05 quit running while driving
Old Aug 30, 2016 | 06:40 PM
K9KUZ's Avatar
K9KUZ
Good luck. When its fixed take a drive up here! I had some very strange electrical probs last year on my '11 - turned out to be BOTH the main battery and the FOB battery.
Old Aug 30, 2016 | 07:55 PM
echelonphoto's Avatar
echelonphoto
Here is whats happening ...you have a loose ground wire behind the left rear wheel...it bolts to the frame there. So as you are moving..it loosen up and you get no fuel...as soon as you stop..it settles down and you can start the car again...I fought this problem for two weeks until it dawn upon me in a dream believe it or not
Old Aug 30, 2016 | 08:02 PM
sonic1519's Avatar
sonic1519
If the car is running or your driving it would a bad battery cause the car to stall and die.......
Old Aug 30, 2016 | 08:13 PM
z06clif's Avatar
z06clif
Im willing to bet its a bad ground somwhere
Clif
Old Aug 31, 2016 | 12:20 AM
Cauhauna's Avatar
Cauhauna
Replying to this message in the event it ever happens to me.
Old Aug 31, 2016 | 07:26 AM
WW7's Avatar
WW7
Sometimes electrical components that fail, only do so when they get hot...I would find out what electrical components could cause this problem and check them one at a time...One that comes to mind is the ecm, parts in the ecm can malfuntion and fail when they heat up..It could be a ground, but the fact that the car starts right up again after stalling makes me think more in the line of electrical components in the ignition system...WW
Old Aug 31, 2016 | 12:01 PM
piddler's Avatar
piddler
In a DREAM, hey, I will take answers any way I can Get them. especially when it FIXES the problem, going to chk L rear wheel for a ground wire???
Old Aug 31, 2016 | 12:04 PM
piddler's Avatar
piddler
Clif
Ground where oh where can you be????Will definitely LOOK and twist and pull.
Old Aug 31, 2016 | 12:06 PM
piddler's Avatar
piddler
What is the "ecm" can it be checked , to see if it bad??
Old Aug 31, 2016 | 12:13 PM
piddler's Avatar
piddler
BUT would it start right up , did it 2 different times, as quick as I could get off road , hit button, fired right up, ran good, would it do this with weak battery????
Old Aug 31, 2016 | 02:00 PM
emcopet's Avatar
emcopet
Here is my experience.Half way between Las Vegas and Salt lake city on a hot sunday afternoon mine stopped like it ran out of gas.Pulled over and like yours it starts every time but would only drive for a couple of miles and quit again. It took me 3 hours and I finally made it home. There was an orange engine light up on the dash. When the weather cools off and orange light went off it ran good the rest of the way. Took to dealer the next day and the computer showed multiple low fuel pressure readings. Replaced fuel pump and control circuit board. Have someone check your computer readings..
Old Aug 31, 2016 | 02:19 PM
extrapilot's Avatar
extrapilot
Probably not.
With the car shutting down and having no dash lights or gauges working points to what others have suggested about a ground connection. Also check the connections with the battery cabling at the battery, starter motor, positive cabling to the under hood fuse box, negative cable connection at the ground to the block behind the starter. Follow the positive cable to the stater solenoid and look for evidences of the bakelite burnt or cracked at that connection point.
Here's a diagram listing the locations of some 12 ground points on the chassis.
Go to post #7
https://www.corvetteforum.com/forums...locations.html
Old Aug 31, 2016 | 05:05 PM
  #33
piddler's Avatar
piddler
Thank You, I will definitely have dealership check that, I hope it shows low pressure readings like yours.
Old Aug 31, 2016 | 05:08 PM
  #34
piddler's Avatar
piddler
Originally Posted by extrapilot
Probably not.
Go to post #7
Thank You will copy diagrams, I think loose ground also or maybe "ecm" ???
Old Aug 31, 2016 | 05:12 PM
  #35
piddler's Avatar
piddler
[B] Dealership drove car 60 miles yesterday with a computer diagnosis instrument plugged in to it, Ran great with NO problems, wouldn't you know it
Old Aug 31, 2016 | 06:26 PM
  #36
Charlie in TX's Avatar
Charlie in TX
ecm = engine control module
Definitely electrical. Could be charging system over charging. I would bet money on a bad ground or power wire going to the fuse panel.
Old Aug 31, 2016 | 07:06 PM
  #37
z06clif's Avatar
z06clif
Aint that always the way...
CLIF
To 05 quit running while driving
Old Aug 31, 2016 | 07:22 PM
  #38
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
What I would do, and don't know why the dealership didn't do it, but when I worked for Lincoln and had problems like your, we installed what we call flight recorder on the car and when it occurs you press a button to record what the ECM is doing.
Might want to ask for recorder.
Old Aug 31, 2016 | 08:12 PM
  #39
echelonphoto
The ground at the left wheel arch controls power to the fuel pump..mine would actually run fine for a long time, but when it lost contact would die instantly
Old Aug 31, 2016 | 08:22 PM
  #40
BlindSpot's Avatar
BlindSpot
I just did a thread on the starter conn and the grounds Monday.
https://www.corvetteforum.com/forums...nnections.html
If you check tightness/cleanliness yourself, please hear this caution: DO NOT attempt to check tightness on the starter solenoid with the battery connected. The wrench will certainly short to ground. Same holds true for the engine ground conn right above the starter G106. There, you'll likely short to the starter solenoid terminal.
