Winterizing question???
Old Nov 13, 2013 | 08:25 PM
ARMISTICE's Avatar
ARMISTICE
Default Winterizing question???
What do you guys recommend to winterized car?
It will be in a detached garage in Pittsburgh. Not heated but well built garage.
I have a battery tender I will use but what else?
Old Nov 13, 2013 | 08:28 PM
saplumr's Avatar
saplumr
Air up the tires, Seafoam fuel additive and cover.
Old Nov 13, 2013 | 08:29 PM
Joe1968ny's Avatar
Joe1968ny
Originally Posted by saplumr
Air up the tires and Seafoam fuel additive.
Old Nov 13, 2013 | 08:44 PM
RicK T's Avatar
RicK T
This list has been around the Forum for many years and while not everyone necessarily follows it exactly it is a good base to start from. Just pick and choose what you want to do with your car:
Fill gas tank and add Sta-Bil; run through fuel lines (15 - 20 minutes driving).
Change oil and filter. (best to let it sit with new oil than old oil that may be contaminated)
Park on moisture barrier (plastic, wood, just keep tires off bare concrete)
Inflate tires to 38-40 psi cold.
Apply sealant, wax, etc. to exterior paint.
Apply leather dressing to seat panel.
Apply vinyl dressing to interior; and to exterior black trim pieces.
Hook up Battery Tender.
Crack windows a bit.
Cover with inside car cover.
Then think about mouse proofing the car/garage. Some ideas in here:
http://forums.corvetteforum.com/c6-c...-vehicles.html
Old Nov 13, 2013 | 08:54 PM
saplumr's Avatar
saplumr
It's definitely what works for you is what you do. A lot of the above list is unnecessary and in the same category as 10 coats of a particular sealant which comes in application products and steps of 1, 2, 3, 4...well you get the picture.
Old Nov 14, 2013 | 09:03 AM
Don-Vette's Avatar
Don-Vette
All I do is clean inside and out, inflate tires a few pounds, fill the gas tank, add dissicant bags inside(to absorb moisture), connect battery maintainer and cover.
Old Nov 14, 2013 | 09:14 AM
kimdjay's Avatar
kimdjay
Is a battery tender really necessary? I winterize my boat each season and I just undo the cables. Is that truly bad to do on a vette? Am I missing something. I guess I could bring the battery inside and throw it on a charger now and then.. Do the electrical components of the car constantly need some power trickling through?
Old Nov 14, 2013 | 10:35 AM
switchblade six's Avatar
switchblade six
apparently there is a draw on the battery can someone elaborate on this?
moved to condo with no outlet
Old Nov 14, 2013 | 10:50 AM
TLS_Addict's Avatar
TLS_Addict
I there is the possibility of mice (north east usually has this) I would say to put covers over your tail pipe. One winter I had a mouse that broke in to a bag of dog food and fill my mufflers on one of my older Corvettes.
I put traps around the tires if I feel a mouse has come in to the garage (I have two garages) as well as I put in fabric softener sheets all over the interior and under the hood. It seems to keep rodents away.
Old Nov 14, 2013 | 11:03 AM
Gars08vert's Avatar
Gars08vert
From what I see, battery tenders are a must for this vehicle, especially if it is stored without being above freezing for a while. That's a given for us with newer vettes.
Old Nov 14, 2013 | 11:15 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
There is heated debate about whether to start the engine during storage. Most people say "Don't", a GM engineer said he preferred to start it periodically. I don't recall how often he said, it was like every couple of months.
The iron/steel parts in your engine aren't sitting out in the rain, but they aren't hermetically sealed either. And even if they were, there is always some moisture that can condense out of the the trapped air.
For the last 6 years, I've been doing it this way for 2-3 month storage:
Clean the car and fill the tank before storage. Change the oil if it's getting close to time. Air up the tires. Connect a battery tender. Lots of mouse traps scattered around the garage.
Once a week, I start the engine and let it idle while I exercise every switch and control in the car. There's a lot of them, that takes maybe 20 minutes and gets the oil up to about 180' to help evaporate any moisture or acids. Then I back out of the garage and go up and down our 50 yard driveway several times, starting out in different gears, using the brakes, turning the steering full lock as I turn around, etc. But not going out onto the street, which will be coated with salt.
When I do the next oil change and have it analyzed by Blackstone, the results are the same as what I get after a summer-only oil change. When the A6 trans fluid and diff fluid were changed and tested at ~50k miles, they too gave excellent results. So this method is certainly not hurting anything. Whether it actually is better than just letting the car sit untouched, I don't know. But it gives me a weekly dose of Corvette.
Old Nov 14, 2013 | 07:11 PM
Bill Dearborn's Avatar
Bill Dearborn
The best way to store them is to drive them. No car was ever designed to be stored. With Global Warming making winters much easier than they were 15 to 20 years ago it is easy to drive the car year round and not let it sit due to weather for no more than 2 or 3 weeks at a time.
Bill
Old Nov 14, 2013 | 07:22 PM
velocity c6's Avatar
velocity c6
[QUOTE=Bill Dearborn;1585431229]The best way to store them is to drive them. No car was ever designed to be stored. With Global Warming making winters much easier than they were 15 to 20 years ago it is easy to drive the car year round and not let it sit due to weather for no more than 2 or 3 weeks at a time.
Bill[/QUOTE
Well I would like to do that, but up here we average 100+ inches of snow a year which lasts around four months. So for now I have to store it for couple more years.
Old Nov 14, 2013 | 07:38 PM
switchblade six
Good info Jim cant argue tested results..
The one component I think fairs the worst by long periods of storage are those valve springs that are completely compressed.
ill be doing some laps in my underground...
Maybe I will post some times..
Old Nov 14, 2013 | 07:49 PM
Mad*Max's Avatar
Mad*Max
I'm on the same program from Dec.1-Mar.1
Old Nov 15, 2013 | 12:42 AM
TKgs2010's Avatar
TKgs2010
Bill
If you're originally from Endicott, you were about 80 miles south of the Syracuse area, where we get an AVERAGE annual snowfall of over 120 inches, for all the math whiz's out there that's over 10 FEET. Low ground clearance, big horsepower and foot wide summer tires are not a really good mix with snow and single digit temps. I'm pretty familiar with the Binghamton/Endicott area, and the winters there are mostly pretty mild in comparison, so maybe driving thru the winter months works there, but up here, not so much. As much as I'd like to drive the Corvette year-round, here in snow country it's just not a possibility, or a very good idea, that's why I have an all wheel drive Mercedes sedan and a 4 wheel drive pickup.
Old Nov 15, 2013 | 08:51 AM
TLS_Addict's Avatar
TLS_Addict
Ah yes, Syracuse. Was there just a few weeks ago.
To Winterizing question???
Old Nov 15, 2013 | 10:59 AM
SK360's Avatar
SK360
I wash it, pull it in the garage, put the battery tender on it and throw the cover on. People overly complicate things. Fill it up, change oil in spring and drive it.
Old Nov 15, 2013 | 02:59 PM
KneeDragr's Avatar
KneeDragr
Do you really need to drive for 10-15 minutes to circulate the fuel stabilizer through the fuel lines? I figured a mile or two was fine.
Old Nov 15, 2013 | 03:43 PM
Gearhead Jim
St. Jude Donor '13
Hard to say, but since the car has two separate tanks; I would want some time and some sloshing, to be sure the stabilizer was everywhere.
