Ls2 or Ls3?
Old Apr 12, 2017 | 08:01 PM
Jzanetti's Avatar
Jzanetti
Cruising
Default Ls2 or Ls3?
I recently posted questions about a c5 that I was planning to buy. That deal fell through due to the owner backing out. Now I've decided in buying a c6. I've seen several articles about the two engines. I'd like to get some input from people who actually have the ls2 and ls3.
Old Apr 12, 2017 | 08:33 PM
whiteboy's Avatar
whiteboy
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Ls2
Bought my LS2 06 Vert , 6 spd Z51,in 2009 with 24000 miles. Now has 46000 miles and has been faultless.
Either is a good choice. LS3 has about 30 more HP. Unless you are
planning on drag racing you will not be able to tell the difference.
Old Apr 12, 2017 | 09:01 PM
Jzanetti's Avatar
Jzanetti
Cruising
Thank you
Old Apr 12, 2017 | 09:08 PM
drew_c6's Avatar
drew_c6
Personally, I'd worry more about your overall budget and look for a car that meets your requirements for mileage and accessory loadout. The 30hp difference is at the motor. It's about 25 at the wheels. It's enough difference to win/lose a race between a stock LS3 and a stock LS2, but the cost difference very well may end up being enough to mod the LS2 to LS3 levels and maybe even a bit beyond.
Old Apr 12, 2017 | 09:39 PM
CadVette's Avatar
CadVette
Buy the best deal you can find. Seat of the pants it's hard to tell the difference between the two. If you get a great deal on the LS2 all you need is an intake manifold, cold air intake and exhaust and a tune to get where the LS3 is. $4000.00 dollars extra if you think it's worth it. C6 Vettes are not a good investment unless you can pass a pristine one to a young relative who might make a little on it 20 to 30 years later.
Old Apr 12, 2017 | 09:47 PM
Jzanetti's Avatar
Jzanetti
Cruising
Thanks, It was down to buying a coyote 5.0 and putting on a procharger or getting a clean c6 and adding exhaust, gears and custom tune. I had a mustang and I've always wanted a corvette
Old Apr 12, 2017 | 10:04 PM
CadVette's Avatar
CadVette
I understand. I loved my last Mustang and would still have it if it didn't catch fire and burn up on me. A Vette is the next level up. After all the real definition of a sports car is a two seater, two door high performance rear wheel drive coupe or convertible. At 8 years old the depreciation curve is leveling out too! Bang for the buck it's hard to beat a C6 Vette.
Old Apr 12, 2017 | 10:22 PM
Jzanetti's Avatar
Jzanetti
Cruising
That's the plan. I'm looking for a clean c6 around $25,000 with low miles. I'd like to find one with the exhaust and chrome wheels already on. I plan to add cold air, 390 gears and a custom tune. Later on I'll add the supercharger
Old Apr 12, 2017 | 10:40 PM
CadVette's Avatar
CadVette
If you supercharge it keep the boost low. Any more boost than 6 PSI may expand and bind the rings too much and then things may get more expensive. Any more boost you may need to gap the rings and while they are out of there you might as well put in forged pistons and rods. Get your Vette first. Then drive it for a bit. You may find that it is so easy to spin the tires you that a 390 gear rear end is not what you need. Then the stickier tire thing comes in. They don't last long. Drive it first then make a plan.
Old Apr 12, 2017 | 11:09 PM
buckmeister2's Avatar
buckmeister2
IMO, the high HP and torque and relatively low weight of the Vette makes a rear gear change one of the last, and least beneficial things most people do. A stock c6 with 2.56 gears can fry the tires easily.
If you are going to add an S/C, put your money into making sure the engine is able to handle the stress. It won't do any good to have 390 gears if you blow the engine. And, no, that does not mean they are weak engines...only that adding the stress of a supercharger is something to plan ahead for, on any engine.
Old Apr 13, 2017 | 02:46 AM
tri08sbc's Avatar
tri08sbc
That makes sense...
Old Apr 13, 2017 | 03:13 AM
BullittEV's Avatar
BullittEV
Veteran: Marine Corps
Everyone else is right, the engine I believe was basically ported out from 6.0L(400hp) to 6.2L (430hp)
The LS3 came in all non-Z06/ZR1's 2008-2013- but not only the engine, you get some serious suspension upgrades as well.
Old Apr 13, 2017 | 03:54 AM
Mike's LS3's Avatar
Mike's LS3
If you plan on supercharging, the LS3 block is a better choice because the main bearing webs are about 20% stronger, stronger rod bolts, larger bore, better flowing heads and intake manifold. Also, the manual transmission is stronger.
Edit: Just to add the dry sump LS3's have a forged steel crank because of the extended crank snout that drives the sump pump. That's all good, however an engine is as strong as it's weakest link. In a boosted application, that would be the cast pistons and rods before cast or forged crank.
Old Apr 13, 2017 | 07:54 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
^This.^
Old Apr 13, 2017 | 08:00 AM
Corvette_Ed's Avatar
Corvette_Ed
LS3 is a much better choice if FI is in the plan.
Old Apr 13, 2017 | 09:31 AM
Jzanetti's Avatar
Jzanetti
Cruising
Thanks for the advice. I appreciate it and it's going to help out a lot
Old Apr 13, 2017 | 10:30 AM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
The LS2 has a flatter torque curve than the LS3. So if it's just a daily driver, save the money, and go with the LS2. You won't tell any seat of the pants difference. Both are super reliable.
To Ls2 or Ls3?
Old Apr 13, 2017 | 02:44 PM
bassman50's Avatar
bassman50
We bought our first C6 (a 2007 base coupe with the Z51 suspension and A6 trans) in October. This was the last year with the LS2 engine and it's just fine. Plenty of power and decent fuel economy also.
For $25,000, you will possibly be able to get into a 2008 LS3, but choose you car wisely. As one poster said, C6s are not a good investment right now - - they are holding their value. Try to find one with low miles that has all the service records, regardless of which one you end up with.
Best of Luck!
Steve
Old Apr 13, 2017 | 03:56 PM
extrapilot's Avatar
extrapilot
I would re-consider the gear change and focus on a MN6 Z51, as the gearing is the plus here, 1, 2, 3 are lower than the non Z51, and the final ratio, 6th, is lower still. As a example, my Z51 cruise engine rpm is at 2k @ 80 mph, where the non-Z51 should be about 1800 rpm.
Old Apr 13, 2017 | 07:22 PM
449er's Avatar
449er
CF Community Team
Ls3,
