please help if possible
Old Apr 26, 2017 | 07:56 AM
hankenstine's Avatar
hankenstine
Originally Posted by hankenstine
Sorry missed that part of your post if the ticking doesn't stop your trunk relese button in the back of the car is dirty remove it and clean it and your good to go
Found this for you
https://www.corvetteforum.com/forums...-pictures.html
Old Apr 26, 2017 | 08:15 AM
Jerry0's Avatar
Jerry0
Thank you !!
now that you mention trunk key dirty,,that makes sense shortly before
this problem started I tried reprogramming a FOB that wasn't working
using trunk key procedure (ended up being a battery in FOB was put in upside down at place I bought car) but I had noticed key was tight and took several attempts with key to activate program fob mode
would you recommend a contact cleaner (or does key switch need to be removed) I greatly appreciate you help..
Old Apr 26, 2017 | 08:59 AM
CriticalmassGT's Avatar
CriticalmassGT
Originally Posted by Jerry0
quick /rapid clicking
That's the disk drive.
Old Apr 26, 2017 | 10:10 AM
hankenstine
Thank you !!
Not the key lock the trunk relese button next to it and i just use wd40 it lubes it at the same time
Old Apr 26, 2017 | 10:13 AM
Corvette_Ed's Avatar
Corvette_Ed
WD40 is not a lubricant. It becomes sticky when it dries; you'd be better off using a graphite or silicone lubricant.
Old Apr 26, 2017 | 11:07 AM
Jerry0's Avatar
Jerry0
I will check both key and switch.. key switch was very hard to turn
at 1st. I am leaning towards key switch position hung up as well
(grasping here)
car has lived most of its life in NE so its probably grime
Old Apr 26, 2017 | 12:40 PM
hankenstine
(grasping here)
My car did this same thing and it was the button it gets stuck and makes the relay inside the car behind the radio go nuts i dont think the key lock has anything to do with the relay
Old Apr 26, 2017 | 12:48 PM
Jerry0's Avatar
Jerry0
Thanks going to play around when I get home,, would be nice if it is that simple
Thanks again for the information
Old Apr 27, 2017 | 01:50 AM
alcatraz's Avatar
alcatraz
Cruising
Now this one got me wondering! Are you talking about the button located at the back (outside). Mine needs a clean. How can that affect the relay chatter inside?
Old Apr 27, 2017 | 07:59 AM
hankenstine
Yes the little black button it's the trunk relese and it must pull power from the brake light because if it gets dirty or stuck it makes the brake light relay behind your radio go nuts it will keep clicking even when your not applying the brake but if you only hear the clicking when you start your car or applying the brake and your trunk button works your fine
Old Apr 27, 2017 | 03:50 PM
Jerry0's Avatar
Jerry0
Hello
Thanks very much for the info. pulled out hatch release switch as you said it was loaded with dust and button/plunger was stiff also pulled apart
contact portion of switch and cleaned that.. reassembled and back in car
NO MORE CHATTER IN DASH other than initial startup which is normal
it is back to sounding like a normal car again..https://www.corvetteforum.com/forums...es/cheers2.gif Thanks AGAIN !!
Old Apr 27, 2017 | 11:12 PM
C3w4sp's Avatar
C3w4sp
Freaking cool
Looking in the service manual the thing doing the clicking is called the RCDLR. Remote Control Door Lock Reciever. I never thought about it but it stands to reason it does its thing when you push the trunk release button. And dahh, I never hear the ticking standing outside the car.
The gummed up button kept the receiver searching for the fob. Tickiddy tic tic,,tic,,,,,,,
You sorted out your issue for literally nothing.
I think the receiver also looks for the fob when the drivers door gets closed.
Old Apr 28, 2017 | 12:35 AM
  #33
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
You see .... that's what's so cool about the forum. There are lots of really nice helpful people here
Old Apr 28, 2017 | 05:32 AM
  #34
Jerry0's Avatar
Jerry0
Originally Posted by C3w4sp
Freaking cool
Yet this made my day to say the least... nice to have so many nice helpful people this site is fantastic as are its members !!!!
Old Apr 28, 2017 | 05:34 AM
  #35
Jerry0's Avatar
Jerry0
Couldn't agree more !!!! The people and information are both fantastic...
