Shifter Cable Broken
Old Mar 10, 2017 | 07:48 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Shifter Cable Broken
Well the dreaded A6 shifter cable got me last night. Pulled into the garage, stopped the car and put it park (so I thought) and released the brake, only to have the car move forward. It ran into a 5 gallon bucket of paint I just bought for the exterior remodel we have in progress It it it hard enough to break the lower cabinet door when the paint was jammed into it. Surprisingly there is no damage to the car.
Next step is to pull the console and hope it is just the grommet.
Old Mar 10, 2017 | 07:55 PM
Mad*Max's Avatar
Mad*Max
Are you doing the fix yourself?
Old Mar 10, 2017 | 08:05 PM
C6ToGo's Avatar
C6ToGo
Most likely console end but you might jack her up and check the trans end before pulling the console.
Old Mar 10, 2017 | 08:09 PM
Mad*Max's Avatar
Mad*Max
Is this easy to check?
Old Mar 10, 2017 | 08:53 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Thanks, I will che k tbe trans first. Console on the C6 is a little more involved then the C5.
Old Mar 10, 2017 | 08:56 PM
RicK T's Avatar
RicK T
We're all with you, looking over your shoulder, kibitzing!
Old Mar 10, 2017 | 10:27 PM
Bruze's Avatar
Bruze
What year and how many miles on the car?
Old Mar 11, 2017 | 06:57 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
2007 with 27,000 miles
Old Mar 11, 2017 | 07:55 AM
C6ToGo's Avatar
C6ToGo
The shift cable runs from the console shifter to the trans linkage. It is attached at each end with a hard nylon bushing. Those bushings can fail and the shift cable separates from the linkage.
If shifter moves freely without selecting gears, check that the cable is still attached at trans. Then pull console and see if still attached at shifter. If still attached at both ends, suspect a broken cable.
Old Mar 11, 2017 | 07:58 AM
Mad*Max's Avatar
Mad*Max
What I was wondering is that if you put the car on a life is it easy to check the cable ends at both ends? Pulling the console is not easy, especially to get to the grommet.
Old Mar 11, 2017 | 08:54 AM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
I was under my 08 the other day,and looked at the trans. area,I could not
see that bushing. Iam old but not that old!
Old Mar 11, 2017 | 09:17 AM
Bruze's Avatar
Bruze
Thanks. '07 with 30k here.
I keep putting it off, but I will have to fix it this year before I'm stranded. I will replace the entire cable and tie the pawl back while it's apart.
Old Mar 11, 2017 | 09:39 AM
mrk1957's Avatar
mrk1957
I replaced my cable this past winter. Just as a maintenance thing, 100,000 on my vert. Had to remove the exhaust and tunnel plate. To replace the cable is a little tedious, but doable if you have mech.skills.
Pretty sure I'd do the whole cable even if one end grommet was broken. Might be a sign. The cable is less than $50 and almost just as much time to replace the whole thing as one end.
Old Mar 11, 2017 | 02:12 PM
Landru's Avatar
Landru
Well the dreaded A6 shifter cable got me last night. Pulled into the garage, stopped the car and put it park (so I thought) and released the brake, only to have the car move forward...damage to the car.
Can't beat where it decided to fail, a silver lining of sorts.
Good thing there's no damage, just cable replacement.
Old Mar 11, 2017 | 02:29 PM
GOLD72's Avatar
GOLD72
Let us know which end failed. Most likely the console end but check rear tranny end first since it is visible at the rear. The console end is not visible without disassembly.
Old Mar 11, 2017 | 02:40 PM
SnakeQ's Avatar
SnakeQ
You can also get to both connectors by putting the car on a lift, dropping the exhaust pipes from the manifolds to the mufflers, then dropping the torque tube cover. Don't know which is faster, but if you go through the console, you have to bend the forward cable up to almost the breaking point to change the nylon clip! Just did this yesterday to a C5 (same setup) and it was way easier doing it from the bottom. And, if you change on clip, you might as well change both.
Old Mar 11, 2017 | 02:46 PM
Mad*Max's Avatar
Mad*Max
when you do from the bottom, how long would each end take?
To Shifter Cable Broken
Old Mar 11, 2017 | 02:47 PM
Blk 08 C6's Avatar
Blk 08 C6
here you go.shifter side.rubber grommet dry rot and fails due to heat generated being to close proximty to torque tube.mine went out sometime last month.checked tranny side and its on its way out.replace both sides.if you look in search I have a pic. in there on the tranny side. kinda tight didnt have to unbolt my pipes just pop it off.
Old Mar 11, 2017 | 11:02 PM
barneygookle382's Avatar
barneygookle382
Default Shift cable
Replace with new cable now and be done with it, patch up with grommets as I did and a few weeks later the plastic end broke from the cable by the shifter probably damaged this pulling the shifter to the side to unsnap the cable no room in there everything in there is exposed to alot of heat and my cable sleeve snapped like a straw.. 2008 16'000 miles plus headers..
Old Mar 11, 2017 | 11:31 PM
mrk1957's Avatar
mrk1957
