Center speaker question
I've replaced the factory Bose HU with the Kenwood 9902s. Now Looking to upgrade the speakers. I will be replacing only the door tweeters and rear 5.25 speakers. Some people say to unplug the center speaker. Some people just let it be. For those of you that have replaced those 4 speakers on the Bose system, do you recommend unplugging the center speaker or leave it alone? Has anyone replaced the center speaker with an upgraded speaker? Is the door 3.5 " speaker a better speaker than the one in the dash?
I have already added about 50 sf. of fatmat to the floor. I'll be adding some to each door when I pull the panels.
I replaced my door speakers with components and disconnected the center. It sounds better without it. Also, the center speaker is identical to the 3.5" door speakers.
My understanding is the Bose system combines the left and right channels into one signal to that center speaker that many consider just "muddies" the sound. So most who disconnect the center speaker think the system sounds much clearer. I don't think the center speaker would be needed if you have nice speakers everywhere else. Just my opinion of course.
I removed my center speaker and used that space to mount the powered speaker for my Beltronics STiR Plus radar detector. The display and controls are custom built into the ash tray location, and hidden when the ash tray is closed. I also added an LED warning in the heads-up display.
Garry
Garry
Looks like I'll unplug the speaker and not bother replacing it. thanks
Just finished installed the sound deadener in the doors. Did not bother to pull the door panels until today when I decided what the next move would be with the speakers.
Replace Dash Speaker?
"I don't think 599 for a set of Focal Poly Kevlar Power Series 6.5"- 165KF is that expensive."
I do. Focals are expensive right now because they are popular. Popularity determines price more so than quality. And popularity is influenced more by good marketing than a good product. Like a BMW or i-phone for example.
You can get a very good set of 6x5s for under 200 bucks that the human ear can not tell the difference between that and a 1000 dollar set. But buy what you like. Some people have a very lose relationship with their wallet.
I would also like to know the depth of the front door speakers. I know alpine makes a decent shallow 10 inch mid-woofer. Surely someone has taken their door apart and measured it by now? They are 4 years old already.
Cost has nothing to do with quality of speaker for the ear. Speakers are a subjective component that are vastly different between brands. Some are cold and bright. Some are warm and midrange. Some are boomy. Some are a mixture of all three. Why does your radio have equalizer tone shapers in them? Because everyone likes a different sound.
As an audio engineer, for years I’ve tested speakers and at numerous times blind tested people who have picked a less expensive speaker over the currently acclaimed “Best (high priced) Speaker of the Year”.
My advice, go to several audio shops. A store like Best Buy has more top brands to compare in the same environment which makes it a fairer test. Listen to the expensive speakers and pick the type of sound that you like(they will sound different). Then start comparing the less expensive speakers (A/B). Keep going down in price until you actually can tell the difference. Now buy the ones that you couldn’t tell the difference from.
Unless your ego demands a certain name, the average buyer will save the money and be just as happy with the sound.
jimijam (01-07-2019)
Received 2,093 Likes
I removed my center speaker and mounted my XM antenna there.
A side note to my previous post: The loudest speaker always wins, no matter how bad it is. Try to get the speakers white noise sound level (between station static) as equal as possible before making your comparison.
I will dive in as I am a bit of an Audiophile. The center speaker was installed so that both the driver and the passenger have the exact same sound experience.. Whoever at GM thought that was a good idea was clueless about the soundstage,
First thing I did on my C6 was to disconnect the center speaker. That gave a very distinct left and right sound.
The goal of any stereo system is to create a soundstage so the band/instruments are laid out in front of you aka across the windshield. One of the best songs I have used to test a system is Chicago The Band's I'm A Man, Long version. They break out into a long percussion routine that has all the instruments laid out across the stage. With the center speaker removed I have the tambourine in my left ear, the sand blocks just to the right of that, the drums in the center and the cowbell and percussion blocks on the far right.
In all of my cars I disconnected the rear speakers, they just muck up the soundstage.
As far as expensive speakers versus cheap. there is a huge difference. I have two identical cars for my business, one with very expensive speakers Focal Performance PS 165 Components and the other stock speakers. The difference is simply amazing. Both have the same Pioneer HU's in them, but the Focals simply make the stock speakers sound like crap. People get in the car with the Focals and can't believe how incredible the sound.system is.
Neither car has any sound deadening material.
Hope this helps
Hope this helps
Unplug the center, you will never miss it and the sound imaging with be much better. Replacing it will not really add anything in my opinion. If you have the door panels off to replace the tweeters, really consider going with components and do away with the Bose altogether. From my experience and research aftermarket and Bose do not mix. Also you should really consider an aftermarket amp. My biggest mistake was not just doing the amp from the start. The amp changes everything for the better, and it is not that hard to install. My new Kenwood sounded decent in the garage but as soon as I hit highway speeds I knew I needed an amp..........You will not regret it and it is a must to drive aftermarket speakers. Good luck
And replace the Bose door speakers with the best mid range you can afford and drive a sub off the amp you add, again within your budget. You don't need top-line equipment initially to get an unbelievable improvement over the stock system! Good Luck!
Received 1,636 Likes
For a cheap easy upgrade you can easily replace the 3.5" door speakers and 5.25" rears with some aftermarket 4ohm speakers and you will definitely notice an improvement in sound and clarity while keeping the Bose woofers and amp. As far as the center speaker, try disconnecting it. It's not difficult to do, and you can decide for yourself if you prefer it connected or not.
Use a plastic trim tool or a tape-covered flat screwdriver to ease off the speaker trim... it's in there pretty snugly & easy to mark up the dash so just take your time. Then just disconnect the wires to the speaker & terminate the ends with insulating material, electrical tape, whatever you've got laying around. I used shrink tubing.
