Ranger Method?
LMK.
Thanks,
Paul
Simple process. Once you do it the first time and get clear fluid (can take a quite a few cycles), then it is a pretty simple 5-minute procedure every few months to maintain it.
I have been doing the method for 8 yrs now and my fluid is always clear. 5,000 yearly miles with maybe 3 changes a year. I do not even change the fluid more than once per session. The first time it took two change cycles. If neglected do not be surprised if it takes a few cycles to stay clear the first time.
But, like buggy whips, some will insist nothing has changed and still use the buggy whip in their car to give it extra power.
In the new vets, the black pigement in the rubber seals leaches out, and will turn the fluid black. This is not a problem, but can mask the real problem next instead.
When you are using the clutch, the slave yclinder had a U shaped rubber plunger part that is riding on and inner and outer surfaces to push the throw out bearing forward to depress the clutch as you push in on the pedal.
The problem is clutch dust get in front of the U plunger piece on the surface walls, it rides over the clutch dust, and clutch dust gets into the fluid this way isntead.
Note, the inside of the bell housing is littered with clutch dust from using the clutch. There are some air vent passages to allow some of the dust to blow out, but even with this, not uncommon to have a 1/8" thick layer of clutch dust on all the surfaces in the bell housing static areas (like on the slave cylinder parts).
Since the clutch dust is abrasive, it end up wearing out the slave cylinder rubber seals quicker, and in regards to the master cylinder that is plastic (including it seal walls), really wears it out quickly when in the fluid instead.
So really, the game plan to have the clutch cylinder walls (and seal) last as long a possible, you want to do fluid changes on the fluid to try to keep is clear as your base line instead.
So you start with the ranger method with clutch pumps for the first few times, then from there, start to just suck the fluid out and replace it in the tank every few weeks until is stays clear, then every few months after point next. Hence after the first fluid change doing the ranger method, you driving the car and using the clutch will do the pumps for you instead, and just a mater of watching the fluid color to see if it time to change the fluid out in the tank.
Note: clutch dust in the lines is a know problem, and GM calls out for the clutch fluid lines to be power bleed every two years to deal with the problem that way instead. The glitch, the bleed valve on the slave is a monster to get at since it at the top front of the bell housing, and what should be a easy process, became a nightmare with having to remove exhaust tubes to get to the bleed valve instead. So by staying in front of the dust problem via ranger bleeding, it saves you hundreds every few years of having GM power bleed the system instead.
https://www.corvetteforum.com/forums...-pictures.html
BTW...
A friend of mine disagrees with the ranger method. Doesn't believe in changing it at all!
