Coolant
Old Apr 30, 2017 | 12:01 PM
BadgeZ28's Avatar
BadgeZ28
Just a side note. Coolant can be checked for effectiveness at low temps with a simple tester available at any auto parts store.
Old Apr 30, 2017 | 01:45 PM
HOXXOH's Avatar
HOXXOH
Car people in general and those higher performance minded ones in particular, tend to over-do maintenance and drive less than the average Joe.
Without good reason that's supported by documented research, people tend to follow the crowd and the advertising or recommendations by assumedly knowledgeable authorities.
Here's a short list for example.
More doctor's smoke Camels.
Friday the 13th is bad luck, so carry a rabbit's foot.
You must buy a diamond for a woman to be loved.
Blue chip stocks always make money
Guaranteed for a lifetime
Most things politicians say
Change oil at 3,000 miles
So tell me where is the documentation (not just opinions) that shows a length of time that automotive maintenance products will continue to function properly. Pretend I'm a doubting Thomas from Missouri and you need to show me.
Old Apr 30, 2017 | 07:19 PM
gordosoar's Avatar
gordosoar
Has anyone tried Evans Waterless coolant.?
Never have to change it for the life of the car.
Old Apr 30, 2017 | 07:34 PM
Bruze's Avatar
Bruze
Old May 1, 2017 | 11:21 AM
windyC6's Avatar
windyC6
....i'm in Missouri and I agree.....I think ??.....but I do think that one should change the air in their tires at least every 2 years.....
Old May 1, 2017 | 11:55 AM
5knives's Avatar
5knives
Since we can't rotate the tires on a Vette, what I've been doing every other oil change is rotating the air in the tires. I drain the air from 2 tires each into an empty tank. Then I swap the air and repeat for the other 2 tires. It requires 2 empty compressor tanks but it's worth it for peace of mind.
Old May 1, 2017 | 12:52 PM
HOXXOH's Avatar
HOXXOH
It's easier to rotate the tires about 1500 RPM,(aka 120 MPH) to let the centrifugal force pack the air near the tread momentarily and eject the impurities. When you stop, the air is cleaner and has better distribution. The only tank affected holds fuel. You can do this as many times as you feel necessary. I do it monthly to get that piece of mine.
Old May 1, 2017 | 01:50 PM
montman's Avatar
montman
Here's one for starters - from the 08 manual.
Old May 1, 2017 | 01:52 PM
montman's Avatar
montman
08 owners manual.
Old May 1, 2017 | 02:52 PM
windyC6's Avatar
windyC6
Originally Posted by montman
08 owners manual.
Well so much for this manual.....it doesn't even address the "air in the tires" change. There must be a mis print....
Old May 2, 2017 | 12:47 AM
703's Avatar
703
I see the blinker fluid change is also missing from the list. I change mine regularly (every 6 months) to ensure proper blinker timing and overall functionality.
Old May 2, 2017 | 01:09 AM
Bruze's Avatar
Bruze
Hey Webster guy! I graduated from RL Thomas, a long time ago. Grew up on Creek St.
