Check out this tire separation...
Can't say as I've seen this one before. Michelin Pilot Sport. Passenger side front. I have a new-to-me set of C7 takeoffs waiting to go on - thank goodness. Looks like I'll have to swap one on and run without a TPMS to the tire shop to avoid the tear possibly going down into the bead and blowing off the rim. That would suck...
John
Mich owes you a new tire I'd say, at least a new prorated one anyway.
Could claim scratched rim was a sign a curb or some such had been hit, though.
I'd try anyway, no tire should do that and especially a RF.
Received 2,890 Likes
Been there done that. Got run off the road by a idiot who was not looking. Hit a big reflector and blew out the sidewall just like that. DT gave me a new one for the cost of a new certificate.
Heading there now to get new M AS3+ put on.
No scratch there, it's rubber particles from where the gash opened up. The mark rubbed right off when I came out to check it. There is curb rash elsewhere on the wheel, probably 60 degrees from the site of the gash. The tires were made in 2012 so I don't know how much Michelin would do for it. I bought the car in May 2016 with these tires on it and I've put about 23k on them. There was a knot there initially which is part of the reason I got a new set.
ByByBMW (06-27-2017)
Received 1,116 Likes
Prorate tire adjustments are usually based on remaining tread depth and not on age of tire. At least for mileage warranties. I would think they would consider this Road Hazard.
DT did the same for me. Tire had less than 1k miles on it before it blew out.
In the tire business, they call that an impact break!
marinablu67 (06-28-2017)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
The other thing I think is something very sharp (not cutting sharp) like a railroad track at just enough of high speed to have it bang on that one point.
With my Michelins, on a CT highway, I came up to a bridge at speed (65-70) and the darned thing had a metal expansion joint separating the two pieces of concrete road to bridge. I hit it so hard, I thought I'd bent all four wheels and blown out at least one or more tires. I stopped very shortly thereafter, took a tire pressure ck., shut off the car to look/listen for leaks, etc. I got lucky, no nothing happened. But it surely could have.
Try this: have someone place their palm on your chest and push. Then have them use just the tip of their pointing finger and push with the same force.
Low profile tires are extremely susceptible to sidewall damage. This is not a manufacturing defect.
I already had a new set of C7 takeoffs on standby, just wanted everybody to see, be aware, and get some thoughts on possible causes. Thanks guys! New wheels and tires are on now.
Edges of the separation channels are too square,
Someone dug a bead breaker spoon into the side of the rubber when mounting the tires to do that damage.
Mich ro road hazard may cover it, but the damage was really down by the shop that was working on the tires instead.
