Does your engine tick?
Old May 10, 2012 | 03:28 PM
TLS_Addict's Avatar
TLS_Addict
Originally Posted by MR_JLR
Yeah sounds pretty similar to "HEMI TICK"
http://www.challengertalk.com/forums...mi-tick-73240/
Both of the ones I have had and have also tick.
Afterall, they are pretty close to an LS1 copy.
Bore, stroke, intake design....etc However the heads are super wide in comparison. The idiot at Jeep/Dodge who decided its a "good idea" to make it so you have to take the whole belt system off in order to change the EGR valve needs a smacking.
Old May 10, 2012 | 03:46 PM
LPT2011's Avatar
LPT2011
does the "ticking" increase (faster pace) with rpm's?
Old May 10, 2012 | 03:50 PM
MR_JLR's Avatar
MR_JLR
Yes with the windows up I can hear it. It's just a painful noise to hear at idle after the oil has warmed up. So far it's sounding like it's to be expected with LS engines.
Old May 10, 2012 | 03:54 PM
djdinoe's Avatar
djdinoe
Yup mine ticks too! I have headers and intake, so yes, it is worse but I have learned to accept and live with it.
Old May 10, 2012 | 03:55 PM
franman69's Avatar
franman69
Originally Posted by 66biskwik
Quote: "Every time my wife rides with me she complains that it sounds like "chains rattling" under the hood.
She swears I got ripped off on the used Corsa exhaust I bought to swap out the Stingers that were on there.
I tried to explain that with the headers and intake, it's normal.
She's not buying it."
Do what I do when my wife has a comment about the noises, run it up to the red line in first and second. After that she usually doesn't say another word the rest of the ride.
exactly!! always quiet's mine right down as well... he he he..
Old May 10, 2012 | 04:07 PM
TLS_Addict's Avatar
TLS_Addict
So you are saying driving a Corvette should shut a woman up?
Put that in writing and you will make millions. This is what men have needed all along.....a Corvette.
Got mine and one week later she was gone. hahaha
Old May 10, 2012 | 04:23 PM
mike100's Avatar
mike100
my valvetrain/lifters only tick if I haven't started it in a while but it goes away a couple of seconds after the oil pressure rises.
2008 LS3. It has never made noise other than what I described above.
Old May 10, 2012 | 04:41 PM
MR_JLR's Avatar
MR_JLR
your engine is defective. You should trade with me at once
Old May 10, 2012 | 04:44 PM
ElmoTA455's Avatar
ElmoTA455
I thought I heard/read that the ticking noise was from the injectors. My 2010 mn GS has the same noise.
Old May 10, 2012 | 05:00 PM
sportcruiser's Avatar
sportcruiser
I'm not so sure it isn't the sound of the exhaust and headers. I know every car I have ever heard with headers "ticks" (it is the very loud bang that is silenced by the exhaust).
My 2010 A6 with 22K miles on it is stock and pretty much silent. I run Amsoil 5W-30 and drive the car daily.
Old May 10, 2012 | 05:05 PM
Seadawg's Avatar
Seadawg
That's what I do too. BTW, both my 2008 and this 2011 LS3 will occasionally "tick" enough for me to notice it sometimes.
Old May 10, 2012 | 05:11 PM
R&L's C6's Avatar
R&L's C6
My 05 ticked, my 11 ticks, I have driven my friends ZO6 and it ticks. Recently had a ZO7 for a couple of days and it ticked. It seems normal for a LS engine.
Old May 10, 2012 | 05:21 PM
  #33
sportcruiser
Agreed. I still think it is exhaust "pop" rather than a mechanical "tick".
Old May 10, 2012 | 05:25 PM
  #34
brooklync5's Avatar
brooklync5
I listened to both videos and nothing seems to be abnormal about either. I wouldnt worry about it at all if I were you.
Old May 10, 2012 | 06:53 PM
  #35
Foxer55's Avatar
Foxer55
GARYFINN,
Mine is on the Drivers side also !! I hear it when I pull into the garage.
Exactly!
Old May 10, 2012 | 07:03 PM
  #36
boraxman's Avatar
boraxman
Crap...I'm worried now...No noticeable tick here.
Old May 10, 2012 | 07:13 PM
  #37
crusher1's Avatar
crusher1
It sounds normal... check the rubber boot near the steering shaft for the heck of it...
The boot on this guys was loose and caused ticking
Here`s what he said:
Hi For last six months i have been battling a ticking sound like lifters
making noise. I went nuts but couldnt find the source.I was disgusted enough to get rid of the car because it only had 11k miles on it and already having engine problems.Turns out it was a loose rubber boot that isolates the steering shaft from engine compartment.You cant believe how much this little boot makes a difference. The mechanic said this is not so unusual on c6 vettes.So if u have engine noise issue do yourself a favor and check this first
To Does your engine tick?
Old May 10, 2012 | 07:21 PM
  #38
Mad*Max's Avatar
Mad*Max
none here
Old May 10, 2012 | 07:37 PM
  #39
gee350z1's Avatar
gee350z1
Same here maybe i gotta get it checked out.
Old May 10, 2012 | 07:41 PM
  #40
Keith Tedford's Avatar
Keith Tedford
Default Making Noise
If you want to hear valve train noise, listen to an old L72 427 or L78 396 engine with the valves set at .024" - .028". Add headers, and now you have a real sewing machine. Going from that to these LS engines, EVERYTHING is different, including the sounds. Injectors have their own noises too. I'm back to square one in every way. As long as the noise isn't getting worse, I wouldn't get too excited.
