Auto headlight sensor
The sensor is the little hemispherical 'bubble' in the dash grille next to the center speaker.
Probably an easy DIY to pop the grille off and change out the sensor.
So as stated, if the sensor sees the conditions as dusk lighting at all, and the lights are going to come on instantly. It's then when the sensor his exposed to the bright sun light long enough and sending the signal long enough, that the BCM will turn the lights off instead.
Really, the easy way to check the sensor, just turn the lights off via the light switch (and press the top right dash button to cancel the light suggested message in the DIC), and come dust/night, make sure that the car is turning the lights back on automatically isntead.
Hence sensor may be going lazy and it not sending back the correct voltage until the sensor has enough time to warm up instead.
The exact same thing has happened to me, twice in around 5,000 miles. Been fine the last few months.
Would, could, should, are all tentative.
As state, if the sensor was bad, then the car should be throwing a B2647 code.
But the glitch is the sensor is being read through the HVAC controller by the BCM, hence the HVAC controller is the item that is supposed to be sending 5v in the first place to the sensor, then getting the differential reading back, then sending the sensor output voltage to the BCM via the GM land bus. I bring this up, since if the HVAC controller is sending less than 5v to the sensor to begin with, then the reading back from the sensor will be lower than it should be, and a false reading back to the BCM through the land bus as well. Hence as long as the voltage reading from the sensor is 2.4V at the lowest (even in bright light), the car thinks that the sensor is good.
Bluntly, Given half a chance with the center console out for any reason, it always a good idea to pull the Hvac controller to clean its board/connectors and check for any questionable solder joints on it at the same time (same goes for any connector that in the area that you are working in the dash as well).
And yes, the next time I have my HVAC controller out, will do a write up on it for what to look for/how to clean it up if it goes glitchly, so the only reason to replace it is when you wear the button decal off instead.
To add, had GM just used some dielectric grease on the electrical connections when assembling the car, it would have solved a lot of electrical gremlins cause by corroded connections as the car.connections gets older instead.
So today I drove the car at around 2pm until 3pm and it was sunny out. The senso works perfectly under this conditions. Parked for an hr and got back in at 4pm and then the sensor thinks its dark.
At this point I'm guessing it might be the tint interfering with it. But I mean the difference from 2pm to 4pm isn't much in sunlight.. Anyway to adjust the sensitivity???... It really irritates me and then my running lights don't work cuz when I override the auto light then I have no lights at all..
I thought tinting a windshield was illegal anyway, except for the upper few inches.
Yeah, it has happened once in the Vette but since it happened in my wife's car also I concluded that even though I thought it was daylight enough it obviously wasn't.
On another subject, how's the weather in NY? The high here today was 91 deg.
Seasonal the past couple weeks, was down to 23* one morning.
But next week is "Indian Summer," will be sunny and in the 60s and 70s.
Probably the last hurrah for us til next spring.
I was at the same gas station I always use, but this NEVER happens during the summer. It's just (apparently) because the sun is so much less intense this time of year.
I've noticed it on my road too, which is completely shaded. In the summer my lights always go off within a half minute of pulling out of the barn, but this time of year sometimes they stay on til I get out of this "hole" I live in, and get into direct, bright sun.
That's my theory and I'm sticking to it.
I asked because my battery died this wknd. I got a new battery and this morning when I got into the car, the lights didn't not come on. Any other time under similar circumstances and time and temp, the lights would be on with the old battery. Relation?
Unless the weak battery was bringing down the alt voltage also.
In other words, if it is working now with the new battery then all is cool.
