Skip shift
Old Jan 11, 2014 | 06:10 PM
vertigogo's Avatar
vertigogo
Originally Posted by leres
Smart fuse LEDs rarely burn out; I've been using the same one for 6 years. If yours does burn out, the car will throw a P0803 during the second consecutive trip (aka run cycle). The code will reset the first run cycle after you correct the problem. (DTC history persists for 40 run cycles before clearing.)
Thanks, very helpful.
Old Jan 11, 2014 | 11:32 PM
florida john's Avatar
florida john
Rather than blowing a smart fuse, I bought one on eBay for about $20. It has worked well and I didn't get junk in my eyes like I did with adding the transmission mounted unit to our CTS-V. Much easier.
Old Jan 12, 2014 | 11:06 AM
mew's Avatar
mew
I have the skip shift eliminator that I used on my 2008 Z06. Can that be used on my C7?
Old Jan 12, 2014 | 11:54 AM
Lerxst's Avatar
Lerxst
Originally Posted by RocketDawg
Maybe one of these days the government will realize that skip shift doesn't save any gasoline and not require it.
Put a CAGS eliminator a days after I broght the car home from the dealership. That and pulled the NPP fuse.
S -
Old Jan 12, 2014 | 11:55 AM
jwf's Avatar
jwf
I installed the CAGS eliminator in the first month I owned the car. It takes 1 minute once you get the car lifted and has been trouble free ever since. Best $20 I've spent.
Old Jan 12, 2014 | 12:38 PM
SSTEVEGS's Avatar
SSTEVEGS
Use the fuse. You don't have to lift the car and you don't have any additional hardware attachments - plus it's 1/10th the cost of a CAGS eliminator.
Old Jan 12, 2014 | 01:41 PM
leres's Avatar
leres
The version that plugs directly into the lockout solenoid is reported to work with the C7.
