Flowmaster drone help?
Old Jan 23, 2016 | 06:12 PM
Denis_3eleven's Avatar
Denis_3eleven
Default Flowmaster drone help?
I've read reviews from other members saying that Flowmaster axelback had a nasty drone at 1500-1800RPM and sounded sweet after that. That couldn't be more true. As lovely as it sounds at any RPMs, it's killing me with a top up in 6th gear on the freeway... There's no other issue I have with and and It's still more than worth it.
My questions are... Will adding an x pipe or anything else ease that drone? Could this be because it's an axelback? Will I be better off with a Magnaflow axelback instead?
Help appreciated.
Old Jan 23, 2016 | 06:28 PM
Denis_3eleven
Oh yeah, it's an 06 base vert 6mt model.
Old Jan 23, 2016 | 06:59 PM
05blkbeauty's Avatar
05blkbeauty
I have 05 coupe with flow masters (cat-back) and I don't have much drone, in fact I wish it were a little louder!
Old Jan 23, 2016 | 07:22 PM
Denis_3eleven
I wonder if it drones because it's an axelback. Would the h pipe fix it then? Interesting
Old Jan 23, 2016 | 08:24 PM
dmoneychris's Avatar
dmoneychris
My Grand Sport has a slight drone at the same RPM range w/my cars aftermarket exhaust system as well. Mine has longtube headers & a catted x-pipe as well. I'm looking into this insulation kit in the link below...I haven't pulled the trigger yet. I'm still deciding if I would rather cut & layer a Dynapad/Dynaliner combo on my own or get a pre-cut kit...
http://www.exoticvette.com/insulation%20c6.htm
Old Jan 23, 2016 | 08:29 PM
Denis_3eleven
That's a think outside the box idea but for this to work it'd need to be pretty heavy like dynamat. I'd rather stick to options with exhaust modification like an X or H pipe or something along those lines. Still, appreciate the input.
Old Jan 23, 2016 | 08:50 PM
dmoneychris
No problem . If those X or H mods don't do the trick, you might keep the option on the table for down the road. If you're going to hold on to the car for a while.
Old Jan 23, 2016 | 08:54 PM
Proud Owner's Avatar
Proud Owner
I have the Magnaflow axle back and minor drone at 1500-1700 not really bad at all.
Old Jan 23, 2016 | 10:26 PM
Denis_3eleven
The drone on mine isn't bad EXCEPT when I'm on a freeway in 6th gear touching the pedal to keep the speed. It has this super deep vacuum cleaner motorboat sound which I'm sure would be fine with the top down. That's my concern.
Old Jan 23, 2016 | 10:30 PM
Proud Owner
Well, my advice is if it bothers ya that much go grab a MagnaFlow axle back. IMO the best all around exhaust system for most performance cars. They are not that expensive.
Old Jan 23, 2016 | 10:33 PM
Denis_3eleven
I don't suppose you know how it compares to flows sound wise? Yes I've read reviews and YouTube videos don't show much through mic and speakers...
Old Jan 23, 2016 | 10:37 PM
Proud Owner
Well, to me over the years the Flowmasters seem to have more of a raspy sound to them. Again IMO Magnaflow has done this right. When I go WOT the MagnaFlow sounds great. I will try and get ya a video mañana. But it will be over speakers so not sure how much it will help ya.
Old Jan 23, 2016 | 10:41 PM
djbrun's Avatar
djbrun
X pipe will not help your drone.
If you want loud and no drone, go with the Borla s-type II axle back.
The ATAK is even louder, best overall exhaust I have tried.
Your best bet is to Go to a corvette get together and listen to some for yourself.
DJ
Old Jan 24, 2016 | 09:23 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
No it won't help at all. I went that road, I ended up switching to Corsa sports with long tube headers. Perfection to my ears.
Nothing you do, even dynamat will get rid of the drone.
Old Jan 24, 2016 | 10:01 AM
Proud Owner
Or..........put your stock exhaust system back on. You can pick them up on CL for cheap. The minor drone with my Magnaflow is perfect for me.
Old Jan 24, 2016 | 06:11 PM
Denis_3eleven
One more question. Would the drone go down once the hardware breaks in after a few hundred miles?
Old Jan 24, 2016 | 06:14 PM
Proud Owner
The tone will change after the inside of exhaust gets coated with carbon build up. But to answer your question, NO.
To Flowmaster drone help?
Old Jan 24, 2016 | 06:25 PM
Denis_3eleven
Thank you so much for quick answers!
Old Jan 24, 2016 | 06:26 PM
dmoneychris
This may be type of exhaust specific, but the drone on mine got louder after a few hundred miles. Maybe w/a few heat cycles & what not. I have long tube headers, catted x-pipe & dual mode Akrapovic Zo6 exhaust. The drone is noticeable when it's closed at 1500-2500 RPM. I didn't notice it much until a few hundred miles after the installation. There are no leaks, everything is tight & the tune is spot on. When the exhaust flaps are open, it just sounds like a race car so I don't care at that point because Jekyll is gone & Hyde has taken over. The closed mode is mostly for my wife, so she will get in the car to go out- lol.
Old Jan 25, 2016 | 06:23 PM
Denis_3eleven
Random update:
Took the top down today and this 6tg gear "drone" is actually a very pleasing sound. I guess it just doesn't resonate right with the top up.
That sound deadening idea would actually work it seems.
