E-Force supercharger installed. I was told that the OEM composite intake acts like a sound deadener. But the supercharger and its aluminum construction acts like a sound amplifier changing what was originally an almost unnoticeable sound into a racket while the engine is cold. As soon as it warms up, the noise is gone. GM is well aware of the issue because they have included "piston slap" tables in the engine control module. Go figure...............
Old May 12, 2012 | 03:36 PM
  #67
florida john's Avatar
florida john
Originally Posted by dckotwicki
This might sound a little goofy, but...
I have owned a few motorcycles and when I would hear something out of the ordinary, I would listen to the motor with a modified stethescope.
Specifically, I removed the flat peice on the end (the thing that the doctor would place on your chest) and insert (screw) a long threaded bolt into the tube end.
Holding the bolt end against the engine in various areas allow's you to listen to specific areas of the engine. I have done this for years and it may not tell you exactly what is going on, but you can certainly hear where the noise is coming from.
My dear departed father taught me an old mechanic's trick years ago. For localizing those hard to pin down noises, he would take a long wood dowel or even a yard-stick and apply it to various areas of the motor (like alternator, right head, left head, water pump, etc) and place the other end of the dowel against the bone just in front of your ear. It is amazing how the sound vibrations are transmitted and what you hear! Over the years, this technique has been very useful for me in locating the source of noises. Hope it can help.
Old May 12, 2012 | 04:31 PM
  #68
Road Rage's Avatar
Road Rage
Default When did Chevy make an engine that didn't tick?
The old addage is:
Cracked
Head
Every
Valve
Rattles
Oil
Leak
Engine
Tick
Surely I'm not the only one that heard this growing up.
Old May 12, 2012 | 04:48 PM
  #69
ATC399's Avatar
ATC399
I hear nothing
Old May 12, 2012 | 05:00 PM
  #70
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by MikeyTX
Rolex ?
Timex.....
Mine ticks and it is a custom motor - the tick is from the injectors in mine.
Old May 12, 2012 | 06:59 PM
  #71
crainholio's Avatar
crainholio
Motor oil manufacturers have been forced to reduce the quantity of extreme pressure antiwear additives (zinc dialkyldithiophosphate or ZDDP or ZDP depending on the publication) since the mid-2000's.
Since then, I've noticed the volume of ticking engine noise complaints here and on LS1Tech has shot up significantly.
Engineering publications and the API have stated that modern roller-lifter engines don't need the extra ZDDP.
I don't claim to be smarter than anybody with engineering credentials and a budget to test oil, but I also note that the only rationale for reducing these antiwear additives is preserving the catalytic converters. There has been no stated benefit to the engine wear components w/ the reduced ZDDP levels, nor has there been a stated risk (other than voiding warranty on a technicality) to using the previous spec quantities.
I find that cats are cheaper to replace than the camshaft and lifters...I also find that my LS6 is quiet using oil w/ the extra ZDDP in it.
Mobil-1 High Mileage 5W-30 has 1100 Zn and 1000 Ph according to Exxon-Mobil, and there's Red Line that has even more.
Old May 12, 2012 | 07:00 PM
  #72
crainholio's Avatar
crainholio
Originally Posted by Road Rage
The old addage is:
Cracked
Head
Every
Valve
Rattles
Oil
Leak
Engine
Tick
And then there's:
Fixed
Or
Repaired
Daily
