Darn 3rd Gear-Shifting Help!
Old Jul 14, 2014 | 07:30 PM
Todds427's Avatar
Todds427
St. Jude Donor '12
Default Darn 3rd Gear-Shifting Help!
Hey everyone, I recently purchased a 2013 Z06 and I'm having a hard time shifting from 2nd to 3rd gear under hard acceleration. Now granted, I'm old school and used to a 4 speed but is this stock short throw shifter junk or do I just need to get used to it? I guess instead of moving it straight up, I move it over to far and miss the gear, any help is appreciated.
I have seen many other brands of shifters, maybe they work better?
Old Jul 14, 2014 | 07:46 PM
lathrash's Avatar
lathrash
When you shift from 2nd to 3rd, try just pushing the gear lever forward with the palm of your hand. It will center itself into the gate for 3rd gear. If you want an aftermarket shifter, many people go with MGW. Search and you will find a lot of info about them on the forum.
Old Jul 14, 2014 | 07:58 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
Open hand just use the palm if you wrap your hand around it you miss every time
Old Jul 14, 2014 | 08:00 PM
stp357's Avatar
stp357
I had the same issue when I first got mine. Just release the shifter after pushing it out of second, it will center between third and forth. Just push forward from there until you get used to it.
Old Jul 14, 2014 | 08:03 PM
drich2905's Avatar
drich2905
well maybe not every time, but a lot of the time
Old Jul 15, 2014 | 12:35 AM
ProfessorDeath's Avatar
ProfessorDeath
St. Jude Donor '13-'14
I almost never miss 3rd. Just push straight up, don't try forcing it, it will find its own way into gear. The open palm technique is silly, and much slower. Practice makes perfect.
Congrats on the Z!
Old Jul 15, 2014 | 01:16 AM
Bill Dearborn's Avatar
Bill Dearborn
Shifter works fine as long as you don't jam shift it like you would do an old fashioned 4 speed. Place hand on top of shifter, use 2 or 3 finger tips to shift to 2,4 or 6. Use palm of hand to shift to 1, 3 or 5.
2nd to 3rd shift is done by using palm with a very slight pressure to the right. Can be done with mostly hand movement and very little arm movement. Don't aim the shifter unless you want to miss the shift.
Bill
Old Jul 15, 2014 | 06:21 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
As said above but you may want to try this ("Ranger" even suggests it, I think). With engine-off, sit in the car and try the 2nd-o-third gear shifting technique outlined above.
(with clutch in) Just push with your palm at a normal speed. Keep increasing the speed just pushing with your palm. Finally, bang it hard. Even tho there is such a thing as rpm pressure that affects shifter compared to engine-off condition, you'll see it works just about every time.
Old Jul 15, 2014 | 07:58 AM
CheckSix's Avatar
CheckSix
geeeeezz.... I never miss the 2-3 power shift and I'm full handing it. It goes in every time and I don't lift off of the throttle either. I guess my early days of drag racing paid off. The only one I have messed up a few times is the 4-5 power shift but I usually don't get that far on the street due to speed.
Old Jul 15, 2014 | 08:04 AM
dvilin's Avatar
dvilin
It is easier pushing upwards with the palm of your hand. Fisting it I found can cause you to move it to far to the right and thus missing the shift.
Old Jul 15, 2014 | 08:21 AM
Todds427's Avatar
Todds427
St. Jude Donor '12
Thanks everyone for the info, I'm going to work with it for awhile and get used to the new pattern. I also did some research on the MGW shifter, it looks impressive! Would that be a better investment for shifting?
Old Jul 15, 2014 | 10:38 AM
dvilin's Avatar
dvilin
I would keep working on your shifting. Once that becomes a non issue, than you can decide if the MGW shifter would be a good investment. My opinion is spend your money elsewhere.
Old Jul 15, 2014 | 11:04 AM
Wayne O's Avatar
Wayne O
CF Senior Member
You mention having the problem under "hard acceleration." I'm guessing when going WOT you tense-up trying to make a fast shift with a death grip on the shifter. I suggest you relax and (as others have mentioned) using the palm of your hand gently 'guide' the shifter towards 3rd gear. Don't rush or 'force' the shift...be easy. Give the shifter a 'suggestion' of where to go and it'll find its way. Practice shifting in a smooth, relaxed manner. When you need a fast shift it'll be there when you need it. Good luck.
Old Jul 15, 2014 | 11:45 AM
Boomer111's Avatar
Boomer111
If you are thinking about the shift you will miss. Anticipation causes stress and stress tightens the muscles. Has to be second nature. Get a routine concerning hand placement on the shifter and trust it. Know your yellow rpm zone when building rpm shift in this one not at the red line. Shifting at the red line will be late.
I learned on a 13 speed trans in the big rig. With 400 rpm spread and pulling a hill you have to grab the next gear dead on or loose your torque and next lower gear. No clutch just unload the trans and move the stick. Thinking about this shift will cause a drop in a gear anyway and maybe more when frustrated. Gotta be second nature. No grinding either with perfect timing. And almost always perfect too with nearly 3 million miles practice.
I will say that when I got my 08 MN6 I too had some trouble with the timing and making smooth shifts. Just takes practice and correct method.
As other have mentioned the palm method works, try it and relax.
This is why on the street our cars are so fast that a lot of information has to be processed concerning your surroundings. This too makes shifting at redline more difficult.
Old Jul 15, 2014 | 11:57 AM
v26278's Avatar
v26278
The MGW is an improvement but it won't cure the problem, at least for me it didn't. It's a shorter throw shifter with a stronger spring to center it on the 3-4 gate. It should improve your shifting speed, plus it feels a lot more positive and precise like high performance equipment should, but the same "palm" technique is useful or you can still blow the 2-3 shift just like with the stock shifter.
Old Jul 15, 2014 | 01:35 PM
whit1's Avatar
whit1
Once I installed the Mgw shifter I noticed a big improvement over stock..
Old Jul 15, 2014 | 03:48 PM
z06clif's Avatar
z06clif
Just tap it out of 2nd and its sitting right at the gate for third. finesse it ......don't bully it. It don't like being bullied LOL
Clif
To Darn 3rd Gear-Shifting Help!
Old Jul 15, 2014 | 06:20 PM
61X's Avatar
61X
Practice, Practice, Practice. I have the mgw shifter and still occasionally "downshift" from third to fourth.
Old Jul 15, 2014 | 06:33 PM
furiousox's Avatar
furiousox
I started a thread in the drag racing section regarding this
I can shift 2nd to 3rd in anger fine, and most find if "quick" enough, but when I run cars with a dual clutch tranny or even a decent auto tranny, 2nd to 3rd I always fall back due to slowless of shifting.
I'm not sure if my clutch is on its way out (it's not slipping at low RPM in 6th gear), but I sometimes get a nice little grind, either from moving my hand too fast (not clutching in fast enough) or from clutching out too fast before my hand finished moving the lever.
It's pretty frustrating that after 2 years I still can't get this damn shift down. I have owned more than 10 3 pedals performance cars over the past decade and never had a problem shifting very quickly.
Once 2nd gear approaches redline the entire shifter assembly tightens up and it becomes much harder to push the lever into gear. I use the thumb-less grip per the Ranger article, I even sit in the garage and practice shifting with foot work, but it's very different when the car is under load. It feels like the shifter misaligns itself once I get past 5500rpm (I tried it so many times I can remember lol)
Old Jul 16, 2014 | 09:14 AM
Cbarile's Avatar
Cbarile
May sound lame but I watched a youtube video of shifting the c6 with the palm of your hand and not grabbing the shifter. I must say it helped alot as now I very rarely miss 3rd.
