wheels
Old Jun 29, 2014 | 06:32 PM
jonesc6's Avatar
jonesc6
Default wheels
Hello people I'm thinking about buying some 20x10 rear wheels I have now 18 front 19 back has anybody went with a 20 rear wheel? If so how did it ride? What size tire?
Old Jun 29, 2014 | 08:12 PM
haljensen's Avatar
haljensen
Lots of things to consider when changing wheel/tire size. With a C6 you have to keep close to the original stagger between Front and Rear diameter to keep the computers happy. You are limited on wheel/tire diameter and width by the amount of room in the wheel wells and for brake clearance. You also have to be carefull of wheel design/shape for brake clearance.
Your best bet is to keep the original overall tire diameters and original wheel offsets. This doesn't really limit you, you can fit Rear tires from 17" to 20" and still maintain original overall diameters.
These sites may help;
http://www.tacomaworld.com/forum/tirecalc.php
http://www.1010tires.com/WheelOffsetCalculator.asp
http://www.1010tires.com/TireSizeCalculator.asp
Old Jun 29, 2014 | 08:32 PM
jonesc6's Avatar
jonesc6
OK thanks the wheels I'm looking at a replica of the original base c6 or 5 star. I have on my car now are original standard 5 star 18 front 19 back.rear tire is 285/35/19 so the one I'm looking at 20x10 with 285/30/30 tire I'm really like the wide tire look
Old Jun 29, 2014 | 08:42 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
You do realize that the rear wheel is 19x10, so why change to a 20 inch wheel and also if you are changing wheels why are you sticking to a stock looking replica?
Old Jun 29, 2014 | 08:58 PM
jonesc6's Avatar
jonesc6
Yes I know my stock are 19x10 I'm trying an looking for idea's I want the wide tire look from the back I want car to have the look of gs
Old Jun 29, 2014 | 09:26 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Again, 19x10 or 20x10, you will not accomplish anything except add an inch in height of the wheel. A Grand Sport has the same size wheel and tire as the Z06 The wheels are 12 inches wide and the tires are 325/30/19., so what you are trying to do will not get that look, and again, you can put the same size tire on your 19 inch stock wheel as save the money.
I just did a comparison on the tires and you will not have any more tire width and in fact the Overall Diameter is less with the 20 inch wheel. It is 26.73 in and the stock tire is 26.85 in.
Old Jun 29, 2014 | 09:33 PM
jonesc6's Avatar
jonesc6
Thanks so much if I went with that tire would I have any problems scrubbing? Clearance
Old Jun 29, 2014 | 09:49 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
No. the tire is the exact same width as you have now and it is not as tall. so you will not have any trouble, except your wallet will have less money in it.
Old Jun 29, 2014 | 10:00 PM
jonesc6's Avatar
jonesc6
Lol yes I agree I'm online looking now! What tire do u recommend? Gy suck!
Old Jun 30, 2014 | 09:15 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I happen to have the Michelin Pilot Super Sports on mine. Much better then the GY run flats.
Old Jun 30, 2014 | 09:25 AM
haljensen's Avatar
haljensen
The tire you are thinking of is EXACTLY the same width as the tire you have. It won't scrub because it's the same width as stock.
A 285 wide tire is 285mm wide regardless of whether it's on a 17" or 20" wheel.
To wheels
