Ceramic coating ?
But worth it to me. I'll post photos after the job is done.
G
Some guys in my club have it for the last 3 years and it still looks like new.
Check out you tube for some examples.
G
Very much worth doing to a black car. The day I took the pics of my car on the lift they also had a 17 black Z06, a 17 black Hellcat and a 17 black Jag F Type R in the shop. All getting paint correction and the Kenzo coating.
Jmills
As I've stated in other threads. 90% of the pop is the result of the quality of the prep. Just about any protectant applied after quality corrective work will yield that kind of shine and pop. Durability is the main advantage of some of the coatings, depending on how the car is driven, stored, and maintained.
DIY people should not assume the results are a function of the coating itself. It absolutely is not. I apply coating on my wife's DD since it spends most days in sun, rain, slush, snow, whatever, so benefits from the extra protection a coating can provide. And, though her car has 110K miles, it looks better than most new cars - simply because I have the tools and skills to do proper prep before applying whatever protective product I choose. Honestly, most people interested in this kind of thing should let a local professional do the work, since the time and expense of doing it yourself will be greater than what they charge.
DIY - coatings are not applied like most waxes or sealants. They are more challenging to apply and less forgiving than most of the waxes and sealants you can get at your favorite local store. Even what you choose for application is fairly important with coatings, while others can be applied with a variety of things without much issue. For those determined to do it themselves - absolutely follow manufacturers instructions to the letter.
Mine had the gloss after the correction and before the coating was applied. I don't have the tools, skill or time to DIY. I mainly took mine to the shop to have the correction done because of the swirl marks, water spots and a few surface scratches it had when I bought it. Decided to do the coating so I don't have to wax it and it last longer. I do believe that coating has better hydrophobic ability than a wax does. At least the waxes I have used. Makes it easy to keep clean. I can just spray it off with my pressure washer and hit it with my car dryer for a quick wash but do need to do a 3 bucket hand wash every once and a while. Everyone that sees my car comments on the color and thought it looked good before the correction. But now people see it and say WOW.
