SuperVettes rear diffuser problem
Old Mar 1, 2017 | 10:58 AM
jkirk1's Avatar
jkirk1
Here's a photo of my 2006 Z51.
Yours looks correct.
Edit: I was missing the point at first. I can't remember if it tilts in towards the diff or out towards the rear of the car. I think some of us were thinking that the others posting about the installation were telling you to turn it upside down. My photo doesn't really give us much to go on. I'll check when I get home tonight.
Old Mar 1, 2017 | 11:00 AM
Biggie G's Avatar
Biggie G
I'd remove the sway bar, install defuser then install sway bar
Old Mar 1, 2017 | 11:31 AM
FlipRay's Avatar
FlipRay
I'd try to flip that sway bar if it wont hit anything flipped, ie exhaust.
Old Mar 1, 2017 | 04:57 PM
COMMANDER2OOO's Avatar
COMMANDER2OOO
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
Jkirk your sway bar is correct, if you look at his pic again you can see his swaybar is angled away from the support frame. if he takes it off and flip it around it will look just like Jkirk.
Old Mar 1, 2017 | 08:04 PM
el es tu's Avatar
el es tu
the angle of the swaybar looks like it may be off:
it seems like there might be an endlink installation issue
if for whatever reason the endlinks and bar are set correctly (but still contacting the diffuser), you can use universal sway bar bushings/brackets from energy suspension to move the bar upward (this will require a bit of massaging to the mount holes in the energy brackets but it can gain some clearance)
*you may want to go to adjustable endlinks if you havent already done so
energy bushings and brackets along with the specs so you can compare measurements:
https://www.corvetteforum.com/forums...m-img_0382.jpg
Old Mar 1, 2017 | 08:44 PM
choppychop's Avatar
choppychop
Originally Posted by poughkeepsie
now that is a beautiful car
O God here we go again........... lol
Old Mar 1, 2017 | 08:59 PM
COMMANDER2OOO
LOL hush Choppy.
Old Mar 1, 2017 | 09:20 PM
c6z51man's Avatar
c6z51man
Just took a pic little dark but should be good.
Old Mar 1, 2017 | 09:34 PM
choppychop's Avatar
choppychop
LOL hush Choppy.
Hahahahahahahahaaha
Old Mar 2, 2017 | 06:52 AM
el es tu's Avatar
el es tu
to see if its off Id have to see the endlinks - heres a link to pfadts swaybar isntallation guide - it will give you an idea of the orientation of everything: http://www.pfadtracing.com/blog/wp-c...structions.pdf
basically the bar should be parallel to the frame and control arm mount tabs that connect to the endlinks:
good luck!
Old Mar 2, 2017 | 07:17 AM
jkirk1's Avatar
jkirk1
Yep, looked under last night and it is just as you described. His sway bar needs to be spun around.
Old Mar 2, 2017 | 08:19 AM
c6z51man's Avatar
c6z51man
Thanks! I'm shocked that it's on wrong. Possibly from factory. Bought car used but was completely stock. Will update this weekend. Thanks everyone
Old Mar 22, 2017 | 12:25 AM
  #33
COMMANDER2OOO
c6z51man did you ever figure out what was wrong? and did you get it straight?
I had my wheels off today adjusting my e brakes and noticed my sway bar was on exactly like yours so I feel I may have given you some bad advise, my apologies. I would really like to know if you got it to fit and what you ended up having to do.
Old Mar 25, 2017 | 05:59 PM
  #34
c6z51man's Avatar
c6z51man
Originally Posted by Supervettes LLC
Just for the record, we still haven't received any phone calls from anyone regarding this.
Jason, I have sent couple emails to you and nothing back, maybe your not getting them. I will call you Monday,Thanks!
Old Mar 26, 2017 | 02:40 PM
  #35
c6z51man's Avatar
c6z51man
UPDATE:
So, I got the diffuser on. I took off the sway bar for the install. Im not sure what you guys who said the sway bar was on wrong, but it was NOT. As you can see in the pic how close the diffuser is to where the sway bar would be and I already trimmed ~3in off. I held up the sway bar and it was still touching slightly. Diffuser was not an easy install few gaps towards the ends....
Old Mar 26, 2017 | 03:22 PM
  #36
COMMANDER2OOO
Holy crap, it looks like you cut half the diffuser off. how does it mount underneath now that you cut so much off? As I said in a earlier post I realized your sway bar was on right when I pulled the wheels off mine to adjust the E brakes, and saw mine were mounted exactly the same as yours. Improper airflow would have to be a concern now that you cut so much off. It does look good though.
Old Mar 26, 2017 | 05:49 PM
  #37
Red08's Avatar
Red08
Originally Posted by pokerpro
I have they're quad exhaust diffuser and the only trimming that needed done was for the exhaust tips. Everything else fit perfect. 2006 Z06
Am I missing something? Where are your back-up lights? Correct me if I'm wrong, but aren't they legally required?
To SuperVettes rear diffuser problem
Old Mar 26, 2017 | 06:04 PM
  #38
pokerpro's Avatar
pokerpro
2021 C6 of the Year Finalist - Modified
2020 C6 of the Year Finalist - Modified
2015 C6 of Year Finalist
You are correct they are required and i do have them under there. There are two 4" wide aluminum blocks one on each side that have 4 extremely bright LED lights in each of them. These are so much brighter than any OEM reverse lights could possibly put out. I'll try to get a better pic of them to show you.
Old Mar 26, 2017 | 10:23 PM
  #39
c6z51man's Avatar
c6z51man
I cut about 3inches off, I had no choice it was hitting the sway bar bolt and still is a tight fit, idk what going on with this diffuser maybe just a bad one who knows. Idk how I'm going to mount it gonna have to be some custom thing. Can you guys with this diffuser take a pic of how close it comes to sway bar bolts to maybe see what's going on with mine... thanks
Old Mar 27, 2017 | 09:31 PM
  #40
c6z51man's Avatar
c6z51man
Should not hit any sway bar bolts, still sounds like something may have been wrong with your sway bar setup. Maybe aftermarket longer bolts, etc? Three inches is a lot to cut off, but not the end of the world. These are not fully functional unless you have a belly pan across the entire bottom, similar to a Ferrari.
"A diffuser, in an automotive context, is a shaped section of the car underbody which ... where a diffuser is usually located. It works by accelerating the velocity of the airflow underneath the car."
Supervettes: from my picture with the sway bar off what do you think is the problem?? See how close the diffuser is with no sway bar and 3in cut off??
