Ranger Method?
Your taking about two different systems here.
The clutch is the flywheel, the clutch disc and the pressure plate. As the clutch disc wears from use, it creates clutch dust in the bell housing.
Now on the hydraulic side, you have the master cylinder, the slave cylinder and the throw out bearing that they will push forward to push the pressure plate fingers in so the pressure plate is not longer under tension (to allow the flywheel to free spin).
So what the ranger method does is removes the clutch dust that will work it way into the hydraulic system fluid, so the dust does not cause premature wear to the hydraulic side (inner parts of the slave and master cylinder).
So when the clutch parts wear out, the clutch will not engage correctly (clutch slips). When the hydraulic system wears out, then it will not push the throw out bearing outwards far enough against the pressure plate fingers, and you can not disengage the clutch instead.
Worst yet, as the hydraulic fluid becomes contaminated, this cause less movement of the slave cylinder to be able to push the throw out bearing outward to disengage the clutch fully as you push the clutch pedal all the way in, and cause premature wear to the clutch parts since it not fully disengaging
Bluntly, you can do the ranger fluid changes for around the cost of a quart worth of dot 4 to keep the fluid clean ($8), or you can just take the car down to GM to have the fluid power flushed every two years as called out in the service manual isntead (at the cost of around a grand for GM to power flush the fluid since it a PITA to get to the slave cylinder bleed vavle).
So again, very first fluid change in the tank, do the pedal pumps.
After this first time, just drive the car with changing out the fluid in the tank every few weeks as it become dirty again (no pumping needed on these fluid changes,since you driving the car is doing to pedal pumps instead), and after a few weeks of just fluid changes alone, the fluid will stay clean for months at a time until you will just need to change the fluid out in the tank again.
The master cylinder is easy to replace since you don't have to drop the drive line to get to it, but you still have to power bleed the system afterward, which means dropping some of the exhaust parts to get to the slave cylinder bleeder valve to power flush the system after the master cylinder has been replaced.
Why, since you did not want to take the time to just ranger method change the fluid to keep it clean for a total of around $8 worth of dot 4 fluid instead.
Just driving the car and using the clutch normally is better than pumping the clutch 40 times sitting in the garage. Besides the fact that pumping the clutch 40 times just needlessly wears on the system...why not spend those 40 times actually having fun driving it.
And even worse, since GM put three orifice restrictiors in the clutch fluid line to slow the clutch engagement down to save the drive line (the part that they warranty) if you clutch dump (the clutch they do not warrenty so they put the abuse to it with it slipping instead of the slower engagement), the more contaminated the fluid, the slower it is in returning from the slave to the master cylinder as well.
Hence here is the nasty rub, since the clutch pedal assists spring will try to pull the clutch pedal up when the assist spring cams over about half way up, and when the fluid is not returning to the master cylinder fast enough instead (through the 3 line restrictors), it end up pulling the end plumber off the end of the master cylinder rod to cause the dead pedal problem.
Read this thread, and the problem is caused by dirty fluid in the clutch system.
https://www.corvetteforum.com/forums...-pressure.html
So simply, GM is still not trying to solve the clutch dust problem in the lines from the bad seal design of the slave cylinder, but just came up with a new master cylinder that the end plunger is not pulled off so easily by the back fluid pressure not returning to the master cylinder through the restrictors instead. So even with the new master cylinder, the service book is still saying that the clutch fluid line still needs to be power flushed every two years still.
To bottom line it, the term to sum it all, is product obsolescence, and it not so much that GM screwed up on the design, but designed the system in a way that it causes the end user to have to replace/service parts more frequently instead.
Clutch dump abuse ends up with the clutch burnt up faster (which again the clutch is not under warranty), and if the fluid is not power flushed every two years as pointed out in the service manual (for around a grand each time), when the slave and master cylinder system die due to clutch dust in the fluid, you get to pay to have them replaced as well.
So with the vet, the price tag to own it is the simple money, and then you have the service charges to maintain it (the corvette tax money and in the life of the car, several time more than the selling price to begin with).
So what the Ranger Method does, is to save you a great deal of money, but staying in front of the problem/product obsolescence to begin with, to get multi-folds more expected life out of the clutch hydraulic instead.
And if think that its only the clutch hydraulic system that GM pull this stunt to sell more parts and services on the vet, your are sadly mistaken.
Case in point, GM designed the NPP exhaust solenoid backwards (NC, instead of Normal open) and it burns out in a short time, instead of lasting the life of the car instead.
Well, if you are talking about me, you should actually read my post. It takes me five minutes to drain the reservoir. And, put clean fluid in. Five minutes. That translates into an aggregate time of about one hour per year. Nobody is talking about changing MC fluid once a month. How much time do you spend cleaning your chrome wheels?
Got a couple 40 cc medical syringes with some large needles. One for sucking out bad fluid, the other for filling with clean fluid. Went on the WEB and found some thin black nylon tubing. Stiff walls, but flexible. Dimensions are 0.075 ID and 0.125 OD. Cut it about 18" long.
Takes 5 minutes to completely flush out the fluid. Repeat every few months and your normal driving cycles any missed fluid through the system for you to catch on the next flush.
Pics of what's needed.
