Hatch Tinting Problem
Old Mar 21, 2017 | 05:09 PM
Durien512's Avatar
Durien512
Default Hatch Tinting Problem
I just had my windows tinted, noticed that the top where the OEM dots are the tint did not adhere to the glass as well.... It looks pretty crappy. The tint people stated that this is common on hatchbacks with the OEM dots. I called BS on this, Im having them remove it...
So whats the scoop here guys? How did your hatch get tinted? What am I missing here?
Old Mar 21, 2017 | 05:22 PM
schizcat's Avatar
schizcat
I remember doing a search right before I got mine tinted and heard the same thing. Mine shows a little of that after 8 years now. It seems to depend on who you go to for the tinting and if they know exactly how to work the tint into that area.
Old Mar 21, 2017 | 05:28 PM
rkj427's Avatar
rkj427
Pro Mechanic
it truly depends upon the type of tint used as far as how well it will form and adhere around the "dots"
on my coupe I had a solid piece of black vinyl added to the top area where the "dots" were and it covered them without any issue........
adding the solid vinyl did not lessen the visibility out of the rear window drastically either....................
Old Mar 21, 2017 | 05:51 PM
NashvilleGrandSport's Avatar
NashvilleGrandSport
Mine looks like that. I took it to the same tint shop that's done 13 other cars for me. They've been in business since 1975! They did the back glass 5 times. Is it perfect? No. Do I think they did the best they could? Yes. Most other Corvettes I've seen have a similar result. Those little dots are problematic.
Others will probably report different results or solutions like scraping the dots off first or using black vinyl as noted above.
Old Mar 21, 2017 | 06:02 PM
FAUEE's Avatar
FAUEE
You can either have the dots filed off, covered with black vinyl, or hope for the best.
The dots are problems for all vehicles with tint, we just have a ridiculous shape and a lot of the dots on top of it.
Old Mar 21, 2017 | 06:03 PM
Durien512's Avatar
Durien512
Thanks for the info guys
Old Mar 21, 2017 | 06:32 PM
Bruster's Avatar
Bruster
Yes the "Matrix" is a problematic area to tint. Mine looks like yours Durien. I have also heard of the solutions mentioned above, I have yet to try any of them.
Old Mar 21, 2017 | 06:43 PM
z06Don's Avatar
z06Don
I got some plain black vinyl on ebay and covered the matrix with that....when I had the tint done I had them leave the matrix uncovered and then made a template to cut the solid black vinyl to cover it.
Old Mar 21, 2017 | 07:46 PM
LMB-Z's Avatar
LMB-Z
Old Mar 21, 2017 | 08:27 PM
Atomic Punk's Avatar
Atomic Punk
every one ive ever had done has this. 3 vettes, 2 Z28's and a trans am. it's the nature of it. live with it. save the time going back cause they can't fix it.
Old Mar 21, 2017 | 08:31 PM
Dcasole's Avatar
Dcasole
Guys don't even try to remove the " DOT"s I guarantee you will ruin your back window and you do not even want to guess how much it will cost you ...... ( READ IT AS REAL EXPENSIVE )
The black on our glass is ceramic coating and not paint ....
As the others have stated either use black vinyl in that area or a thinner gauge window tint that will conform around the dots
Dave
Old Mar 22, 2017 | 12:47 AM
Not So Fast's Avatar
Not So Fast
Mine has it, used to bother me but now I don't even notice it, why worry, be happy
NSF
Old Mar 22, 2017 | 03:03 AM
Twayneo1's Avatar
Twayneo1
there is truly no way around it. unless you want to by a hatch window that is free of defrosters and those damn dots. my car has it too. but after a while you don't notice it. the first two days i did everything to make it look better, and honestly yours looks pretty good. but it will alway be like that. The tinting guys were correct this is common on windows with dots. i wouldn't have them remove it, because you will be wasting your time and money brother.
Old Mar 22, 2017 | 07:31 AM
SixAddict's Avatar
SixAddict
I've got the same issue. Can't see it at 80mph....
Old Mar 22, 2017 | 08:05 AM
Husker C6's Avatar
Husker C6
Mine has the exact same thing. Bothered me at first, don't even notice it anymore.
Old Mar 22, 2017 | 08:12 AM
Welker1's Avatar
Welker1
I have very little thanks to a very good installer that used a good film. Had mine done shortly after buying it in '06 and what little I have I don't even notice anymore
Old Mar 22, 2017 | 09:37 AM
Boomer111's Avatar
Boomer111
Used vinyl to cover the dots. Hardly even noticeable really. Can not see in rear view mirror at all.
Best way to do it, move on.
To Hatch Tinting Problem
Old Mar 22, 2017 | 10:40 AM
jhawk127's Avatar
jhawk127
Lots of threads here. For best results, Google search "C6 Forum window tint"
Here's a good one with valuable info.
https://www.corvetteforum.com/forums...-question.html
"Common on hatchbacks with OEM dots...." Yes, it's common because there are a lot of lazy, inexperienced installers.
If you have the patience, have them redo it. Otherwise, get a refund and take your business elsewhere.
My installer used Elmer's clear glue, and it is acceptable. It would have been better if my installer had taken more time with the squeegee. I worked on it a bit after the install to further eliminate the air pockets around the dots.
Others like the vinyl, but unless you are at 15% or darker, I personally think it doesn't look right as you can see where the black vinyl ends and tint starts.
Best of luck to you!
Old Mar 22, 2017 | 11:03 AM
jrose7004's Avatar
jrose7004
I've had the same problem on 2 C5's and both C6's that I've had.
Old Mar 22, 2017 | 12:33 PM
CMY SIX's Avatar
CMY SIX
My tint guy painted that area, 2007 don't even know it's there. there IS a difference between a good job and So-So, you get what you pay for
