Coolant
No track just highway cruising for the most part.
Took into a dealer who is very well respected on in the corvette community. Told them the situation and to check on the condition. The rep said it looked like new and I was still good.
I asked them to check the condition and assumed they would test the fluid.
Now I am wondering if this happened, the testing part.
Reading lots of older threads about GM's Dexacool when it first came out, all horror stories.
I know GM quotes 5 years or 150,000 miles. It was originally designed to be a for life fluid.
I asked if just being in the system for 5 years contaminates the fluid and I was told not the way I have driven.
Brake fluid is 4 years old and they said will a little dark but it is fine.
I would think that they wold jump on replacement if marginal, after all it is a dealership and it wasn't busy like I have seen in the past.
What is the consensus here?
Ya I tend to over think things.....sometimes.
Even before we were old enough to legally drive and were ramming POS lot cars around, the above was true (and we beat them mercilessly).
And we often ran just water (in warm weather) because we had enough trouble scrounging up change for gasoline, screw wasting money on antifreeze.
If the dealer tested the ph level of the coolant and said it was fine and you didn't want to replace it, I would check the ph level more frequently or replace the coolant. After all, it isn't an expensive proposition. I'll have mine replaced this year even though it has low miles as it is a 2012, along with a brake fluid flush.
To the OP - I would change it after the five years - just did my 07's for the second time as a precaution - it is very easy to do at home - I was probably able to get out 75% of the old coolant.
Hate to be the bearer of bad news, but that is Oil in the Dexcool that is your seeing in the tank and on your finger. To prove it, light it on fire and you will see that it will burn, hence oil.
This the mess you end up up with when someone mixes standard radiator fluid (green) with Dexcool instead.
As for Dexcool sludging (not enough dexcool in the system with too much air in the system instead, or just left too long before flushes, you end up more with this,
As for Dexcool sludging (not enough dexcool in the system with too much air in the system as well, or just left too long, you end up more with this,
Now, if someone told us they were thinking of replacing the coolant every year, and brake fluid every month, that'd be extreme. But, five years and four years is not "doing it too soon."
I gotta say that all this "sealed system", fluid looks good, etc. is nice to think about. But really, isn't this fluid being USED? Heat and extreme heat, flows thru different metals, flowing thru system, cold, etc.? It's not like it's sitting in a hermetically-sealed container, in a climate-controlled environment, on a shelf somewhere. Even Mobil1 full synthetic oil has a "shelf life" that says replace and don't use after X years from just sitting on the shelf.
I say, don't waste money or fluids, but don't be foolish either (not saying anyone's being foolish). As that advertisement once said about paying for it now, or pay for it later. Later is always good, as long as it's not way, way more than paying for it now.
I have become somewhat laz in the recent few years due to so few miles driven.
I initially wanted the fluids tested, And I am not sure this was done.
I looked at the coolant and it does look brand new.
Remember I am the guy who changes his diff fluid every year with low miles driven and no track time.
Just trying not to spend so much money uselessly. Wife goes off every year.
I have gone to every other year now in the diff and it comes out pure with no sparkle of metal.
I tend to agree with everyone, should of changed them both.
I have gone to,every other year now in the diff and it comes out pure with no sparkal of metal.
I tend to agree with everyone. And I am disappointed in my service at Abel In Rio Vista.
I kept the engine oil/filter changed regularly; the engine was as clean as a whistle, didn't burn any oil, and ran great.
The tranny and rear end oil had never been touched since it left the factory and they were fine. When I was young, I don't remember anybody changing stick or diff fluid. They're not like the engine oil.
