OEM Goodyears
Also, considering adding Blockit to the car, how many installed it and are disappointed.
Thanks in advance.
They are noisy, not very good in the rain, and terrible under 50 F .
I changed mine out at 10K miles because of them being so dangerous when I was caught in the rain, and was hydroplaning all over the place at 30MPH.
Any other tire but GY's will be much better.
Meaning, at any temp below 50, hang on if you punch it in 3rd, 2nd, and completely forget 1st.... Rainy roads can be scary too, and these are tires with about 2k miles on them.
I'm going back to my tried and proven Bridgestone Potenza Pole Positions once I wear this set out.
Drove it last saturday, Dry and in the low 30's/ high 20's. I had to move it from my old house to new house. They were downright awful and I babied it the whole way. Only got up to 30 MPH and took my time at that. I had to do a tight low speed turn and the front tires skipped like crazy. I was lucky it was only 1.5 miles and 3 traffic lights.
I couldn't imagine trying it with snow on the ground or on a highway.
Mine lasted just 12,000 miles on my '11 GS.
Much happier with my Bridgestone Potenza Pole Positions.
So, when it's below 40 deg. I drive in a very relaxed fashion 'til they get warm (which I can tell from the TPS read-out) and then avoid getting crazy aggressive on on/off ramps or pedal to the metal. Can't drive in snow, so 10 days/year it stays in the garage. I have never felt the car was dangerous at all. Never felt like I was "driving on ice," even at < 20 deg.
A lot easier than changing to winter tires in December and back to Summer tires in late March
The Blockit is designed to take care of tire/road noise especially in states like TX, CA, FL...etc where the roads make the tires roar.
It also helps with some exhaust BUT if you have headers, a real aggressive exhaust and your looking for a library, this is not for you.
Below are some positive treads from members about the Blockit. Within each thread you will also find a ton more positive posts from members & mods who like it. .
http://forums.corvetteforum.com/c6-c...ation-mat.html
http://forums.corvetteforum.com/c6-c...e-product.html
http://forums.corvetteforum.com/c6-c...ning-mats.html
http://forums.corvetteforum.com/c6-c...d-deadner.html
http://forums.corvetteforum.com/c6-c...irst-ride.html
http://forums.corvetteforum.com/c6-c...rformance.html
http://forums.corvetteforum.com/c6-c...post1573973170
http://forums.corvetteforum.com/c6-c...-block-it.html
And now with the C7, I grabbed these posts.....
It arrived packaged well. Easy install with a precise fit. I was able to use the rings and shade. I found it able to make a nice noise reduction on all surfaces around Little Rock including interstate and different road surfaces including concrete and asphalt.
I'm very happy with the product!
So bottom line: I'd recommend(your hearing my vary) .
I can't say it's equal to the kits that require full interior dis-assembly since I didn't do that, but I definitely feel there is value in the product. If you are in Southern Calif and want to try in your car, come by and we'll throw it in and you can hear for yourself. Or just take my car for a test drive.
Tom
If your interested its on sale now
★ Click here to order: http://store.tkoperformance.com/bleadinnodes.html
It is more about realizing the limits of summer performance tires in cooler temps. Oh and btw the Michelins on my C7 are not much better in the cold than the run craps on my C6
. ...... on the plus side they are not as noisy
I got tired of losing traction in 3rd while trying to accellerate to interstate speeds and any temp below 60 degrees with my Goodyears. Meaning, I would break straight line traction in third, just by flooring it at 4k rpms, at any temp below 60 degrees with the Goodyears, unless I literally smoked them for a hundred yards or so. That was not for me, as a daily driver I want predictable traction.
When I put on the Bridgestones, I could not make them spin in 1st, with very, very hard launches!! Even on wet roads, they would not break traction from full on accelleration in 2nd gear.
The Coopers I have on now act exactly like the Goodyears, so when I wear them out, it's back to Bridgestone Potenza Pole Positions for me
My OEM GY tires were at 4/32" thread (just over 1/2 worn) at 10K miles.
I changed them out after a hairy ride home on wet roads, just to be safe, as I drive my car, on road trips. I couldn't take a chance on being stuck on a road trip in the rain with a set of dangerous tires on my car.
After much research over that next week, looking at reviews and tire thread patterns, I bought a set of Firestone Summer performance tires, 10/32" thread. They were great at full thread, Good handling, not noisy, great wet condition traction.
At 3/32" thread remaining (70% worn), and at 30K miles on them, they were getting pretty noisy, but they still had decent traction on wet roads, not the 30-40 MPH max speed that the GY's had at 4/32" thread.
I replaced the Firestones at the 3/32" thread, with another set of exactly the same tire.
My observations:
GY F1 Supercars - From 9/32" - 4/32" at 10K miles- Dangerous on wet and at below 50F and noisy. Cost - $1500.00 + Installation
FROM TIRE RACK SITE:
Firestone WO Firehawk Indy 500's - From 10/32" - 3/32" at 30K miles.
Noisy but not dangerous to drive on them on wet conditions or below 50 F. Cost - $700.00 + Installation
IMO, I'm glad that I replaced the OEM tires. Since I drive my car from April to Nov on road trips, I need a tire that will be safe in wet conditions, and sometimes when the temps are below 40F.
Granted, all summer performance tires will not have the max traction at low temps.
For winter driving or below 20F, then for sure Winter tires and their special rubber compounds are needed for maximum safety.
Even AS tires are not suitable for winter driving, but better than running a summer performance tire.
While I do not complain about the fairly new GY's that came with the '08 I just bought (they're not that bad), the Tire Rack reviews, and my own experiences, do mean that something else will go on my car when they're worn out!!!
