I have had to 're-index my drivers side window every couple of weeks. it works fine after 're-indexing for a couple weeks then stops closing completely. I then 're-index and all is good for a while, any suggestions?
Probably your battery going.. I'd have that checked..
Something you also might look into is the grounding. I had a friend put a couple of robust grounds on his car, and he truly believes the whole electronics/car is performing better. After all these new cars are all about the electronics and sensors.
Thanks I am 99% sure it's not the battery. For some reason I missed the indexing with the window down, I will that and if need remove the door panel and reseat the connectors since that fixed the issue for bingo1105
