Vitesse Throttle Controller Installed
Waiting for the positive review.
And waiting for this positive review as well.
Nothing different than what we did on the old days when we changed the timing, added advance weights to the distributor , advanced the cam if we had an automatic and changed jets in the carburetor except with this its all done with a computer now
You can also load the TCM ( transmission Control Module) tune which changes the shift points and firms up the shifts. Again no different that in the old days when we increased line pressure and added a modified throttle body
You can also turn off Torque Management .... which really wakes up the car but be careful with this one . I have my TM set to "off" but its real easy to put the car into a tree if I have my Throttle Controller turned up to SP9 and the car is not pointing straight
Some say that they cannot feel any difference so I can only speak for myself , The tune really woke my car up and when it shifts from first to second it will snap your neck
The Vitesse Throttle controller just modifies the throttle response curve . GM has a huge negative EXPONETIAL curve programed into the Corvette which is perceived by us as throttle Lag . The controller depending on the setting you chose removes or adds EXPONETIAL by just sending a modified signal and fooling the ECM on what position to put the throttle blade
The reason why I like both so much is as others have stated , with the Diablo you can return your car back to stock at any time , modify other parameters if you chose and with the throttle controller I can chose any setting I want instead of one that GM or a Tuner chose for me .
I can also remove it if I want just by unplugging it .
Since I don't want to overpower the tires and get the car all crossed up , if I was going to go to MEXICO and push it as hard as I can I would turn the controller down to SP7 but leave everything else alone , at this setting the car feels like my 1970 SS LS6 Chevelle putting as much power down to the ground, pulling hard all the way up to the red line , snap your neck when shifting but still controllable
Dave
Dave
It has an economy setting 0-9 and a sport setting 0-9.
(First I guess I should let you know that I have had the car Dyno tuned). The SP9 setting put the car into BEAST MODE. Slight pressure on the gas pedal and it downshifts, revs and flies...
City driving should be good on SP5-6.
Economy mode tames it ALOT. Great for letting the wife drive it when she wants... Haha
I've put about 20 miles on it in SP9 and it's a blast! Total transformation, even tho I've done:
BBK Cold air intake
BBK larger throttle body
Cat back exhaust
160 Deg thermostat
Dyno tuned (aggressively with trans. tune)
Would recommend !
I hid controller in center console.
