Acceleration problem 2008 c6 automatic HELP
I don't think we're getting the whole story.
Something seems odd with this whole thread....
These cars supposedly will do 186 mph.
Find a nice suburban neighborhood with plenty of kids, bikes, dogs, etc. and has a long straightaway.
See if you can get close to 186 then post the results. That should tell us something.
What happens when you floor it?[/QUO No not at all I dont floor cars I put it the pedal down about 75% with dramatically slower acceleration than it did for first two days with sluggish clunky knocking delayed shift cahanges feels slower than my old 300 hp Sl 500.
My assumption is that a 436 HP motor would normally only get 8 miles to the gallon. So corvettes are tuned to sip gas under moderate acceleration and to shift into the highest gear as quickly as possible. I'm guessing ?? The result is you get a 436 HP engine that can obtain near 28 MPG on highway and like 20 city. So it makes sense that the car feels like a V6 under normal driving conditions and a V8 under WOT conditions.
Make sure the engine is up to temps, mine sometimes has a rough time shifting if I take it out without letting it sit for a minute on cold days.
On that same note, if it hasn't been running long don't accelerate in a corner when it's on the verge of shifting. If i remember right it's supposed to hold whatever gear it's in during a turn, and if you don't expect the sudden shift that might happen as you come out of a corner it will feel clunky / jerky. Oh, and if you try shifting too early it will wait a split second to get closer to a proper shift point, at least in my experience, and that could also be causing the shifting issues in paddle mode.
If these don't sound like something you are having then try driving it the exact same way you did on the first couple days. Yes it's an auto, and yes it doesn't feel like 430+ HP when driving conservatively, but as soon as you push on it the baby will wake up in a damn hurry.
Also, what you feel that may be half throttle, is possibly only 1/4 or 1/3 throttle. Going full out does take some effort if you haven't done it before, I know it opened my eyes up real quick.
I found this on this website:
http://gmlongroof.4umer.com/t6394-common-4l60e-problems
You gotta be in in Limp Mode...
Little tidbits pop up from time to time, but he doesn't reveal it easily. Kinda like that fact that the car sat on the dealer's lot for months before he bought it. And that he ran Lucas cleaner through it which made the problem worse. Or the part about he filled the tank with 93 octane (no mention of how much), when that's normally what a dealer does when completing a sale. And that he paddle shifted to 1st gear at 50 MPH, which if it actually shifted would cause a mechanical over-rev and possibly done engine/trans damage that won't show up on a techII.
The weird part is that he's never gone WOT or exceeded 5000 RPM, yet believes he can accurately determine rates of acceleration by some magical means of precisely pushing a pedal to a specific percentage of distance. Like how can you know what 50% of something is, unless you know what 100% is? I fail to understand how you get "fast as hell acceleration" at part throttle.
Did he even have a mechanic drive the car? If so, did he go along for the ride? Did the mechanic go WOT? If there was a test drive and the mechanic felt it was fine, then maybe the OP's foot needs re-calibrated. If all the mechanic did was check for codes and saw no CEL, then the OP failed to present enough concern for his assumed problem.
Just a lot of gaps in the story and the biggest being what the circumstances were at the precise moment that this problem occurred.
Maybe someone local should take it for a drive if he fears WOT himself. Of course, he never filled out a profile, so other than this thread he's never revealed anything about himself (or herself) or the supposedly reputable dealer.
