Ported throttle body will eliminate lag. I bought mine from Vmax Motorsports for $150, best investment I ever made. They have an exchange program so you can simply send them your old one after you receive theirs.
Hate to burst your bubble, but your still going to have lag even with the controller.
Hence GM programmed in throttle response lag, both pushing the throttle down, and letting off on it as well.
This was done to help gas mileage, as if you where holding the pedal steady instead.
Granted that your going to get into the meat of the power with less pedal push with the Vittesse controller, your still going to have that slight delay on pedal push before engine responce, and the same delay coming off the throttle before the RPM's start to drop.
Note, if you push the clutch in, it will allow the RPMs to drop instantly instead.
In the z06 throttle mapping, GM did not program as much delay into both sides, but its still there to a lesser degree instead (why you can't buck the car with the gas pedal like you could on a carb car).
Bluntly, if you are wanting crisp like a throttled carb car, then it will take a remapping of the throttle response tables in the ECM instead (which HP tuner and EFI live can not get at to do such). Also, you have to think of terms of spinning mass, such as the flywheel and clutch that lighting them would help to allow faster RPM climb and drops as well.
To sum it up, with the C6, you really have to think ahead when driving, to deal with the delays of the two and how you drive the car.
Originally Posted by GS057
I do not think your reply is valid if you do not own a Vittese.
Dano's right. You don't have to own a Vitesse to know that it only changes the amount of throttle requested, and does NOT change any parameters beyond that gas pedal on the floor. Read Vitesse's own website if you don't want to believe me.
I'm not saying the Vitesse isn't a good thing in its ability to remap the throttle pedal travel curve -- but that is all it does. If you want to feel 75% throttle when you are only pushing the throttle down 25% -- the Vitesse can do that for you, and it will certainly make the car 'feel' very snappy.
But to say it somehow changes any "lag" built into the remainder of the ECM or other systems is demonstrably wrong. Again, read their website.
Did you ever own (or drive) any muscle cars from the 60s-70s with steel linkage between your foot and the carb? If you did, then you would notice the lag on the C6. Not so much under normal driving, but dumping it from a standing or rolling start it is quite noticeable.
I have a VTC (SP6) installed and I completely agree with Bruze on the different "feel" from an older car. There is still a slight delay in response, no ammount of tuning can completely eliminate it, as there is no direct mechanical link between the throttle and accelerator. The VTC is a huge improvement over stock, but electronics can only go so far.
I appreciate all the input. My last experience with a performance car was a 66 Chevelle, the lag reminded me of the quadrajet when those big secondaries opened up. Switched to Holley, ran Holley on some boats over the years with good luck b4 efi became the norm. They were much easier to jet too. My tuner recommends a TB in his package so I'll try that route for now. Three weeks of ownership and my wallet is bruised up. Hurst shifter DIY this weekend, goin OS, will post some pics.
With only a tune(dyno/street) on a stock motor is a retune required with the addition of the Vmax throttle body upgrade?
Dont understand all the complaints about throttle lag.......when I want more power, I just push the peddle farther....what's the problem? You know not much happens in the first 25% of peddle travel, so adjust your thinking and it's no longer an issue.
Ordering today. I already have the Vitesse, but this looks like a great upgrade as well.
Does the ported throttle body affect the ability to get the car "smogged"?
