how would someone know if company car used cheap gas instead of premium
FWIW, I once knew a guy who grew up in the gasoline business and made a small fortune. He always drove high end cars (Maybach, Maserati, Lambo, etc.) and told me he never bought a drop of premium gas. He said the "premium" label was all marketing fluff which enabled them to make more money. The addition of additives raises the octane level and may add some cleaning agents but does not alter the quality of the fuel.
Received 1,136 Likes
"Premium" and "High Test" were (are) used interchangeably but I assumed most people knew that "Premium" didn't mean it was of higher quality.
"Premium" tires are generally better and of higher quality than "cheap" tires.
Same for an expensive suit vs. a cheap suit.
But not so for gasoline. "Premium" just has a higher octane for cars that need it. It isn't necessarily of higher quality than regular, or "cheap" gas.
As far as the wisdom of running high performance engines on regular, that has been debated many times on the forum. I personally think it’s dumb, but some disagree. As far as profit margin, yes, they do make more on premium. It costs about 10 cents per gallon more to make. But before you crucify the oil companies on that score, remember that profit margins are almost always higher on premium stuff, whether gas, cars, washing machines, or whatever.
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
^^^ Very interesting answer above! Thanks.
This is a myth that comes from the old days where the pumps were not filtered. The systems now have inline filters that prevent this from happening. If you have ever been to a station where your pump seems to be taking forever it is more than likely that the filter is just overdue for service.
You may be partially correct. I used to work at gas stations in the day when the customer did not pump the gas, like the way it still is today in New Jersey. Used to have to check for water in the bottom of the tanks every day by putting a special green paste on the bottom of the long measuring stick and record it. There was usually 1/2 to three inches of water in the bottom. Yes a filter will help stop debris from entering your gas tank, but it won't stop any water from going through it when the fuel is being stirred up by the tanker truck. The pumps do slow down when there is not much fuel left in the underground tank to help prevent air being drawn into the lines. All the tanker drivers always told me not to get gas when they were dumping fuel into the underground tanks so they got that information from somewhere.
