Visor extension
Old Nov 11, 2012 | 11:45 AM
vdavenp802's Avatar
vdavenp802
Default Visor extension
This is a prototype for an extension to the sun visor on a C6. I hate it when the sun hits the side window since the visor is about 4 inches too short. I have built in a notch for the homelink, and sized it so it will slide easily back an forth. Color is a good match with the black. I put in a piece of white paper to enable a better picture of the notch. It really does work nice and goes all the way across the window.
http://i1088.photobucket.com/albums/...802/photo2.jpg
This view is from the top showing the opening a bit better.
http://i1088.photobucket.com/albums/...p802/photo.jpg
Added installed pic, there is some excess glue on the prototype
http://i1088.photobucket.com/albums/...802/photo3.jpg
Bear in mind this is an early version, and I will attempt to improve it.
Let me know what you think (be nice now).
BTW, the response is overwhelming......
Old Nov 11, 2012 | 05:26 PM
Cyber Greg's Avatar
Cyber Greg
Cool! Keep at it, make it look OEM and I think you'll have something.
Good Luck!
Old Nov 11, 2012 | 06:14 PM
ButWhatDoIKnow's Avatar
ButWhatDoIKnow
Old Nov 11, 2012 | 07:17 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Let us know when it's ready for all!
Old Nov 11, 2012 | 09:05 PM
Kvothe's Avatar
Kvothe
I like where you're going with it. It would be better to have something that will allow the mirror to still be used should someone want.
Old Nov 12, 2012 | 10:03 AM
vdavenp802's Avatar
vdavenp802
Good idea, I had thought of that but the first prototype was to be simple and get some rough dimensions/size.
I will continue my quest.
Old Nov 12, 2012 | 10:48 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Good Luck!
Refine to the point of looking 'factory stock' and they'd probably sell like hot cakes.
An extending sunvisor is a little thing but when you really need it you realize how much you miss not having it. Good on you...keep working on it!
PS I suggest you simply plug your photos directly into your post instead of using links.
Old Nov 12, 2012 | 12:19 PM
Mardis Gras's Avatar
Mardis Gras
Old Nov 12, 2012 | 03:17 PM
vdavenp802's Avatar
vdavenp802
Thanks, I'll try that on the next version. Already in the works.
Old Nov 15, 2012 | 10:12 AM
vdavenp802's Avatar
vdavenp802
I took a refined prototype to a local auto upholstry shop and they had a good suggestion to use a visor board (flexible) and to cover it in in factory visor material.
Bad news, cost about $30/per extenstion. This seems to me to be to costly.
Thoughts?
I am also working on another option that works on a totally different concept. It will be a bit more challengeing.
Old Nov 15, 2012 | 04:55 PM
Gearhead Jim
St. Jude Donor '13
$60 for a pair?
I'd probably go for that, IF they worked well and looked factory. That may be a tough combination to do.
Either way, thanks for your efforts.
Old Nov 15, 2012 | 09:32 PM
Kvothe's Avatar
Kvothe
Thoughts?
I don't think that's too bad for a prototype. $30 for time and materials plus some profit seems about right. On the flip side I don't know if I'd pay $60 for a set. I guess I'd have to see them first.
Old Nov 20, 2012 | 04:04 PM
vdavenp802's Avatar
vdavenp802
Thanks for the reply, I feel the same. I did a test run on a two hour drive and used the extension. Result:
A bit unwheeldy sliding back and forth. Got hung up on the cutouts.
Didn't want to slide back in very well. A well made unit might work a bit better, but I have another idea that would be much better but more challenging to build.
Bottom line, it does do the job nicely, just a bit klunky.
To Visor extension
